05-09-2024, 08:56 AM | #1 |
Rep 942
M4 CSL | Moton 2 Way Suspension w/Remote reservoirs installed | Review
Re: M4 CSL | Moton 2 Way Suspension w/Remote reservoirs installed
I'll start by saying, I'm overly excited & satisfied with the new suspension setup. I've driven approx 1000KM on them to date Smooth & bumpy roads | HWY Speeds | Low speeds etc. They are flawless - I enjoy my rides tight & firm. Your able to dial in this suspension as you like 15 bumps of adjustment on rebound & compression at your finger tips. Ordering: I placed my order with PSI (Precision Sport Industries) They were amazing PSI's knowledge, service, and follow up during the ordering/shipment process was incredible. I would highly recommend. MOTON's The quality of materials used is amazing. It's no surprise why MOTON is the leader in the business. Remote reservoirs that look amazing and make adjustments very simple | Quick release lines on the front 15 positions of adjustments for Rebound & 15 positions for compression. Top mounts included I did choose to retain the individual OEM STYLE / Rear setup Strut is separate from spring in the rear. Not a true coil over design. This car will primarily be driven on the streets - improved comfort in this format. Install Install process was seamless - MOTON provides everything needed. External cannisters mounting position is trial & error I did a bunch of test fits prior to install Really happy with the final outcome. Ride Quality: AMAZING! I like a nice tight/frim ride. Rebound & compression adjustments take 0.1 seconds to adjust. The adjustments points are very accessible & changes can be made/felt immediately. I made slight adjustments to ride stiffness. I will be lowering the front 1-2 turns this week since it's now settled. Alignment will be done in the next 1-2 weeks. I am really happy with the setup.
Alpine White M4 CSL
Instagram: YASPLZ_CSL |
05-09-2024, 11:57 AM | #2 |
Rep 636
They do look amazing and Moton's reputation speaks for itself. I know it's dependent on individual setup, but how are they for daily usability? Is there a stock setting (i.e. sport, sport+) that can compare from a firmness perspective?
YasPlz_CSL2458.50 |
05-09-2024, 01:02 PM | #4 |
Rep 34
Drives: 2018 M4 ZCP
How do these compare to AST, MCS, or Nitron?
05-10-2024, 09:31 AM | #5 | |
Rep 942
You can really adjust the ride as firm or soft as you'd like. The CSL from factory rides quite stiff - this can be replicated or dialed down based on your personal choices. 15 clicks of adjustment for both rebound and compression. The biggest thing I forgot to mention - These have the capability to go really low if your into that appearance - My rear height for example is set to nearly its highest setting with plenty of room to go lower if desired
Alpine White M4 CSL
05-10-2024, 09:36 AM | #7 |
Rep 942
AST is MOTON
AST is MOTON
AST acquired MOTON years ago I have never dealt with Nitron/MCS My experience with these MOTONs has been amazing. I would never deviate from their brand (AST/MOTON) after experiencing this quality.
Alpine White M4 CSL
somer973.50 |
05-10-2024, 12:21 PM | #8 | |
Rep 636
I'm mostly interested in case the stock shocks give up the ghost at some point and would then move to coilovers most likely!
YasPlz_CSL2458.50 |
05-20-2024, 08:11 PM | #9 |
Rep 203
No clearance issues with the hood with the way you have the remote reservoirs mounted?
YasPlz_CSL2458.50 |
Today, 02:32 AM | #10 |
Rep 720
I was wondering the same thing.
YasPlz_CSL2458.50 |
Today, 07:13 AM | #11 |
Rep 942
No issues
No issues in that exact spot - Move them up or down 1cm each way and it will rub.. Several test fits completed prior to install to ensure they would fit in that spot
Alpine White M4 CSL
