04-05-2022, 06:13 PM | #1 |
Rep 38
Having steering vibration issues since new
I received my 2022 M3 xdrive about a month ago and have been having steering vibrations from day one. The vibration are getting worse and it vibrates at all speeds, I also hear a droning sound as my speed increases. I'm hoping the dealer figures it out tomorrow. Since I've not driven any other M3, how do your cars act over bumps and driving in general? I have Michelin Pilot 4 tires by the way. Has anyone experienced anything like this?
04-05-2022, 10:47 PM | #3 |
Rep 388
Given that it is happening at all speeds (does it peak at any particular speed(s)?) and the drone, this sounds more like a halfshaft issue.
Let us know what the dealer says. Hope it gets fixed soon.
TJR
04-06-2022, 07:24 AM | #5 |
Rep 38
Just dropped it off at dealer. Took a short ride and the tech says all he feels is normal feedback. I was afraid of this but he did he will take it on the highway later. This is my 3rd M3, many other bmw's and never had a car vibrate like this. Will see what they say later. Does anyone get vibrations at a feedback on normal street roads?
04-06-2022, 11:20 AM | #8 |
Vault Dweller
704
Rep 577
it could be tires. unfortunately you cannot switch front to rear to see if it goes away due to the staggered setup, but definitely start with balancing and have them look for signs of uneven wear on the tires.
Current (delivered 20/10/21): 2021 G80 M3 6MT; Dravit/KO/ZPP; 826M; Sunroof (yes no CF)
(More Pictures) Previous: 2018 340ix 6MT Msport(Dec 17-Sep 21); 2013 335ix 6MT Msport (Nov 13-17); 2011 328i 6MT ZSP (Aug 10-Nov 13); 07 323i 6MT ZSP (May 07-Aug 10); 97 318ti MT ZSP (Feb 97-May 07) |
04-06-2022, 12:16 PM | #9 | |
Rep 388
What did the tech say about the droning noise you mentioned? Do you have all steering assists and warnings turned off - particularly the lane departure warning?
TJR
Joeg80m349.00 |
04-06-2022, 12:48 PM | #10 | ||
Rep 38
04-08-2022, 07:03 PM | #11 | |||
Rep 38
04-08-2022, 08:58 PM | #12 |
Rep 454
OP - Tell the dealer to perform a Road force balance and ask for a printout or picture of what each wheel balances at. Anything higher than 25 will result in vibration. Normally significant vibrations will be in the high 30's or higher. Also, the highest road force wheel/tire assemblies should be on the rear/non driver side.
Current: '23 Ford Raptor
Incoming: '24 G87 M2 - BG/6spd BMW Past Rides: 2023 G80 Comp, 2023 G80 xDrive, 2021 M3 Comp, 2020 M340i, 2019 540i, 2016 M4, 2016 535i, 2008 545i |
04-08-2022, 09:07 PM | #13 | |
Rep 38
04-08-2022, 09:22 PM | #14 | ||
Rep 454
I will tell you road force balancing 4 wheels and tires the right way, knocking off weights, checking road force and then breaking the bead and rotating the tire on the wheel assembly to match what the machine gives x4 times - is not in a tech's interest from a FRT standpoint so getting them to do it can sometimes be tough. If you get a readout or photo and all are in line and you're still experiencing vibrations you've either got a larger issue at hand or you're overly sensitive to it. Especially if you've verified all the lugs are torqued to spec as well after the balance.
BMWM5NYC496.00 |
04-29-2022, 04:26 PM | #15 | ||
Rep 69
Any resolution on the steering wheel vibration? |
04-21-2023, 02:31 AM | #16 |
Member
9
Rep 30
Drives: 1M AW, M4 MG, X3M40i DG
I’ve also been fighting with the dealership about a vibration that drives me nuts. On my case it only happens at high speed and not necessarily coming from the steering column but kind of a general vibration throughout the car. I had my wheel and tires balanced 2 twice with road force at 2 different shops it doesn’t cut it. Its still here.
Bmw shop foreman also testdrove the car and mentioned it was normal for the speed he drove it. At this points I think it’s probably a bad wheel. I plan on putting go pros at every tire to see if I can see the wheel vibrating laterally. |
04-21-2023, 08:47 AM | #18 |
Rep 531
Im lowered and running 20/21 wheels and its smooth as butter. I dont think this is notmal at all for you to be feeling the vibrations unless youre constantly crossing into lanes and your steering wheel vibrates whoch i doubt is the case here. Ive had an F80 before and my G80 is much smoother.
08-02-2023, 09:34 PM | #22 |
Rep 2,606
