08-28-2022, 08:41 PM | #1 |
Rep 764
02 Sensor wires, which go where?
Strange questions, but I removed all the wires and dp's to quickly and forgot which set of black/grey wires goes to which dp's lol. Thinking the front two wires that are connected at the top of the motor closest to the bumper may both connect to the longer dp? or other way around? Tried searching for a diagram but couldn't find one. Also a little confused on how to route the wires, unfortunately my DP's were once out from last owner and they look to be incorrect and routed around the turbos. Any suggestions or help are more then welcome.
08-29-2022, 06:19 AM | #3 |
Rep 764
Thanks, all good on knowing the color and which connectors go where on the dp's themselves (grey wires go to the back of the cats and the black goes towards the fronts.). I'm wondering where they go on top of the motor.
08-29-2022, 07:15 AM | #4 |
Rep 374
08-29-2022, 08:20 AM | #5 |
Rep 764
10-30-2022, 11:39 PM | #6 | |
Rep 92
11-01-2022, 10:06 PM | #7 | ||
Rep 15
Please remember to reset/remove your Current and History Cel by disconnecting the battery while installing the cel fix, or longer, If not using a Scan Gauge. To prevent damage to the o2 sensor's wiring, always disconnect the sensor at the harness connection point , usually 12 to 17 inches from the sensor. DO NOT REMOVE SENSOR'S WITHOUT UNPLUGGING, AS TWISTING THE SENSORS WIRES WILL DAMAGE THE SENSOR... The mini cats require the supplied washer be installed onto the oxygen sensor with the original OEM oxygen sensor washer before screwing it into the mini cat cel fix, failure to do so will damage the mini cat cel fix. The oxygen sensor must have two washers, Insure your installer fully understands this must be done, |
