      05-25-2021, 03:41 PM   #1
Scorp!on
Switzerland
1512
Drives: BMW M3 G80 MT BSM
Brakes "squeak" since break-in service
Hi together,
I don't know if you have the same issue as me...but since the break-in service my brakes squeak on low speed as soon as they are a little warmed up.
and it's really loud !!
I called the mechanic and he told me it's normal, I should brake once pretty hard (which I then did but didn't help) but it will never go away completely.
I mean I know it's a performance car but this is insanely loud...I never owned an M car before so I don't know if this really is normal.
Have you guys the same experience ?
      05-25-2021, 04:13 PM   #2
bri1042
bri1042's Avatar
5925
Drives: 2021 IOMG M3 6MT
Brake hard a few more times. It is "normal" but it's been worse on this car than my M2C was (not a lot, but worse).
Scorp!on1511.50
      05-25-2021, 04:28 PM   #3
Scorp!on
Switzerland
1512
OK i'll do it, thank you !
so this is actually "normal" ?
      05-25-2021, 04:53 PM   #4
bri1042
bri1042's Avatar
5925
Yep, it is. Porsche made a whole video about squeaky performance brakes at one point.
Scorp!on1511.50
      05-25-2021, 04:57 PM   #5
opielm
Drives: G80 TBII 6MT
It's "normal" but should go away once the pads are set into the rotors. The trick is to break a few times to first get the rotors and pads more malleable due to the heat generated. Someone recently posted this that explains a pretty involved process if you are desperate.
https://brakeperformance.com/bedding-in-rotors.php
Scorp!on1511.50
