BMW Lease Deals
      09-16-2021, 06:54 PM   #111
evilalien
evilalien's Avatar
Drives: MY22 M3 Competition xDrive
Originally Posted by jailonacs99 View Post
I'm doing this exact same setup. Had to re-jigger my original order for 826Ms but hopefully now I have a proper order in. Ordered my tires from TireRack separately. I don't think the latest in-stock ones I ordered at 275/35 come with the BMW * (there was a different size that did on the website) but for a square winter setup I'm not concerned about super high performance driving as much.
I hit the easy button and my dealership is getting me the G80/2/3 winter package, which is 19x9 front 19x9.5 rear wrapped in the Pilot Alpin tires.
I've only seen photos in a profile view, from BMW's marketing. That's enough for me
https://www.press.bmwgroup.com/latin...KR?language=en
What does the whole set run?
~$5000 CAD, wheels tires and TPMs, but prices vary. Depends on how you get them, they are BMW parts.
evilalien
Current: MY22 M3 Competition xDrive; Canadian Ultimate Package (-carbon bucket seats, CF trim); Santorini Blue; Fjord blue/black full leather
      09-16-2021, 09:46 PM   #112
blackheartm3
Drives: 2022 M3C xDrive
Shout out to LoneAmerican who found a bunch of photos of the 829s. Made me feel better about having ordered them. They look pretty good!
https://g80.bimmerpost.com/forums/sh....php?t=1859233
evilalien459.00
      09-17-2021, 01:41 PM   #113
jailonacs99
jailonacs99's Avatar
496
Right on, ya that's about what I'm paying for the 826Ms, tires, and TPMS' separately.
Only hiccup now is there are only 2 19" 826Ms in the whole country, so I'm going to have to wait over a month to get the complete set shipped out from Germany. Unfortunately my tires had already shipped before I found out, otherwise I may have tried to go with larger rears. But the Alpin 5s don't seem to come in a larger size that isn't built for a Mercedes SUV.
evilalien459.00
      09-17-2021, 02:06 PM   #114
evilalien
evilalien's Avatar
Yikes. That is a good example why I opted for the full package through my dealership parts department for about the same timeframe my car arrives.
evilalien
JTO245906.00
FLOSS M389.00
      09-17-2021, 09:15 PM   #115
tmilnthorp
Drives: 2015 M4
Do they fit the vehicle with CCBs?
      09-17-2021, 10:22 PM   #116
ame2010
Drives: g80
help a newbie!
Hi everyone, this is my first time having a car in cold weather. I have stock 826m (19F, 20R) on my g80. Is anyone keeping their stock wheels on and just getting winter tires? What am I missing here? Thanks for the help
View post on imgur.com
      09-18-2021, 10:49 AM   #117
amzbimmer
Drives: G80 comp San Marino Status 112
Each time you swap tires on a wheel, there is chance of damage. It is safer to get a dedicated winter set. You don't want to risk damaging your OEM tires with frequent mounting and dismounting of winter tires every year. The larger winter tires will also be more expensive, they don't make a lot of 20" winter tires, and they are much pricier.
Also, skinnier/smaller tires are generally better to cut through snow. Fat tires are not idea. This is why they recommend sizing down and narrower for your winter set.
evilalien459.00
ame201033.00
      09-18-2021, 11:48 AM   #118
evilalien
evilalien's Avatar
No idea, I'll try to find out. I thought that winter 18s fit the normal brakes, and that the stock 19s work for CCBs. Therefore, I expect that the 19 winter set will as well. That might be too rational, which is a character flaw of mine.
evilalien
      09-18-2021, 12:35 PM   #119
ame2010
Drives: g80
thank you for the info !!
      09-18-2021, 01:24 PM   #120
S@v3f3rris
I think 18/19 staggered setup will give best sidewall protection. I was looking at 824m wheels for this purpose. However, 1) some people with 18s have inner barrel scoring from rocks and 2) I haven't seen true winter tires for this (only conti dws all season).
19 square setup will allow for better tire rotation. But back wheels will have more of a gap in wheel well vs 10.5 wide OE unless you add spacers. There are snow tire options for this setup.
19/20 staggered setup will look great for rear wheels but won't offer as much pothole protection with less sidewall in the rear and isn't the best if you get lots of snow (wider wheels like the summer setup). Sottozero is only snow tire option for this setup, I think.
Kind of need to figure out your winter snow conditions and how you like the car to look to make the call.
      09-18-2021, 02:22 PM   #121
Nifty
Drives: 2022 AWD M3
I always run separate winter wheel / summer setups but like everyone else, it's been more difficult this time around with these wheel sizes (finding tires isn't too bad) and 4-5k for the OEM option seems pretty steep. I'm by no means an expert, but it appears that one of the main issues might be backspacing to ensure zero complications with suspension components. If that's the case, that's probably why tire rack only has a single option and it's a +22mm offset (with stock being +20)
OEM Wheel sizes
824M: 9,5Jx18" IS20 / 10,5Jx19" IS20;
825M / 826M / 963M: 9,5Jx19" IS20 / 10,5Jx20" IS20;
1000M: 9,5Jx20" IS20 / 10,5Jx21" IS20;
829 M (winter wheel): 9,0Jx19" IS20 / 9,5Jx19" IS20
That said, it seems like there would be alot more options if you use a 19x9 wheel (instead of 19x9.5) along with 10mm spacers. I think that would allow for wheels with up to 35mm of offset which dramatically increases selection. Like I said, not an expert, just trying to work out options. Does what I said make sense, or am I missing something obvious?
2022 M3 xDrive
      09-18-2021, 03:30 PM   #122
forza1976
forza1976's Avatar
2022 BMW M3X  [9.50]
My winters. Not pretty, but economical. Will need some new BMW center caps to make it a little better.
Nifty73.50
amzbimmer306.00
      09-18-2021, 03:32 PM   #123
evilalien
evilalien's Avatar
OEM Wheel sizes
Probably makes sense. When it comes down to it, I'm not willing spend the time and absorb the risk in finding my own mildly-more-optimized solution that'll likely cost the same or more at the same quality bar.
Easy and guaranteed correct path is the BMW set. Might not be cheapest, but looks good and I don't have to spend time or energy over-thinking my off-season solution. Done. No longer an active problem.
evilalien
Nifty73.50
      09-18-2021, 04:02 PM   #124
Nifty
Drives: 2022 AWD M3
Yea, it appears that I'm spending time overthinking for us
I'll more than likely go with the OEM BMW set or the one that Forza posted above from TireRack, but figured I'd try to find something in the middle if not too complicated. Until these cars became a bit more common and some folks act as testers, you're right, having the peace of mind and lack of headaches is certainly worth quite a bit.
2022 M3 xDrive
evilalien459.00
      09-18-2021, 04:05 PM   #125
Nifty
Drives: 2022 AWD M3
Ya know, those don't look as bad there as they do on Tirerack's site, especially if you just remove the center cap. I might just pull the trigger on a set as well.
2022 M3 xDrive
forza19763521.00
      09-18-2021, 05:36 PM   #126
voyagergab
voyagergab's Avatar
Drives: G82 M4 6MT, G01/F97 X3M
Looks good. Can you post the names and specs please.
      09-18-2021, 06:09 PM   #127
amzbimmer
I had pulled the trigger on these with the Wintrac Pro, but then cancelled it. I think they look decent, but I'm looking the other Superspeed option suggested on the Canadian forum. The Super Speed team was very responsive and suggested this- RF05 19*9.5 +25 5x112 CB:66.6 (Conical seats). Can anyone that is good at fitment check if that sounds correct?
I was able to go into my local Costco and get the Michelin Alpin 5 for ~$1140 + tax, which is a killer deal! They said they have to order them in, but will get there in 3-5 days. You can't get them directly on the website as of now.
FYI- the price includes a $120 rebate for the tires that he gave me. Beats the heck out of any prices I have found for good tires thusfar.
      09-18-2021, 07:20 PM   #128
tydntydj
Drives: m235i
2019 BMW X5 40i  [0.00]
2016 BMW M235i  [0.00]
Have you found a dealer for these in the States? I found them on AutomotiveStuff.com but not sure if I trust this site.
      09-18-2021, 09:39 PM   #129
forza1976
forza1976's Avatar
2022 BMW M3X  [9.50]
https://m.tirerack.com/wheels/WheelC...tandard+Brakes
      09-18-2021, 09:41 PM   #130
amzbimmer
I've been looking at a couple of options in Canada that ship to the USA.
Automotivestuff does seem shady based on reviews, I'll keep looking for another option and let you know if I find something.
      09-19-2021, 10:05 AM   #131
jmh600cbr
jmh600cbr's Avatar
Drives: G80
2021 BMW G80  [0.00]
Originally Posted by PLife View Post
What about the continental all seasons for the awd? This car has a clearance of 4 ish inches anyway
If you have snow where you live all seasons won't do it. You need real snow tores
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM
evilalien459.00
      09-19-2021, 11:21 AM   #132
forza1976
forza1976's Avatar
2022 BMW M3X  [9.50]
Test fit, I'm satisfied!
Appreciate 9
Medal505.50
amzbimmer306.00
Nifty73.50
rdasari87.50
JTO245906.00
M3exDeo214.00
fattest13.50
