04-07-2024, 11:17 AM | #133 | |
Rep 7,033
YT: G Dubyou |
M4Tejas846.00 |
04-07-2024, 12:43 PM | #134 |
Rep 198
So what they are saying is AC Current vs DC Current - absolutely 100% false - The taillights are set to a way they start up - I've tested so many aftermarket Tail lights and its how its made you cant change the current they should know that you get an error code if the current goes over or under - now you can go into coding and code out the current values so you don't get a code but the problem with that you can burn the tail light so scratch that whole theory .
Limegrntaln13707.00 |
04-07-2024, 12:44 PM | #135 |
Rep 198
Lights I have they dont flicker at all its simply on or off
https://youtu.be/32bPtlvnROo?si=Wci5HMNP3OQzfG36 |
M4Tejas846.00 |
04-07-2024, 01:11 PM | #136 |
Rep 553
Drives: 2022 G83 M4
Sounds like we're going to need someone with an LCI to compare the BDC coding with to find out what the differences are that need to be changed and eliminate the startup flicker
Limegrntaln13707.00 M4Tejas846.00 |
04-07-2024, 04:04 PM | #137 |
Rep 7,033
People should start getting their 2025s pretty soon.
YT: G Dubyou |
04-07-2024, 04:07 PM | #138 | |
Rep 7,033
https://vinyl-designs-2-1515.myshopi...yle-taillights Jerry, once I get my lights installed, I can run them by so you can take a look at them and see how they function, if you want? It’s up to you.
YT: G Dubyou |
thatguyM4220.00 |
04-07-2024, 04:21 PM | #139 | |
Rep 553
Drives: 2022 G83 M4
Man if you were able to get to Jerry's and he were able to look at it I'm sure he could figure it out
04-07-2024, 04:35 PM | #140 |
Rep 7,033
I’ve been to Jerry’s house a few times. He’s installed my CSL DRLs. I’ve tested a few sets for him. I’m not down the street, but he’s not too far to drive to. Maybe an hour from me.
YT: G Dubyou |
yocubed1084.00 |
04-07-2024, 04:55 PM | #141 |
Rep 553
Drives: 2022 G83 M4
Yeah you do have to pull the taillights to run the harness. It connects to the plug on the backside of each outer taillight and then you run the other end to the BDC module in the passenger footwell. Thankfully the G83 already had the requisite wiring. I still have a feeling that even with the current coding we'll have the strobe effect. My car is already coded for the Euro signals so I'll know for sure when my lights come in.
04-08-2024, 10:13 AM | #142 | |
Rep 198
04-08-2024, 10:17 AM | #143 | |
Rep 198
Limegrntaln13707.00 yocubed1084.00 |
04-08-2024, 05:51 PM | #144 |
Rep 7,033
Fixed the swirling with my LHR75E, Rupes white pad and Sonax Perfect Finish.
YT: G Dubyou |
yocubed1084.00 chicagofan0019327.00 M4Tejas846.00 nearwater4me1924.50 thatguyM4220.00 yousefnjr6238.50 bri10426127.00 ny2nj192.50 |
04-08-2024, 05:54 PM | #145 |
Rep 553
Drives: 2022 G83 M4
They look great now get them on!!!
04-08-2024, 05:59 PM | #146 |
Rep 7,033
Yeah, I had other things on the agenda. I swapped out the 826m for the 1000Ms. Pulled the fender liners, drilled and fitted the screens. Installed 13mm spacers squared. It’s already 4 my time.
Not sure if going to get to them; today. I kind of wanna drop them off at the detailer and get them PPFd. My whole car is already wrapped. Tails scratch easy, but the detailer is 25 miles away. 50 mile round trip to get them PPFd? Worse, they don’t do anything same day. So, it’s 25, come home, go tomorrow, 25, come home. 100 miles to get my tails PPFd.
YT: G Dubyou |
M4Tejas846.00 |
04-08-2024, 06:18 PM | #147 |
Rep 553
Drives: 2022 G83 M4
Gotcha. You've been busy my man. Those 1000Ms would have been my choice of I didn't get the 827s.
Which fender clearance option did you opt for? RKP, R44 or something else?
04-08-2024, 07:36 PM | #148 | |
Rep 1,069
04-08-2024, 08:30 PM | #149 | ||
Rep 7,033
YT: G Dubyou |
04-08-2024, 08:40 PM | #150 |
Rep 7,033
I went back out and started fiddling with the tail lights. I got all of the plastics off, I was just going to pull the carpet back to get to the inside nut. I put my socket on it, and I needed a longer extension. Pulled the extension out, and the 10mm came off the extension and fell back down behind the fuse box and down into the fender, so, I closed up shop for tonight. I’m. I’m not messing with it anymore. I have to pull the whole floor out now, to unbolt the plastic tray in the bottom corner. I started pulling this trunk trim piece off, but, I didn’t wanna break it, so, I’m packing up. I’ll figure it out tomorrow.
YT: G Dubyou |
04-08-2024, 08:52 PM | #151 |
Rep 553
Drives: 2022 G83 M4
That trim piece has 3 or 4 push pins on the inside edge. Look in the trunk and face the rear of the car and you'll see them. After that it's just held on by friction clips. Pull straight up and it'll come loose.
04-08-2024, 08:59 PM | #152 |
Rep 553
Drives: 2022 G83 M4
Something like this may help you fish it down into the crevice and get the nut. https://www.harborfreight.com/flexib...saAoyLEALw_wcB
04-08-2024, 09:09 PM | #153 | ||
Rep 7,033
YT: G Dubyou |
04-08-2024, 10:57 PM | #154 |
Rep 539
Pull 4 pushpins, 4 interference clips (mounted trunk trim part) inserted into the metal bodywork……yank and pull Rubber trunk gasket covers edge.
