07-07-2023, 12:27 PM | #177 |
Rep 235
I ended up going off the AliExpress full heatsink kit from icedriver. From this tread, it seems like this store is the primary supplier for other yellow DRL vendors.
Took about 1 week for shipping with a super easy install IF you take of the wheels and use a ratcheting wrench with a T20 bit on the outer lights (behind fender liner). Also you might have to get some double sided thermal tape as when I received the kit, the smaller boards fell of the heatsinks. Easy fix and a couple bucks off Amazon. BMW M3 M4 CSL 4 series DRL RGBW multicolor LED boards G80 G22 G82 G23 G26 daytime running lights Lemon Yellow Red https://a.aliexpress.com/_mKAzOdK
2023 G80 MT / AW / Fjord Blue/Black | KW HAS | Apex VS5RS F:20x10+8 285/30-20 R:20x11+18 305/30-20 | Maxton Street Pro Splitter | OEM M3CS Grille | SST Valve Controller | CS Style Yellow DRL | MAD Non-Res Single Midpipe
Past: 2018 X3 M40i | 2016 M-Sport X1 | 2013 MT M-Sport 328i | 2021 Audi A6 Allroad |
tatarwj390.00 J_Supplanter59.50 |
07-20-2023, 03:00 AM | #178 |
Rep 49
Ordered from IceDriver and installed the yellow DRLs today. No issue with the boards being loose or light quality, however one thing that slightly bothered me was the top modules being both right sides. The boards were swapped to have it accommodate its respective headlight but the fins are both facing the same way instead of being one for left and one for right. I originally thought it was going to make contact with the hood upon closing it but everything is fine. IceDriver has no comment about the modules being both the same for the top.
Note: if you inspect Ice Driver’s product picture you can see both modules saying ‘R’ meaning right side. |
07-23-2023, 12:00 AM | #179 | |
Rep 235
Unimatrix074.00 |
07-26-2023, 06:18 PM | #180 |
Rep 68
I also ordered from IceDriver and half way during installation I noticed that my driver side DRLs stopped working.
They do turn on but they only stay on for a second... Almost like the car is trying to send power to the DRLs but does not. I tried putting in the top OEM DRL and no dice either. Anyone have any ideas? |
07-27-2023, 07:13 AM | #181 |
Rep 68
I swapped the bottom left module with OEM and the DRLs started working again. I can only imagine that the bottom left module IceDriver sent was a dud. It did turn on but you could tell the car did not like it since it turned off once the car knew something was up.
I like to look on the bright side of things and say that I now have an extra set of heatsinks for when I buy them from IND. Why IND? So I don't have to deal with someone across the world who can just decide to ghost me or tell me to spend $50 to send something back. A pic of alternating DRLs when I was testing the modules out in case anyone was wondering what it would look like.... |
Bostro532.50 |
07-27-2023, 01:47 PM | #182 | |
Rep 194
07-27-2023, 04:45 PM | #183 |
Rep 1
Drives: BMW G82 M4 Comp.
I received the kits from icedriver. Cost me $128 in total 2 weeks ago. But one chip felt off during the transportation. I thought it was missing LOL, so I contacted the seller, got an instant response and send me a new one through FEDEX.
07-27-2023, 04:53 PM | #184 |
Rep 31
For M440i none laser headlight
Is there any luck for us who doesn't have the laser headlight to potentially swap off the DRL LED to yellow? Is there a preferred vendor to order this mod? Anyone had bad experience with the mod sold by AliExpress?
07-28-2023, 11:22 AM | #186 |
Rep 262
There are laser and non laser kits. Icedriver, as well as other more expensive vendors sell both.
08-01-2023, 08:14 AM | #189 |
Rep 530
08-01-2023, 08:31 AM | #190 |
Rep 405
08-01-2023, 08:58 AM | #191 | |
Rep 530
Simplest method would be to use a Dremel to cut a slot in them to use a flathead, but I haven't tried this. |
08-01-2023, 09:02 AM | #192 | |
Rep 405
As they’ve obviously been coded to be just white whilst only DRL’s are on. Also how close do you think the aftermarket DRL’s are compared to OEM CS/CSL DRLS? |
08-01-2023, 09:32 AM | #193 | |
Rep 530
I doubt regular DRLs will work in a CS/CSL because of the wiring for the extra functionality of having a 3rd diode for yellow. Because of the security screws I have not investigated further to see if this theory is correct however. I have heard of people having their car coded to US/ROW spec to have yellow all of the time, but a software update would most likely revert this and may cause issues with part of the car being the wrong region. It could also potentially void your warranty like any software changes. |
08-01-2023, 05:50 PM | #195 | |
Rep 405
Also, would this coding flag when you go for a service at BMW? I.E I know you get flagged when you tune, they get an automatic notification saying “potential tune”. Is the likely hood of warranty being voided by coding the same risk as using something like Bimmer code? |
08-02-2023, 05:40 AM | #196 | |
Rep 530
Any software changes, be that ECU tune or coding of any kind may flag up when the car is plugged in to BMW diagnostics. I haven't heard of it happening, but in theory any software not supplied by BMW is against your warranty. |
08-02-2023, 05:44 AM | #197 | |
Rep 405
I’ve got a pair here and I’m considering doing the top module under the bonnet and testing it out. So essentially if that works, the modules near the wheels should work? |
08-03-2023, 10:02 AM | #198 |
Rep 405
So I managed to get the screw off without damaging the head… used a ply and it came off quite nicely and easily.
Plugged the after market modules in and they work!! The colour is pretty identical… however the aftermarket modules are not as bright. Id says 10/15% less light. I also saw that the original CS module has three diodes for light, whereas the aftermarket only has 2. That’s for the module on the bonnet. Stuck with the OEM modules as they’re in my opinion much brighter. Was thinking, is there anyway to turn up the brightness on the modules? Or is it already set at 100%? |
