12-06-2022, 12:23 PM | #551 |
Rep 502
That was such a great deal (now they are all out of stock) and I am kicking myself for not buying a set since my G87 won't be here until April and I won't be needing my winter setup until next fall. I should have just bought and stored them for next year
BMW CCA Member ID: 592739
biglilsteve1189.50 |
12-06-2022, 12:27 PM | #552 | |
Rep 163
Yeah, the reason I got my setup was, one, the price, I really didn't want to spend a ton of money on the winter setup. I saved money on the 245's and the wheels are really nice, not cheap looking but without breaking the bank. Second, the comment about rubbing, so, I really didnt want to mess around. And, again, its winter - snow and crap, so no big deal for me, anyway. |
12-06-2022, 01:41 PM | #553 | |
Master Chief
1190
Rep 938
12-09-2022, 10:54 AM | #554 |
Rep 502
They are available again, I just ordered them! Hopefully mine will also come with the 2020 manufacturing date...
12-09-2022, 05:28 PM | #555 | |
Master Chief
1190
Rep 938
moodyhank82587.50 |
12-10-2022, 08:09 AM | #556 |
Rep 436
Check Costco, I went with a square 275/35/19 all around set up from them
Dinan Stage 3/Cobb FMIC/ER Sport Oil Cooler/CPE Catted DP/BMS DCI/Eisenman Race/Koni Yellow F + Dinan R/Dinan Springs/UUC F + R Sways/M3 subframe bushings/OEM 313 Wheels/M3 steering wheel
12-11-2022, 07:14 PM | #557 |
Rep 308
Drives: ‘23 M3 Comp xDrive
My Winter Setup
Not sure if this will help anyone out but I was in a bind to get a winter setup going here in MN last minute. I didn’t want to spend a bunch of money so here is what I ended up going with. The fitment is good but I don’t think I’ll be winning any awards for the stance. I know it looks super weak and I’ll be playing around with spacers in the years to come.
Car: M3 Comp xDrive Dravit/Silverstone Setup: Squared Wheels: VMR 801 19x9.5 ET35 (ET22 not available at the time) Color: Anthracite (Bronze was a 4-5 week wait) Tires: Blizzak LM-32 275/35R19 Spacers: Macht Schnell - 12mm all around TPMS: TPMS.RDE077 from RG Sport Center Caps: OEM caps from dealer All in was ~$2000 and I think it’s pretty decent for a winter setup. If I had more time, I would have ordered the satin bronze finish with more offset but I’m happy with the performance and that’s what matters to me in the winter over the looks. I hope this helps someone looking for a winter setup! As you can see from the pictures, I had a little too much fun today in the snow |
12-11-2022, 07:24 PM | #558 | |
Master Chief
1190
Rep 938
I also picked up a set of VMRs (V710FF 19x9.5 ET22) during Black Friday. $275 a piece was too hard to pass up! Car is at port and hopefully makes its way here sometime in the next month. |
moodyhank82587.50 Llarry16060.00 |
12-11-2022, 09:30 PM | #559 | |
Rep 502
12-11-2022, 10:31 PM | #560 |
Rep 308
I’ve had 3 sets of Blizzaks now and they are my favorite winter tire. The only other winter tire I’ve run is the Michelin X-Ice so I don’t have much to compare it to but I prefer it over those. I did get the close out 2018s but I haven’t noticed any issues so far (I’ll update if I do). Your 710s look awesome BTW! I was cross shopping those as well and I’m curious how you got the 50th anniversary caps to fit. My dealer only had the smaller caps for that style but maybe your 710s match up with the smaller center bore?
biglilsteve1189.50 moodyhank82587.50 |
12-12-2022, 03:24 AM | #561 | |
Master Chief
1190
Rep 938
12-12-2022, 01:57 PM | #562 | |
Rep 14
I am supposed to take delivery of my new M3 later this month, which is much earlier than I originally anticipated so now I have to find a winter setup. I really like this package and had a few questions: - Have you driven this in the snow yet and if so, how did it handle? - How long did it take to receive the wheels after you ordered them (I am located in CT for reference) |
12-12-2022, 07:58 PM | #563 | |
Rep 163
So, when I ordered the wheels/tire package, the retailer informed me that they had received alot of orders due to a recent snow storm and it was that time that people were buying these wheel/tire packages. But they informed, that I would get the package within 10 days, and I did. The wheels/tires were all properly packaged and protected. The wheels were ready to be mounted and the only change I had to make was to reduce the tire pressure in the tires from 40 psi to the factory values. |
12-16-2022, 05:47 AM | #564 |
Rep 308
Quick update on my setup…
I was noticing some slight road vibration on highway cruising along with a lot of pull one way or another. It was a windy day and it felt like I was driving my wife’s jeep. I took it into my dealer and they found out that the alignment was off. Unfortunately, because this is an aftermarket setup, they told me I voided my alignment warranty (this lasts 5000 miles I guess). The good news is that they said they can realign it for me for about $350. They assured me that I wouldn’t have to get an alignment done every time I swap from summer to winter tires but I don’t know enough about these cars yet to understand how that’s possible. I have a few questions that I could use help understanding: Can they actually do a realignment that will work for both the OEM summer setup and my aftermarket winter setup? When you mount/balance a new set of wheels/tires, shouldn’t you check the alignment before giving it back to the customer? The more I’m sitting here thinking about it, the less sense it makes in my head and it’s causing me to lose trust in my dealer. Any help here would be greatly appreciated |
12-18-2022, 05:43 PM | #565 |
Rep 647
How is it still so hard to find a wheel/tire combo that comes mounted with TPMS? TireRack still only has 3 available wheels and they claim they can't mount/balance them because they don't have the TPMS yet....which is weird. The TPMS on my winter set for my M340 works on the G80. Fitment looks derpy though.
The only complete set I can find is the OEM 829M on getbmwparts, but while those look good, they are cast. That makes me a bit nervous for a winter set. Are all of you guys who assembled your sets just not running TPMS or did you buy those separately and then pay a shop a few hundred to assemble and balance?
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i |
12-19-2022, 08:24 AM | #566 | |
Rep 1,929
Most likely you new wheel setup isn't balanced properly.
12-19-2022, 08:36 AM | #567 | |
Rep 308
Overall I’m just confused and don’t really trust my local dealer anymore. I’ll have to research some more shops in my area but it’s just disappointing so far. |
12-19-2022, 08:46 AM | #568 | |
Master Chief
1190
Rep 938
Just find a set of wheels with appropriate specs: 19x9.5 5x112 Offset around ET20 +/- 5mm or so 66.6 hub bore Flow formed or better Find tires in 275/35/19. Buy TPMS - either OEM BMW or a set from TPMS d0t c0m. Bonus points: get BMW center caps for wheels Have a shop mount/balance them, which should be not much more than $100 total. It’s really that simple. |
12-19-2022, 08:56 AM | #569 | |
Rep 1,929
As for the alignment changing it could be as simple as hitting a pothole and one of the nuts on the suspension not being tight enough or the dealer just saying it's off or some newbie at the dealer not knowing how to set up the machine properly.
12-19-2022, 02:21 PM | #570 |
Rep 308
So I just picked the car back up after sending it back for investigation into the steering wheel vibrations and pulls on the highway. Attached is the dealer documentation.
The original reason for the visit was a ceramic coat and they also recommend that they do the break in service at ~760 miles. They also looked into the wheel issue and ended up doing a rebalance and alignment. Based on the paperwork I got back, I’m even more confused. It looks like they had to rebalance because the original balance was off? Is this how the alignment got off? Why am I paying for this out of pocket? Why are there notes on the alignment asking for the summer setup? I was told that I just had to pay this and all was perfect on the car going forward. Overall, not a great experience so far, but at least I have an 84 month warranty on the interior leather and exterior ceramic coat! |
12-19-2022, 03:04 PM | #571 | |
Rep 647
Spent a few hours searching and ended up getting the 826M (black) 19's from getbmwparts and a set of Vredestein Wintrac Pro's from tirerack. TPMS from tpms dot com. All in was just under $4k, but glad I'll have OEM wheels that are forged. The Vredestein's really get great reviews and are competitively priced. Not sure why the 826M bi-colors are $300 more per wheel than the black.
12-19-2022, 03:16 PM | #572 | |
Master Chief
1190
Rep 938
