03-30-2024, 06:24 AM | #1 |
Rep 1
BBS LM Can I lower?
I just recently put a set of BBS LMS 20x11+24 (rear) , 20x10+22 (front) with a set of Michelin Pilot Sport Cup 2R 295/30 in the rear and 285/30 in the front. Has anyone run a similar set up with a HAS lowering kit without any rubbing issues???
03-30-2024, 03:20 PM | #2 |
Rep 87
Drives: AW G80 6MT
Great thing about KW HAS is that it is adjustable and you are not stuck with a specified height like lowering springs. You can definitely go lower without having rubbing issues. BBS LM's look fantastic on the car by the way.
04-01-2024, 01:28 PM | #4 |
Rep 874
Here’s mine lowered on M Performance HAS. Max low in the front with 12mm spacers all around. I had to modified the fender liners so they wouldn’t rub on full lock in reverse.
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
04-02-2024, 12:31 AM | #6 |
Rep 531
Not aggressive offsets at all. You could probably bag it and put it on the ground and you wouldnt rub. All jokes aside. You wont rub if you lower it.
