10-06-2022, 09:04 PM | #1 |
Rep 148
Naturally aspirated power of the S58?
I know might be a stupid question, but for the sake of curiosity, what would be the peak power and torque of the S58 at sea level with no forced induction?
It's not straightforward to know, the engine is tuned for the forced induction so the stock map would produce lower numbers than it should, but say you remap the ECU to extract the max power. Since the engine has lower compression than NA engines, I would think the power might be around 250 whp or so. Just my guess, but maybe someone here may have a more educated guess. |
10-07-2022, 10:07 AM | #2 |
Rep 191,194
Since it's meant to run with turbos, checking power without it does not make sense, to be honest.
If your boost is 0, you can increase ignition timing by 10+ degrees, that's going to get you over 100 whp more power if you are running same ignition time but zero boost, i expect ~200 HP
10-07-2022, 01:17 PM | #3 | |
Rep 148
Thanks for replying. |
10-07-2022, 10:23 PM | #5 |
Rep 5,025
I concur. Pistons are made for boost so it probably makes around 200ish hp NA.
10-08-2022, 05:01 AM | #6 |
1411
Rep 1,174
I know nothing about any of this.
Can anyone point me to a good resource where I can learn about engines, turbos, boost, etc. Not trying to become a walking manual, but just to understand the basics and be able to follow a conversation. I have a basic understanding of vehicles, but the last time I was taught anything was when almost all cars had carburetors (I know you can have both, but it doesn’t seem very common). Any good resources out there? |
10-08-2022, 07:42 AM | #7 |
6920
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Gotta be half at most. It's pushing almost 200hp/l. NA engines outside of Ferrari make 100hp/l at most and that is when they are optimized for their purpose.
10-08-2022, 10:28 AM | #8 | |
Rep 191,194
10-09-2022, 02:39 AM | #9 |
1411
Rep 1,174
10-10-2022, 10:50 AM | #10 | |
Rep 5,025
See a good video below
bri10426082.50 |
10-10-2022, 11:00 AM | #11 |
Rep 110
One thing that had always confused me is why the compression needs to be lowered on an FI motor? If the compression is higher, then wouldn't less boost be needed to achieve the same power output? Like for example the S58 has a lower compression than the B58 so the turbos need to produce more PSI to achieve the same power as the B58, which needs less PSI.
So why not just keep the compression higher and have less boost? I know I am missing some key factor here, maybe someone can enlighten me. |
10-10-2022, 11:49 AM | #12 | |
Rep 3,315
10-10-2022, 12:58 PM | #13 |
Rep 110
10-11-2022, 11:05 AM | #14 | |
Rep 5,025
10-11-2022, 05:25 PM | #15 |
Rep 609
Another thing which is counter-intuitive is running leaner improves performance. You would think rich = more gas, = more power. Not so. Of course, there is a line that you can't go over without potentially burning holes in valves. But canned tunes for GM 8s always leaned things up, as the factory ran pig rich just to protect the engine. Of course, altitude (atmospheric pressure) comes into it, as well as compression and fuel octane.
10-30-2022, 10:43 AM | #16 |
Rep 1,435
It's gotta be quite low, I'd think somewhere in the mid-upper 100 whp range.
Not an S58, but I have driven my tuned M57 diesel 335d without the small turbo before, due to a vacuum leak. My specific leak prevented the bypass valve leading to the big turbo from closing, thus the small turbo could never spool. It was hilarious. From a stop it was probably the slowest car I've ever driven--we're talking 10+ seconds to get to ~15mph with the pedal on the floor. Right around then, the big turbo spooled, it melted the rear tires and took off. |
