01-10-2023, 07:14 PM | #111 | |
Rep 1,368
2021 ///M3
2019 X3 |
M4Tejas846.00 |
01-11-2023, 07:06 AM | #112 |
Rep 373
Wow so wait I thought when you had the pic of the bumper on the car it fit??
22 G83 X Drive Toronto Red Black Interior
Blue Calipers Frozen Black Edelweiss LT3 |
01-11-2023, 08:51 AM | #113 |
Rep 1,368
So did I, but I didn't have it fully buttoned up. When I went to screw everything in is when I had the issues. I spent an embarrassing amount of time taking the bumper on and off because I trlmmed everything according to the video and pictures im the thread. I even test fit the foam to the bumper cover when it was off the car. All seemed good...but alas it wasn't.
01-11-2023, 10:06 AM | #114 | |
Rep 373
01-11-2023, 10:08 AM | #115 |
Rep 1,368
I can only speak for myself. The fitment of the grille itself is nice, but I wish I had known how much of the foam I needed to cut. I wish they would have just accounted for it in the design so that you didn't have to modify the foam, but oh well. I have such a love/hate relationship with modding.
2021 ///M3
2019 X3 |
01-19-2023, 06:03 PM | #116 |
Rep 105
Thanks for the tip - will give this ago next week!
M4Tejas846.00 |
01-21-2023, 12:13 AM | #117 |
Rep 1,368
Let us know how it went and if you had to trim that whole center section of foam. Whatever you do, careful with the sensor clips - they are the weakest part of that thing. I still managed to crack one of mine a tiny bit where the tabs of the sensor clip in. It's crazy how much stronger the OEM unit is.
2021 ///M3
2019 X3 |
01-23-2023, 04:42 PM | #118 | |
Rep 105
Epoxy on the sensor clips drying as I type! Grille will be fitted in the morning
Quick question, did you have to order a new M badge? Or can you get the one of the original grille with wire and a pry tool? Quote:
mattssi882.00 |
01-23-2023, 04:55 PM | #119 | |
Rep 1,368
I wanted to do it myself and save a few bucks, so I ordered the side vent w/ the M3 logo ($35), peeled it off. Ordered some 3M emblem tape and an X-acto knife but could not get the tape to be perfect. It was very difficult to cut it exactly right. I didn't want to see the tape from the front at all, but I wanted it to basically fill the entire back side of the emblem similar to what you would expect from the factory. Mission failed. I easily could have cut some tape in pieces and put it on there and called it a day, but I have issues apparently In the end, I paid IND $90 for a stupid logo, but that thing came packaged like a tank, with very thin 3M tape on the back that fit exactly how I was trying to make it. If you're anal like I am, that is the way to do it. I like doing things myself, but I just couldn't DIY to the standard I wanted without cost getting out of hand. This photo is a little misleading due to the lighting/reflecftions, but the logo fits perfectly. The only thing that bugs me a bit now is the bumper foam which is visible/noticeable in direct light. Otherwise, it look bad ass.
2021 ///M3
2019 X3 |
01-23-2023, 04:59 PM | #120 |
Rep 1,368
Oh, you can def take the logo off the old grille with about 3 seconds of heat gun and a pry tool. I just wanted to easily revert to stock if needed.
2021 ///M3
2019 X3 |
01-23-2023, 05:07 PM | #121 |
Rep 105
Excellent, thanks for the help! I'll post my progress tomorrow!
01-23-2023, 05:11 PM | #122 |
Rep 1,368
Good luck!
One last word of advice. You can't over tape/protect things. It'll probably be overkill, but worth it. I only taped part of my headlights, but I had taken off/put on the bumper about 30 times in my frustration with the grille/foam fitment I managed to get lazy and the metal clips on the top of the bumper managed to scratch both headlights. So, I have to get those polished out. What a journey!
2021 ///M3
2019 X3 |
01-23-2023, 05:22 PM | #123 | |
Rep 105
Haha got it!
But its worth it, yours looks wayyy better now its finished! Hopefully this will be the last piece that stops me being slightly annoyed by the way my M4 looks... Quote:
mattssi882.00 |
01-23-2023, 06:36 PM | #124 |
Rep 1,368
I should write a grille install blog the way I keep remembering things I should relay.
Another tip. Most people just undo a few fender screws and fold the liner back in order to finagle a socket set in to remove the 2 bolts from each side of the bumper. I've done that before, and it does work, but you scrape up the back of your hand and its kind of a PITA. This time, I removed the wheels and removed the front fender well plastic. It was SO much easier to then remove the two bolts that hold the bumper on. Not only that, the plugs are super easy to then remove. Its also a great time to do the halo light mod if you're into that thing since you have access to so much with that portion of the liner removed. Its extra time, yes. But it was nice to not fight for access to the screws. Plus, its a great opportunity to shine up the wheel well and wheels.
2021 ///M3
2019 X3 |
khalua80769.50 |
01-24-2023, 05:50 PM | #125 | |
Rep 258
01-24-2023, 06:09 PM | #126 |
Rep 105
Installed, no dramas aside from what's already been mentioned (and its not really drama)
Picture isn't the best, I'll get some more tomorrow but looks a lot better in my option, looks more like an M car and what this car should come with in my opinion. Still not content, maybe I need to add the ducts or the MP splitter... |
M4Tejas846.00 |
01-24-2023, 07:20 PM | #127 | |
Rep 1,368
Nice work! I assume you cut that entire center foam section? And yes, ducts make almost just as much of a difference. Should definitely come with them from the factory.
2021 ///M3
2019 X3 |
01-25-2023, 09:25 AM | #128 |
Rep 105
No I just did it as per the Vorsteiner video to start with and see....and didn't need to remove anymore.
Only thing after looking in better light this morning, the gap from the top of the bumper to the hood is a little too big, so guess I need to do some re-adjusting (and hope I don't need to remove again) Did you struggle to get the gap to the hood right? |
01-25-2023, 09:28 AM | #129 | |
Rep 1,368
I could only do left or right, too or bottom because the foam prevented good fitment. Once trimmed the bumper sat nicely - no issues with gap or anything. Wonder if different trimming is needed for M3 vs M4 Last edited by mattssi; 01-25-2023 at 10:00 AM.. |
01-25-2023, 09:59 AM | #130 | |
Rep 105
Hmm interesting, I removed about 2inches in terms of width and was fine! Possibly an M4 vM3 thing, but id assume everything would be the same?!
I need to sort the gap out, so I'll investigate more! I think I need the CF ducts now or the Alpha N splitters to make the look perfect though... Quote:
12-09-2023, 10:58 AM | #131 |
Rep 1,368
Wow, V dropped the price on this grill pretty significantly. About time. Used to be $899, now $599, but on sale for $509. Pretty sweet.
2021 ///M3
2019 X3 |
