03-08-2023, 08:03 AM | #23 |
Track Rat
1760
Rep 403
I have bad news for you Roger. The new M2 uses the very same brakes as the M3 & M4. Also the same trans. & suspension. It's pretty much the same car in a very slightly smaller, and not nearly as good looking package.
jmg18741.50 |
03-08-2023, 08:10 AM | #24 | |
Rep 6,760
The only problem with the G8x brakes is that they don’t fit over 18” wheels at the front, so your choice of track tires may be a bit limited.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
03-08-2023, 08:12 AM | #25 |
Rep 6,760
Let’s leave the looks accolade for the G80/82 out of the conversation.
03-08-2023, 09:44 AM | #26 |
General
21121
Rep 20,741
Drives: 2021 911 turbo
And that you need a laptop to change the rear pads track side
jmg18741.50 |
03-08-2023, 09:57 AM | #27 | ||
Rep 14,118
Drives: G82 M4C X-Drive
Great video/article!
What they didn't mention was that to get 33° operating temp, you have to start at around 28° in the pits, then adjust after your warm up laps, depending on the track conditions. I like that they talk about cool down laps–use the brakes as little as possible, cool the tires and brakes down before heading to the pit. I've had my wheel weights pop off from the heat, so I use aluminum tape to secure them for track days. It's more a courtesy to others so they don't get flying pieces of metal embedded on their new GT3s. One thing that annoys me about "TRACK MODE". While it does disable the collision detection nannies, it does not disable it during hard braking. I've gone into hot corners and had my windows close by themselves when braking hard with a car in front of me. I've also had the windows close automatically when I've spun out. Ironically, at least in the US, we have to run windows down for easy extraction in case of an accident. The G8X just does away with that. If they would allow it, I would just run windows down and reduce the drag! WISH LIST: Permanently exposed rear tow hook - I had this on my factory Audi S4 25Quattro, which I didn't even track. Constantly removing the tow hook cover has made mine a little loose and I fear it will get worse. Overall the G8X is a great "arrive and drive" track car. Brake pads, fluid, camber, and you are good for almost any HPDE. Competitive racing and time attack is another story. Quote:
I've tracked with factory pads and they are decent, but it takes brake management ie cool down laps, to keep pad temps from getting too high. The F80 made swapping to track pads very easy. Wheels off, pop pins, and swap. I had it down to a leisurely 20-30 minute swap for all four corners with a single jack. I really hate how the current G8X calipers have to be removed to swap pads. A step backwards in this regard IMHO. My theory is that the additional caliper material helps keep brake temps down, and the G8X being heavier than the F80, so it might need it. Same brakes, similar weight (3800 vs 3900), same laws of physics. Swapping will be equally annoying. CanAutM3 tracked his F82 M4CS quite a bit before he moved onto a 911! Corded my tires after 2 track days without camber plates. I'm running -3.2 in the fronts now. I ran -3.0 in my F80 M3 CS. The G8X seems to want more.
03-08-2023, 10:00 AM | #28 |
Rep 14,118
Fortunately, you can do this on your phone with BimmerLink. Still a step backwards.
CanAutM321121.00 |
03-08-2023, 01:13 PM | #29 |
General
21121
Rep 20,741
I’ve owned multiple ///M cars over 20 years that I’ve all taken to the track quite regularly. If you look at my post count and rep points, you’ll see I’ve been a long time active member of the community, and I continue to be because I am still passionate about the brand, despite having recently jumped ship .
PLF693767.50 herbnlegend50.00 |
03-08-2023, 01:14 PM | #30 |
General
21121
Rep 20,741
Good to know there exists a less annoying solution
jmg18741.50 |
03-08-2023, 02:09 PM | #31 | |
Rep 643
In fb G8x track car group, Paul found the fuse to disable that, But I’m too lazy to that. I also feel like If you trigger ABS before the corner, your are coming in too hot, these cars are very easy to understeer.
2021 M4 Competition
2020 M340i |
03-08-2023, 02:57 PM | #32 | |
Rep 14,118
03-08-2023, 05:03 PM | #34 |
Rep 121
I mean the oem wheels on the base G8x are 18" front wheels
03-08-2023, 06:17 PM | #36 |
General
21121
Rep 20,741
In the video they say it is mainly to deflect water.
03-09-2023, 04:07 AM | #37 |
Rep 2,700
Even easier with a small 9V battery
PS: CanAutM3 I finally registered for a BMW Auto Club event (the first one)
03-09-2023, 09:18 AM | #38 |
General
21121
Rep 20,741
Great! Looking forward to seeing you there (and the car )
PLF693767.50 |
03-09-2023, 11:24 AM | #39 |
Rep 1,425
Should be able to do it with a Scan tool also. I don't yet have my G80 (and my E90 obviously has a mechanical parking brake), but I've used my Foxwell NT530 to retract the EPB on my wife's Audi when I did her brakes last year. I assume it will be the same for BMW.
03-09-2023, 01:28 PM | #40 |
Rep 14,118
Cool down laps every 3 to 4 hot laps makes it manageable at Streets Of Willow. Faster tracks like VIR will require more management. The first thing we do is swap pads and get race fluid.
edwinm3980.00 |
03-09-2023, 01:31 PM | #41 | |
Rep 14,118
If you are on track pads but drive on the street, you simply don't need them to be open. One might argue that you want them closed to keep as much heat on the track pads as possible on the street. Track pads usually aren't that great cold.
03-09-2023, 02:35 PM | #42 | |
Occasionally frequent poster
3003
Rep 2,745
No, wait, that's not right. It really depends on the track too, and arguably how you drive. I can be very fast through most of VIR but I just don't try to beat the land speed record on the straights. Slowing down from 125 instead of 140 can be the difference between the pads surviving a session or not. And you don't learn a whole lot in those extra 15 MPH, nor for me anyway, do I get any enjoyment out of it other than bragging rights. And there's always someone faster.
Current inventory:
03-11-2023, 08:31 PM | #43 |
Rep 470
