      04-23-2022, 01:44 PM   #177
mattssi
Drives: 2019 X3
I guess I wasn’t crazy, the noise is still there. It’s not as bad as before but if I hit a good dip, or two in a row, I get the squeak. It is really annoying.
Today I was just turning left into a parking space and it was slightly uneven. Got two squeaks out of it. I then drove around the lot when I left and got it to happen again when not turning (to rule out rubbing the fins).
I have the bottom-up measurement so not sure when to place the isolators this time around.
      04-23-2022, 02:06 PM   #178
mattssi
Drives: 2019 X3
I jacked the car and noticed a rub mark on the powder coat about a 1/4 turn above the isolator, so I rotated it up a 1/4 turn and will give it a try.
      04-24-2022, 10:24 AM   #179
mattssi
Drives: 2019 X3
Well that didn’t work. I’m tired of these things already…
I’ll try another adjustment and see if it helps.
      04-24-2022, 10:32 AM   #180
JDUNITNOW
JDUNITNOW's Avatar
Drives: BMW 335I, 750li, X5 G80
Ate you considering switching to something else? I know you have invested time and money in your current setup .
Formerly Wyndi335I
2009 BMW 750li sold
14 BMW X5
04 BMW X5
11 BMW 335i convertible (sold, sellers market
      04-24-2022, 10:42 AM   #181
DS_BMW
DS_BMW's Avatar
Drives: 2022 M4 comp, 22 M240
How are your isolators compared to the pics I posted?
      04-24-2022, 01:52 PM   #182
mattssi
Drives: 2019 X3
Considering it, but not quite worth it yet. I'll see if I can dial it in a bit still.
2021 ///M3
2019 X3
JDUNITNOW3995.50
      04-24-2022, 01:55 PM   #183
mattssi
Drives: 2019 X3
They were nearly identical. I've since rotated it up about 1/4 rotation, but that didn't fix, so I moved it back a bit, so now maybe 1/8 of a rotation from your spot. We'll see how it does...
I really don't understand how its just the passenger side, that alone doesn't make much sense to me.
Is your photo the driver or passenger side?
2021 ///M3
2019 X3
      04-24-2022, 05:22 PM   #184
DS_BMW
DS_BMW's Avatar
It's the driver's side in Pics.
mattssi927.50
      04-24-2022, 08:04 PM   #185
mattssi
Drives: 2019 X3
I went ahead and did the passenger side spring again. I noticed the dust boot wasn't sitting flush all the way around the top of the spring. Anything is a culprit at this point, so I was meticulous about the spring seating when I placed it back in and jacked it up. It is seated like it should be this time.
I then, moved the isolator back to the 40.25" or whatever from the bottom, took it for a test drive and so far so good. Just need time to see if it creeps back or not. Every time I think I'm good, I haven't been - but I have a better feeling this time around.
Crossing fingers! Thanks DS_BMW.
2021 ///M3
2019 X3
DS_BMW1712.00
      04-26-2022, 02:37 AM   #186
DS_BMW
DS_BMW's Avatar
Did you get the noise under control?
      04-26-2022, 08:18 PM   #187
mattssi
Drives: 2019 X3
Haven't taken the thing out since the test ride. Likely will tomorrow though and will report back.
2021 ///M3
2019 X3
      04-29-2022, 10:26 PM   #188
mattssi
Drives: 2019 X3
Quick ride today and so far so good.
JTO245740.00
Limegrntaln14179.00
      05-04-2022, 05:40 PM   #189
abdulisraddd
abdulisraddd's Avatar
Drives: 2025 G82 X IOMG
Mines still creaking!!
      05-04-2022, 05:41 PM   #190
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
If this was installed by us, please contact me to get this handled - I have additional isolator kits in stock.
      05-04-2022, 05:42 PM   #191
mattssi
Drives: 2019 X3
Did you install or a shop? Not saying mine are perfect yet without more testing, but I def had a rubber boot at the top of the spring that was not seated properly. It was sort of folding a bit so the spring was touching the mounting area directly in one spot.
      05-04-2022, 05:54 PM   #192
abdulisraddd
I'll check it out! I had Ben from RG do the install. He measured everything on the dot. Thanks
Limegrntaln14179.00
      05-04-2022, 05:57 PM   #193
mattssi
Drives: 2019 X3
He’ll take care of you. New isolators won’t do anything but I’m sure it will be resolved. I had the DIY factor
Mcc420483.50
      05-14-2022, 11:19 AM   #194
mattssi
Drives: 2019 X3
I went to the dealer yesterday to make an appointment and they have those rubber speed bumps. I went over it at maybe 3-4 mph specifically to see if the squeak came back.
What I heard sounded like a combination of the squeak, but with the crunch of those plastic vanes underneath the car. Sounded horrible, but I'm not sure if the noise was really there.
At this point it's like I have PTSD. On certain dips in the road or bumps its like I get tense and expect a noise lol.
On a related note, if you hit an aggressive speed bump - is there "natural noise" (like a hiss-type sound) expected to come from the strut/spring under sudden compression or should it be 100% silent?
Secondly - I'm surprised how those vanes really get in the way on speedbumps. Even going at nearly 0 mph. I guess that's just the life of a lowered ride.
Thanks for listening!
2021 ///M3
2019 X3
      08-15-2022, 08:39 PM   #195
bgexpress
bgexpress's Avatar
353
Drives: LSB E46 M3
Writing here instead of making a whole thread about it but I have finally had enough of my ast springs - I'm going back to stock for now. I installed the isolator fix. The noise went from the left side to the right side of the car, continuously got worse and louder after coming and going every few days. Having them removed tomorrow.
1000$ later after install costs and springs costs - really disappointed to say the least.
JDUNITNOW3995.50
DoubleDave1209.00
      08-16-2022, 08:40 AM   #196
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
I got rid of my AST's as well. They ended up making so much noise even with the isolators in the correct spot. Switched to H&R and they've been perfect.
      08-16-2022, 01:50 PM   #197
JTO24
JTO24's Avatar
Drives: 2022 G80 M3 6MT
I'm sorry to hear folks are still having issues even after the fix... *knock wood* ever since I adjusted the position of my passenger side rubber isolator I've had zero noise.
Current: 2025 G80 M3 | Boston Green | Tartufo
Former: 2022 G80 M3 6MT SG | KO, 2018 F87 M2 6MT | AW, 2016 981 Cayman 6MT | JB, 2015 F80 M3 DCT | TZB | GB, 2013 E92 M3 6MT | MW | FRB
      08-16-2022, 06:03 PM   #198
DoubleDave
Drives: 2022 M3 6MT
I had my AST springs removed about 2 weeks ago and it was the right decision. I went with stock rear springs and Eibach front and the car has been great for two weeks and a few hundred miles.
So far so good.
Tags
ast, creaking, g80 m3, suspension issue
