08-17-2022, 11:51 AM | #155 | |
You got my money?
3250
Rep 4,716
Drives: Ice Cream Truck
Another member posted something by 3M. It looked like a good solution. But I am not an engineer and I have no experience with it. 3M has excellent customer service. I would call them ask ask them about it or what they suggest.
chicagofan0019325.50 |
08-17-2022, 12:01 PM | #156 |
Rep 753
Drives: 22 M4c vert
I ordered a tube of this stuff, which I've used previously. Has a temp rating up to 250 f, which should be far more than sufficient.
https://www.amazon.com/gp/aw/d/B072M...b_b_prod_image |
hawaiiracer1275.00 |
08-17-2022, 12:05 PM | #157 |
Rep 8,113
Drives: 2024 X5 M60i
Perhaps something like this?
MG Chemicals - 8329TFF-25ML 8329TFF Thermally Conductive Adhesive - Fast Cure Epoxy, 25 mL Dual Dispenser https://a.co/fCQikus
08-17-2022, 09:45 PM | #158 | |
Rogue
760
Rep 243
Or do you need a physical light taken out? |
08-19-2022, 07:13 AM | #159 |
Rep 2,142
Any updates on the shipping status?
08-22-2022, 02:21 AM | #160 |
Rep 346
IMPORTANCE Double check your DRL configuration
For those outside the State, make sure to double check your DRL to confirm to get the right one for your car. From the video posted I saw the outer board (which has the indicator) has 11 pin configuration. My AU model car with laser light, has 9 pin configuration, so assume EU model would be the same as AU model. So your order may not work. Also access to remove the top screw for the outer board is major PITA if you dont have the right tool. I happen to have this in the toolbox and it just works. |
08-22-2022, 02:32 AM | #161 | |
Rep 7,033
YT: G Dubyou |
08-22-2022, 09:46 AM | #162 |
Rep 753
Drives: 22 M4c vert
Didn't spot in the video - is there a separate Bluetooth module? Thought earlier in the thread it was mentioned that it was a separate box that had to get mounted in the right place.
08-22-2022, 01:49 PM | #163 | |
Rep 2,142
EDIT: that pic looked like an allen wrench... confirmed hawaiiracer's commnet that it's torx. Last edited by nearwater4me; 08-22-2022 at 02:00 PM.. |
08-22-2022, 05:09 PM | #164 | |
Rep 346
The screw is blocked by all the surrounding frame and has very little clearance to squeeze the wrench in, left alone the ratchet. You can see the screw through the hole when you pop the hood opened. |
08-22-2022, 05:12 PM | #165 |
Rep 346
here you go |
hawaiiracer1275.00 Limegrntaln13707.00 |
08-22-2022, 05:34 PM | #166 |
Rep 7,033
I think if you need to buy something because you don't have anything that fits. Search "low profile torx." You'll run into these types of results. This is like a $10 kit on Amazon. You can probably get a single T20, even cheaper.
YT: G Dubyou |
08-22-2022, 05:44 PM | #167 | |
Rep 7,033
YT: G Dubyou |
08-25-2022, 11:05 AM | #168 |
Rep 1,683
So I tried using the recommended app below on my Samsung s21 ultra and quite frankly it sucks. Explains the poor ratings it got. The app keeps crashing on me and there is no way for me to add a Bluetooth device.
Are there any other alternatives? |
Mraceguy113.50 |
08-29-2022, 07:33 PM | #169 |
Rep 8,113
Clearly.
08-29-2022, 07:37 PM | #170 | ||
Rep 8,113
08-29-2022, 08:17 PM | #171 |
Rep 200
Thanks. Really looking forward to this mod!
08-29-2022, 08:20 PM | #172 |
You got my money?
3250
Rep 4,716
Is the yellow dark like on the M5CS yellow? The pics look almost brownish yellow. Kind of of reminds me of the E92 M3 halo bulb color.
08-29-2022, 08:36 PM | #173 | |
Rep 8,113
GENNEL 10g Thermal Conductive Glue, Heatsink Glue, Thermal Adhesive for 3D Printer, LED, PC and Various Electronic Components That Need to Be Bonded - G109 https://a.co/4M4WnhF
08-29-2022, 10:35 PM | #174 |
Rep 7,033
I just tried to take more pictures and the apple phone camera just can't capture the true color. These still look yellow orange, when the actual DLR pipe, is blood red, and it doesn't glow like it does in the pics. I tried to adjust the settings before and after I took the picture.
YT: G Dubyou |
hawaiiracer1275.00 chicagofan0019325.50 |
08-30-2022, 12:00 AM | #175 | |
Rep 1,123
08-30-2022, 12:05 AM | #176 | ||
Rep 7,033
YT: G Dubyou |
Blindside_1376755.00 |
