01-29-2021, 05:38 PM | #45 |
Rep 2,700
Just in the front
ABenLauda371.50 |
01-29-2021, 05:41 PM | #46 | |
///M Powered for Life
11510
Rep 10,342
Perhaps the difference is we don't have Ferraris, Lambos, McLarens, Aston Martins, Paganis, Bugattis owners on the BMW M forum all day every day whining nonstop about how inferior BMWs are. |
01-29-2021, 05:45 PM | #47 | |
11510
Rep 10,342
If you 'track a lot and are fast', OEM brakes are worthless. Apparently not only BMWs suffer this problem. I have an M3 CS. There is a hole in the splitter but it does not make it to the fender liner/wheel well. When a car gets a duct in the wheel well it has some kind of brake ducting. The last normal M model to get that was the E46M back in the stone age |
01-29-2021, 05:52 PM | #48 |
Rep 1,120
Sliding rear caliber on a $100-120K CAN performance car? What a disgrace.
SantaEugence479.00 |
01-29-2021, 08:47 PM | #49 |
Rep 2,181
01-29-2021, 08:49 PM | #50 | |
Rep 2,181
01-29-2021, 08:54 PM | #51 | ||
Rep 788
01-29-2021, 09:04 PM | #52 |
Rep 2,181
The last sliding caliper in an M3 tended to stick after heavy rain. The last electronic parking brake caliper was a bitch to change pads as it required the caliper pistons to be compressed by electronic message - the parking brake actuator.
So these calipers are the worst of both worlds to me. And ugly. |
KZEVO191.00 |
01-29-2021, 09:26 PM | #53 |
Rep 855
90% of the braking is done on the front of the car (where most of weight and inertia during braking matters).
Don't compare this to mid-engine or rear engine cars where actually rear braking setup matters more.. like P-car or Ferrari. Anyone that actually does a track day can tell by looking at the wear and tear of their braking setup.. the rear is marginally taxed at best. |
01-29-2021, 09:41 PM | #54 |
Rep 2,700
Not sure if it applies to BMW style rear caliper but I find it super easy to back up the rear calipers in my Q5 using any 12v battery. And with 150k+ km in harsh Canadian winters never had any problems doing regular maintenance.
clee1982797.50 |
01-29-2021, 09:52 PM | #55 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
As long as the front brakes can be swapped as easy as the F80 and one can set the rear brakes to "service mode" or be turned/compressed by myself with out the need is special electronics.
I already have the caliper tools to rotate and compress the caliper so fingers crossed
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
01-29-2021, 09:54 PM | #56 |
Rep 878
Drives: ///M2
Signal green is starting to grow on me
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
xlover2198.50 |
01-29-2021, 11:41 PM | #57 |
Rep 908
Drives: G20 M340ix; F30 328i msport
Both fixed and floating can work well if properly sized which I'm sure BMW engineers have done. However, having both front and rear brakes to fixed calipers provide a more consistent pressure application across the pad which equates to even pad wear and good pedal feel. Floating calipers are definitely more cost effective for BMW but are also easier and cheaper to maintain, low moving parts and can provide plenty of braking force. Pros and cons I guess
01-30-2021, 03:31 AM | #58 |
Rep 1,477
Drives: BMW M2
It's AMAZING how people issued verdicts about something they have never tried (and often not even seen live)
The brakes are small so the car doesn't brake (while they use the same solution on the heavier M5 F10/F90 and nobody complained), the gearbox is a ZF8 so it sucks, the car is heavy so the handling is poor, every reason is good to throw shit I'll be here waiting for you to buy the new M3/4 when your lease is over or your cars will have many miles |
01-30-2021, 05:41 AM | #59 | |
Rep 3,056
SMB M3 CS (gone) YMB F80 6MT (gone) |
01-30-2021, 06:33 AM | #60 |
General
21132
Rep 20,742
Drives: 2021 911 turbo
I am curious, how many G8X have you seen on the road thus far ?
frankiebones5300.00 |
01-30-2021, 06:37 AM | #61 | |
General
21132
Rep 20,742
01-30-2021, 06:40 AM | #62 | |
General
21132
Rep 20,742
The main brakes are still hydraulically actuated. What changed is the parking brake that is now electrically operated instead of a mechanical cable linkage.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-30-2021 at 06:50 AM.. |
01-30-2021, 06:42 AM | #63 |
General
21132
Rep 20,742
No.
ABenLauda371.50 |
01-30-2021, 06:44 AM | #64 |
General
21132
Rep 20,742
Not sure about that either. If the G8X calipers are like the F8X 6-pistons, you need to remove the calipers to swap the pads. With the F8X 4-piston front calipers, pads could be swapped by only pulling the two pins.
RedSectorA37.50 |
01-30-2021, 06:53 AM | #65 | |
Rep 396
SYT_Shadow11509.50 |
01-30-2021, 07:49 AM | #66 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
going forward, as in the future
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
