09-08-2023, 10:12 AM | #112 |
Rep 191,156
09-09-2023, 01:26 AM | #114 |
Rep 179
Ordered on 8/30 and received directly from Germany on 9/7 (DHL/USPS). This controller was exactly what I was looking for. Prior to the controller, I found sport+ / valves open a tad too quiet from what I wanted out of my dinan rear section and mid pipe. But now, it is at the perfect volume I was looking for.
Install was a breeze even without a lift or Jack however, I do recommend. It took me about 5 min to install and 30 min for wiring management. I then, programmed A and C to homelink for quick access to factory and full open settings. I 100% recommend this to anyone in doubt but, I also hope it last a lot longer than the VSCs I was hearing about. Only time will tell. Thanks again Mike and X-PH for getting this to me so quickly! |
09-09-2023, 04:59 PM | #116 |
218
Rep 260
Although it does seem a pretty easy install, are there any good videos around that show the Install, with cable routing through the gromet as shown in the previous pics? The ones I found on YouTube has them mounting it under the car.
09-09-2023, 05:03 PM | #117 |
Rep 152
I haven’t found any but I assure you when you take a look at the grommets and truck space you will figure it out. The grommets are super close to the exhaust valves.
Tobstertx3217.50 |
09-10-2023, 02:53 AM | #119 |
Rep 138
Install was a breeze (~10 minutes include wire zip tie management).
However, sometimes when pressing the B button, the flaps don't close so I just leave them open and try it again next time. Seems to work every other time. Meanwhile, the A button works like a charm everytime Paired with Gesi HFC, resonated single MAD midpipe, and stock muffler. Stage 2 BM3 OTS tune...really enjoying the combination with juuust the right amount of loud, and am done with exhaust tinkering. |
09-10-2023, 07:27 PM | #120 |
Rep 191,156
dm sent
09-10-2023, 10:13 PM | #122 |
Rep 164
Drives: 2023 G80 M3 Competition Xdrive
Works great and install was a breeze. Can anyone else confirm for me that the remote does not work on the valves with a remote start? It wasn't until I actually got in to start it is when the my controller started working, so seeing if anyone can replicate it.
Instagram- @G80M3dia
Current: '23 G80 M3 Comp - BG over FR Past: '16 Mineral Grey M235i, '03 e46 330i |
M3YEC253.00 |
09-11-2023, 10:35 AM | #124 | |
Rep 191,156
2turboBMW115.50 |
09-12-2023, 12:39 PM | #126 |
Rep 13
For the Canadian folks ordering this, it may take a little longer. I'm just glad it will arrive before I go on vacation
Timeline: Aug 24th order placed Shipped out from Germany on Aug 28th Arrived in Canada and presented to customs for processing on Sept 6th Released from customs on Sept 12th Delivery is TBA |
hrosenberg33630.50 |
09-12-2023, 01:33 PM | #127 |
Rep 303
Hi Mike,
Do you carry this for the G83 M4 on your site? I could not locate it? Any differences for M4 for installations compared to the M3 for routing, etc? Thank you |
09-12-2023, 02:09 PM | #128 |
Rep 191,156
its the same for the G80 and G82
09-12-2023, 05:42 PM | #129 |
Rep 2,686
I would be a bit careful with that. From experience installing the VSC2 controller, there's a lot of extra struts and bracing across the bottom of the car for the G83 because of the convertible roof.
Those two bolt areas for the VSC2 are taken up by those struts and can't be used to mount the controller. I wouldn't know how to access the trunk compartment with all of these extra parts in the way. I had to ziptie the controller to the strut braces. Pics attached. If I'm overthinking this LMK but it doesn't seem as straight forward as on the G80 or 82. Plug and play compatibility-wise, yeah there's no issues, but maneuvering around in there seems challenging. |
09-12-2023, 08:05 PM | #131 | |
Rep 226
Oh well, I’m sure it will be with the wait. |
09-13-2023, 01:47 AM | #132 |
Rep 13
Usually my packages pass through customs in a day or two, but the valve controller probably looks a bit suspicious through the x-ray machine
