06-05-2023, 11:40 PM | #1 |
Rep 618
what makes the s58 so much better than the s55
I've been wondering, what makes the s58 so much better than the s55 in terms of power making potential and reliability? how is a downpipe and a tune all you need to make 700+ whp on the G8X platform? plus no need to buy a crankhub upgrade to support all of that power.
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
06-06-2023, 12:35 AM | #2 | |
Rep 401
somer966.00 Forzanerazzurri6918.00 turnsignalslol274.50 anthony412159.00 SubzeroF90244.50 Vectors2final1356.50 eugenebmw1482.00 |
06-06-2023, 06:36 AM | #3 |
Rep 989
Drives: 2024 M4 Comp X-Drive
The S58 is a little bit like the 2JZ of the BMW world. It’s going to be a classic engine for making big power.
06-06-2023, 09:06 AM | #4 |
Rep 1,929
The s58 has bigger turbo's, lower compression so it can run higher boost, more fuel flow capability, add those things together with Xdrive and some ethanol and you got a 9 second car.
Info@mad-us.com1925.00 Forzanerazzurri6918.00 turnsignalslol274.50 SubzeroF90244.50 6speed_M23633.50 BigRedG80127.00 |
06-06-2023, 08:35 PM | #5 |
Rep 764
BMW nailed it with the s58.
forcefed2567.00 Forzanerazzurri6918.00 |
06-07-2023, 12:11 AM | #6 |
Rep 618
A G8X car is something I definitely want in the future. But I haven't had my M2C for very long and am still waiting for my warranty to expire so that I can have my fun. We'll see how much I still want a S58 once I get to tune my S55 (and yes, I will be doing crankhub before doing any power mods)
06-07-2023, 12:15 AM | #7 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
What a beast
06-09-2023, 12:25 PM | #8 |
Rep 124
S58 is derived from B58. The compression ratio was dropped from 11:1 to 9.3:1, making S58 a big old boosty boost boy.
Plus you get forged steel con rods, forged aluminum pistons and a forged chrome molybdenum heat treated steel crankshaft as well as plasma coated cylinder walls. The internals are STRONG. Classic overengineered German machine. |
12
kgelfen3602217.00 Forzanerazzurri6918.00 BetMineWins22.50 imperfectluck426.50 TrentMeister2860.00 dspiel37.50 mathys202.50 Vectors2final1356.50 AJM1125114.50 Bimmerfun827215.00 Jnat408.50 MintyG823.00 |
06-09-2023, 03:55 PM | #9 | |
Rep 1,446
06-09-2023, 05:22 PM | #10 |
Rep 311
To be fair //M motors have very predictable maintenance/ upgrades needed to be bullet proof. S58 seems to be the perfect motor finally.
//M is awesome
06-10-2023, 09:25 AM | #11 |
Rep 1,446
06-10-2023, 11:04 AM | #12 |
Rep 6,726
There’s a few tuned S58’s that have grenaded their motors top end but they are tuned to be fair and anything goes at that point. Maybe a Motiv issue according to one poster.
I’m also hoping for a robust platform that can be tuned to reasonable levels outside of the typical rod bearing, crankhub, and VANOS issues. |
06-12-2023, 12:09 AM | #14 |
Rep 217
Drives: BMW M3 Competition XDrive
While most of the guys talking about the positiv stuff, I will say few words about the weak points:
- Rods - Rod- and mainbearings - Clutch If those things could have handled little bit more ... the car would have been really a beast of a beast.
m3inquisitor -- XtremWerk XW12 Twin Frame Turbo Setup -- Build Motor -- Reworked Cylinder Head -- Upgraded Transmission -- R44 Titanium Exhaust -- xHP Stage 3 -- Unlock Femto + bm3 -- Custom Tune by odintuned --
bilal5.00 |
06-12-2023, 03:50 AM | #15 | |
Rep 824
Drives: G80 M3CX (Oxide Grey)
Also, what sort of power is your car running now that you are running into these issues?
Gone:
2011 E90 318d (Alpine White) • 2016 F83 M4 (Mineral White) • 2019 F83 M4 Competition (Sapphire Black) Current: 2022 G80 M3 Competition M xDrive (Oxide Grey) Last edited by Sbm007; 06-12-2023 at 07:47 AM.. |
06-12-2023, 07:38 AM | #16 | |
Rep 6,589
The S58 is way more mature and capable though |
06-13-2023, 01:46 AM | #17 | |
Rep 217
About the bearings: I personally experienced it and saw how they look. I am building my engine and gearbox currently. At 9000 km (5600 mi) my main and rod bearings were already in bad shape. I know lots of other S58 opened engines with very little milage and they all had same issues. I assume it is the OEM oil and the Bearings materials. About the clutch: A friend was running 25k km (15.5k mi) on stage 2 and he gave his gearbox for upgrade. Clutch was done. So basically above 900 nm (660-700 ft lbs) you will roast the clutch at some point. For me: 1. Change frequently oil (3000 mi) and I think it is better to switch to different oil (not OEM). 2. Torque must be limited 650-700 ft lbs (if one plan to drive the car for a long term) 3. If one plans to go hybrids or frame - just do engine and gearbox (not worth the risk).
06-13-2023, 07:38 AM | #18 | |
Rep 984
2022 M3 XDrive - Full Race Turbos - BMC Filters - MAD Catless downpipes - MAD single midpipe - BM3 Flex Fuel Kit - Paul Johnson Flex Fuel - XHP - MPHAS - EBC Bluestuff - PS4S
2023 IX M60 2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09 |
BetMineWins22.50 |
06-13-2023, 07:46 AM | #19 | |
Rep 1,052
06-13-2023, 07:47 AM | #20 | |
Rep 217
I know lots of guys running 5w40 and even thicker oil. It is stupid that B58 has zero issues with bearings and S58 sux
06-13-2023, 07:48 AM | #21 |
Rep 217
5w40 - Röwe Racing (but Make plays no role … redline, lm, ravenol, motul … all good)
06-13-2023, 08:39 AM | #22 |
Rep 6,726
This will definitely be something to watch for as the years go by. BMW should have learned lessons from the prior rod bearing issues of the past. The S55 didn’t have widespread issues although a few may have happened, just not widely broadcast.
