04-22-2024, 12:38 PM | #1 |
Rep 3,715
How is the lap analyzer with the M Drive Professional?
I'm adding it as an option on my build for the M track mode/traction but wondering how accurate or useful it is. Does it automatically detect start/stop line and how decent is the gps refresh?
Would be a lot easier than my GoPro/XGPS setup if it's decent. Not looking for excessive information like the catalyst, at least for now. |
04-22-2024, 02:16 PM | #2 |
Learning to drive again
728
Rep 328
Drives: M3CS
It has useful information, but it is not a lap timer. It does not detect start/stop of a track or autox course. What you see is what you get and that's it.
IMHO, viewing the track data, such as brake zone, speed, Gs, etc. on a phone is also not practical. The way it is useful to me is it tells me when I apply the throttle and how much, when I apply and release the brakes (I can tell amount of braking I am applying through the G-meter) and my RPMs, and integrates all that with the video. For me and my personal driving objectives, it is more than sufficient. I am very proficient in using full-fledge data analyzers, and in the past I would lose myself in all of the data I used to collect. It is tremendously fun to do so, and helps with self-coaching tremendously. I no longer have such objectives, time or money to spend. The M Perf. Analyzer is cheap, easy and sufficient for me.
Cheers,
BoB |
NYG10840.50 |
04-22-2024, 02:20 PM | #3 |
Rep 3,715
BackOnBlack727.50 ///M Power-Belgium63937.50 |
04-22-2024, 07:51 PM | #4 |
Rep 310
Drives: ‘23 M3 Comp xDrive
It works well for me. Auto detects everything and gives me cool useful information.
I haven’t been able to save any of it after turning the car off, so I’m not sure I can do that or not but it’s awesome to see lap times and max speeds and Gs. I doubt it’ll give as much info as something aftermarket, but it couldn’t be any easier to use for a normal track day |
NYG10840.50 |
04-23-2024, 08:48 AM | #5 | |
Rep 3,715
EatThatLunchBaby388.00 |
04-23-2024, 10:27 PM | #6 |
Rep 735
You can run both the M Drive Analyzer and the M Lap Timer at the same time while on track.
The M Drive Analyzer runs as an app on your phone using a Bluetooth transmitter connected to the OBDII port. Mount your phone and record your laps and the data. You can then view the recording in the app on your phone with telemetry, or export it and get the telemetry overlay: At the same time that you're running the M Drive Analyzer on your phone, you can run M Lap Timer from the Apps in iDrive. This will add a widget to your dash/HUD that shows real-time lap times and timing differentials from the fast lap. One thing to note though is that where ever you press start/stop is where the app will think the start/finish line is. At the end of the session it will tell you which lap was your fastest and what the time was:
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 Last edited by m4ml; 04-23-2024 at 10:41 PM.. |
04-24-2024, 09:06 AM | #7 | |
Rep 3,715
m4ml1859.50 |
04-24-2024, 02:40 PM | #8 | |
Rep 310
04-24-2024, 03:57 PM | #9 | |
Rep 735
Edit (because I might have misunderstood your statement): The phone app for M Lap Timer does not work any more, regardless of ID7 or ID8. The M Lap Timer in-car app is still available however (at least in ID7, and should be available in ID8). The in-car M Lap Timer can run at the same time as M Drive Analyzer. This is because M Lap Timer is an in-car app, and M Drive Analyzer is a phone app (that I think "replaced" the M Lap Timer phone app - even though the M Lap Timer phone app was awesome from what I saw of it).
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 Last edited by m4ml; 04-24-2024 at 04:05 PM.. |
EatThatLunchBaby388.00 NYG10840.50 |
