      08-05-2023, 07:47 PM   #1
evanescent03
evanescent03's Avatar
1033
Drives: '24 M3 CS; '22 GT4
Vaporized M3CS pad* (remove your brake duct covers!)
**Edit** seems like the biggest thing I could've done better is remove the brake duct covers. I just assumed the CS was set up front the factory ... oops.
So. Did a day of HPDE and blew through the stock pads (steel), damaged the rotors. Looks like I’ll need a new set of front rotors/pads. Rears look pretty good. Car otherwise drove great. Fast, stopped great, balanced. Track mode and aggressive settings except comfort chassis. Maybe the leftover nannies contributed to accelerated wear? Top speed ~150mph. About 90*F ambient temp in intermediate group at Summit Point Motorsports track, WV.
If you’re going to drive the the car hard, look at more robust pads. Great experience otherwise but sad to rip through pads so fast. It might be slightly on me because I also burned up pads (while damaging rotors) on 718 gt4, GR86, SS1LE.
Have fun out there! Now to find some replacements for the street.
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
      08-06-2023, 01:26 AM   #2
Gottagofast
Gottagofast's Avatar
394
Drives: 2023 M4 Comp X-Drive
Did remove the cooling duct covers?
      08-06-2023, 05:50 AM   #3
beamlord
Drives: 2023 m3c
Regardless of the event, this is unusual. There's two ways you can completely wear down your pads to bare metal (since you mentioned damage to rotors):
- you're driving at a gt4 level endurance race
- complete opposite, your braking/racing needs a lot of improvement
(Not to sound like an expert, my own braking is far from perfect and I am constantly working on that).
Or your pads were already half-way through? The wear accelerates exponentially due to reduced mass. Hence always better to use a separate fresh set of pads before each full-day event.
      08-06-2023, 08:45 AM   #4
forcefed
forcefed's Avatar
Drives: .
So you didn't learn anything from your previous 3 experiences?
Rotherd311177.50
Sp2pilot168.50
M4Tejas788.00
      08-06-2023, 04:31 PM   #5
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
What was the mileage on the pads before you started the day?
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      08-06-2023, 07:14 PM   #6
Needsdecaf
Needsdecaf's Avatar
6606
Drives: 2024 G80 Comp xDrive
Apex vaporized a set of pads in 10 taxi laps on the Ring. Switching to endless they got 100. They then added additional cooling and got over 170.
Change pads, open the ducts, add additional cooling.
s58544.00
      08-06-2023, 07:47 PM   #7
BMWRacer523
BMWRacer523's Avatar
2519
Drives: G80 M3 Competition xDrive
This doesn't track (pardon the pun). I'm quite familiar with SP Main and you shouldn't be destroying front brakes there, especially in the intermediate group. As someone else asked, did you remove the vent covers? How much pad depth did you have prior to the event? I've got about 4 track days on a set of OEM pads/rotors and they still have a couple days on them. I did need to replace the rear pads before the last event.
      08-06-2023, 09:04 PM   #8
evanescent03
1033
Thanks for the input guys!
Bottom line ... new car, new track, always lessons to be learned - the brake duct covers seems like something I definitely should've removed prior to the track day! I didn't do my due-diligence. hopefully someone can learn from my mistakes. I will say that there was ZERO fade at any point which would have triggered me to think something was going on with overheating. i've had nannies kick on with other cars and overheat breaks and inducing fade... made me investigate and turn stuff off. the 3CS was running so well i didn't suspect anything amiss.
Sure didn't. I didn't expect to do a whole weekend but figured i could get through a day "as-is" ... oops. I'm guessing the brake ducts would've helped a lot.
1 of 4 front pads was down to the metal (drivers side interior pad). the other 3 were down to about 3mm. rears are all about 4-5mm. i'm thinking the lack of opening ducts along with that front left being a hotter corner (as indicated by tire wear) was a vicious cycle in destroying the pads.
I'm definitely not a GT4 level guy. But i don't think i'm the complete opposite either. I too realize I have a lot to learn. Are you aware of certain braking styles that you think would cause this? I believe folks who drag the brakes and have an excessively long braking zone tend to inject more heat into the system. a compressed braking zone, afaik, actually helps reduce brake wear.
I've asked a ton of people at the track (drivers, race mechanics/"brake guys", etc) and have had a hard time pinning down the answer. And everyone I've talked to has been a lot more helpful than you, thankfully. thanks for the contribution
about 2,000 miles of normal street driving.
the ducts alone i'm guessing would've helped a lot, wish i would've RTFM on that one. ambient temps were ~90* but not 110* like I encountered at thunderhill in the past.
nailed the pun! vent covers are definitely the big thing I should've thought of. kinda crazy to think that would make such a big difference but honestly, it probably would've been super helpful. side note that i'm sure you're aware of .. if you're replacing the rears before the fronts, that probably means the nannies are kicking in and wearing them down, yeah? which settings are you running? I enjoyed SP! I haven't ever driven there although I did run Jefferson about 13 years ago. I was hitting 140s-150 at the end of the straight and i think my best time was 1:23.99 per Garmin. i'm not hot-shoe so it takes me a while to learn a new track. I'll be going there more often in the coming years because i'll be moving closer.
      08-07-2023, 01:52 AM   #9
SFVM3
Drives: E46 M3
Good rule of thumb, you should never start a track event with less than 6 mm and I check after day 1 of a 2 day event and swap as needed--I always have a new or 6 mm+ backup set going into a weekend.
If they make Ferodo DS 2500 or DS 1.11 for these cars they are a very reliable and effective pad with predictable wear in my experience--DS 1.11 are next level stopping power/initial bite even cold and last 2-3x as long.
M4Tejas788.00
      08-07-2023, 04:23 AM   #10
beamlord
Drives: 2023 m3c
While opening the brake ducts would definitely be better, I don't believe it would dramatically change the wear, maybe by 1-2 mm overall.
As for braking, I learned there is a WORLD of difference between a professional driver and amateurs in that. Someone mentioned here already, that Apex rental took 10 laps (Nordschleife, mind you, i.e. 200 Km) to wear down stock pads on their m3 - well, the guy who drove those laps is a professional driver who knows exactly how to minimize brake wear and optimize momentum and speed through corners.
I am certain that an amateur can destroy the pads in under 5 laps.
While braking style and errors are individual, some are quite common.
My own problem is that I often have to do corrective braking after initial braking before corner, because the initial braking was not enough i.e. I tried to keep more speed than necessary ("greedy"), and midcorner realize the entry was too fast. That is a very common mistake. Have gotten better at it recently.
Others include brake dragging as you mentioned.
      08-07-2023, 09:46 AM   #11
BMWRacer523
2519
This is more of a case of not timing the braking correctly. Very hard to do especially as you get faster. As Ross Bentley says, timing and release of brakes is what separates pros from the amateurs.
Hit_Apex2370.50
      08-07-2023, 09:51 AM   #12
BMWRacer523
2519
MDM 4wd Sport. So yeah some nannies are still on. Rears needed to be replaced after 6000 miles, 6 track days.
      08-07-2023, 10:12 AM   #13
beamlord
Drives: 2023 m3c
Well said, exactly my issue, I release brakes early, unconsciously afraid to lose too much speed (losing even more eventually, because of corrective braking).
      08-07-2023, 01:26 PM   #14
Jims M3
Drives: F95 X5M, F80 M3, C7 Z51
I noticed the brake ducts were blocked on the M4 from the factory when I installed my racing studs.
      08-07-2023, 03:10 PM   #15
CMW33
CMW33's Avatar
312
Doesn't stability control often contribute to increased brake pad wear since it uses wheel-specific braking?
      08-07-2023, 03:21 PM   #16
Needsdecaf
Needsdecaf's Avatar
6606
That would account for increased rear pad wear, yes.
      08-07-2023, 03:32 PM   #17
BEAR-AvHistory
Any idea why they are blocked from the factory?
Kevin
      08-07-2023, 04:18 PM   #18
Needsdecaf
Needsdecaf's Avatar
6606
To prevent debris from hitting the calipers and rotors when the cooling is not needed. Also for "approval-related" reasons. Which I would guess means they add drag, which changes the fuel economy rating.
