BMW David
      07-04-2025, 04:19 AM   #155
John @ BSPK
John @ BSPK's Avatar
2423
Drives: 2023 G80 6MT
Another Millie. This time in brushed gunmetal satin, going on a Brooklyn Grey G80. We intentionally went a little darker than usual for brushed gunmetal to contrast against BG. Should be beautiful setup. Just the right amount of contrast IMHO.
Millie | Brushed Gunmetal Satin (Darker) | 19x10 / 20x11 | Flush Fitment | Custom Drilled for OEM Caps |
View post on imgur.com
somer1458.00
Jodedor334.00
MLife6141391.00
      07-05-2025, 06:06 PM   #156
Otto Bon Jovi
Licensed Professional Slacker
Otto Bon Jovi's Avatar
3040
Drives: 2026 M4, 2025 i4 M50
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
That gunmetal is sure purdy 👍😁
The Dunning-Kruger effect - Stupid people are too stupid to realize how stupid they are.
KB7290.00
      07-05-2025, 10:48 PM   #157
DeezBluBallz
DeezBluBallz's Avatar
Drives: F80 M3, G80 M3
Originally Posted by John @ BSPK View Post
It’s RWD only given the xdrive tire diameter requirements.
That said there is an xdrive compatible setup that would be a 18” front and 19” rear and 305/325 tires that would work. The 305 front requires a little camber finesse to fit well though. You can also do a 275/325 setup that would work with multiple diameters.
The default setup (and I mean default because it’s like 99% of setups for xdrive) is 285/295 but there’s more that’s possible if you’re looking to push the boundaries a bit.
I’d be happy to run through in more detail over DM. Thanks!
Pm sent
      07-08-2025, 09:11 AM   #158
00dyb58
Drives: 2022 BMW M340i
Any photos of Anika White Gold on a BG G80?
      07-08-2025, 11:14 AM   #159
JTO24
JTO24's Avatar
6898
Drives: 2025 G80 M3 6MT
#savesilverwheels
Current: 2025 G80 M3 6MT | Boston Green | Tartufo
Former: 2022 G80 M3 6MT SG | KO, 2018 F87 M2 6MT | AW, 2016 981 Cayman 6MT | JB, 2015 F80 M3 DCT | TZB | GB, 2013 E92 M3 6MT | MW | FRB
KB7290.00
      07-08-2025, 01:28 PM   #160
Otto Bon Jovi
3040
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
Originally Posted by JTO24 View Post
#savesilverwheels
Looks good ! 👍
      07-11-2025, 12:16 PM   #161
John @ BSPK
2423
Not on BG, but there should be some Anika white gold pics very soon.
      07-11-2025, 12:20 PM   #162
John @ BSPK
2423
More Vera love. This time in brushed aluminum satin. More to come in a second as I have some fun milling content that I want to share as well. First off, though:
Vera | Brushed Aluminum Satin | 19x10 / 20x11 | Flush Fitment | Custom M Logo Cap
JTO246897.50
      07-11-2025, 05:34 PM   #163
John @ BSPK
2423
This is the part I find most fascinating. What you’re seeing isn’t a typical 5-axis pass. It’s a 3-axis CNC machine, but with a fully articulating cutter head — one that tilts, dips, and pivots mid-cut to reach angles even full 5-axis setups can’t hit without complex fixturing or reorientation.
That’s not to say it’s easy. Because of the tight clearances and extreme angles on the spoke windows, each spoke has to be milled from the outside in — resulting in a total machining time of 31 hours per Vera wheel. Fortunately, I run these 24 hours a day, so I'm able to get these done in the same time as others.
L3G0TS289.50
Nyyrule140.00
Jodedor334.00
JTO246897.50
cronut706.50
      07-15-2025, 12:25 PM   #164
John @ BSPK
2423
Another Anika – couple of these coming down the pipe this week. Let’s lead off with this, classic brushed aluminum. Someone had asked to see this over PM so here we go…
Anika | Brushed Aluminum Gloss | 19x10 / 20x11 | Flush Fitment | Custom Drilled for OEM Caps | Knurled Beading
JTO246897.50
Greg71856.50
      07-17-2025, 11:44 AM   #165
John @ BSPK
2423
Another Vera – satin black as mentioned. More of these coming.
Vera | Satin Black | 19x10 / 20x10.5 | Flush Fitment for OEM Tires | BSPK Caps| Knurled Beading
      07-17-2025, 05:17 PM   #166
Wagon1
Nobody
164
Drives: M3
These were delivered recently, 19/20 set Millies in brushed celestial gold. Will update when they are actually mounted. They look great in the box though.
      07-17-2025, 08:26 PM   #167
Otto Bon Jovi
3040
  [9.25]
  [9.25]
2024 BMW M2  [9.50]
https://imgur.com/zjjT7p0
I have to say IMO the new Vera is the best looking wheel for the G platform. Even better than my current Josie which I really like. Excited to see my new ones on the car once they are done!
JTO246897.50
      07-22-2025, 02:13 PM   #168
John @ BSPK
2423
Chiara coming off a recent design refresh, similar weight to before (~22lbs in 20x11) but a little bit more dramatic shape. Always iterating a bit. This one is in brushed gunmetal gloss, more in the classic shade (the Millie last week was a bit darker).
Chiara | Brushed Gunmetal (Gloss) | 20x10 / 20x11 | Flush Fitment | Custom Drilled for OEM Caps|
L3G0TS289.50
      07-22-2025, 06:11 PM   #169
stbm5
Drives: 2018 M5 DG
hard to tell what's different??
      07-22-2025, 06:12 PM   #170
stbm5
Drives: 2018 M5 DG
more concave?
      07-22-2025, 06:21 PM   #171
John @ BSPK
2423
Originally Posted by stbm5 View Post
more concave?
Yes. I probably should’ve clarified. I changed the shape of the spoke a little bit to make it more concave visually and allow for the spoke milling / holes to be a little larger. The video shows it really well imho.
Me2168.50
      07-22-2025, 07:19 PM   #172
stbm5
Drives: 2018 M5 DG
will the Chiara Due be different?
      07-22-2025, 07:52 PM   #173
John @ BSPK
2423
Yes. I would make the same changes to Chiara Due in G8x fitment.
      07-22-2025, 08:09 PM   #174
stbm5
Drives: 2018 M5 DG
i think the Due is my wheel. that or the Vera.
      07-23-2025, 11:06 AM   #175
John @ BSPK
2423
Something a little different. Jackie Due. Black centers with polished lips and hidden hardware (not a G8x fitment FYI – so concavity is reduced versus what you would expect for a G8x).
Jackie Due | Black Center with Polished Lip (Hidden Hardware) | 20x9 / 20x10 | Flush Fitment | Custom Drilled for OEM Caps|
MLife6141391.00
      07-24-2025, 07:05 AM   #176
John @ BSPK
2423
Another Anika – this time in brushed titanium gloss. I have posted a bunch of these but every time I just love the concavity we’re able to achieve here.
Anika | Brushed Titanium Gloss | 19x10 / 20x11 | Flush Fitment | Custom Drilled for OEM Caps |
matowi2699.00
JTO246897.50
lithe68.00
