      05-13-2023, 01:40 PM   #89
TheNine90
582
Drives: bmw
Originally Posted by BIGW0RM View Post
Say that again? How did you accomplish this?
Change typecode to ECE and code the flm modules.
If you have pre lci then you can edit the cafd without change the typecode.
      05-14-2023, 08:45 PM   #90
FC4
Drives: Yes
Coded anti-dazzle via BimmerCode…I don’t get what all the fuss is about. Sure it’s a little different than the high beams flashing on and off, but it’s not a big deal.
      05-15-2023, 08:30 AM   #91
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Drives: BMW 2017 M2 07/16 Build
It will work but your missing coding on three other modules. Which is pretty important I would say considering the cost of these lights if they were to burn out or over work themselves from incorrect coding.just saying.
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey
2004 E46 M3 White
END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci
      05-26-2023, 11:39 AM   #92
Rux
Rux's Avatar
656
Drives: Little of this, little of that
2024 BMW G42  [10.00]
2022 BMW G82  [10.00]
I found the opposite. It was a huge difference for me. Without ESYS I am to understand the beam is just not as narrow? Meh. I like free. For now.
"It's not how fast you go, it's how you go fast"
      05-28-2023, 03:16 AM   #93
backslashv
backslashv's Avatar
106
Drives: 2022 BMW M3 Competition
Apologies if this has been mentioned elsewhere, but what are the values that need to be changed via ESYS? This seems to not be exactly accurate for iDrive update 11/2022 as per a comment in this thread saying anti-dazzle was disabled in 7/2022 update following that guide.
      05-28-2023, 04:01 AM   #94
Th3DarkSide
Th3DarkSide's Avatar
369
Drives: 2020 M4
I’m not going to even bother. I had it in my F82s and never used it. I’ve been debating it but it’s something I won’t ever use.
      11-25-2023, 11:25 AM   #95
G82DravitWolf
G82DravitWolf's Avatar
Drives: '24 M4 G82 xdrive coupe
Hey all - just coded the settings available in Bimmercode for Anti-dazzle. I wanted to ask if the remaining coding is required/recommended in Esys?
I do have Esys and open to coding it myself but haven't been able to find a confirmed/verified step by step process.
Thanks in advance for the help!
      11-26-2023, 01:36 AM   #96
TheNine90
582
Drives: bmw
If you did using bimmercode it should be enough
      11-26-2023, 01:40 AM   #97
TheNine90
582
Drives: bmw
If you have 5AP in FA then you can remove it and vo code BDC, FLM, HU, KAFAS. then redo the coding using bimmercode
      11-26-2023, 07:59 AM   #98
biggripper
biggripper's Avatar
728
Drives: 2024 G80 M3 Comp xDrive
I live in the UK with my US spec G80 and here it’s a must have feature. I’m driving mostly unlit B roads at night, and it gets extremely dark here this time of year. This is a country where Road visibility during the daytime is poor, because of how they allow hedges and other vegetation to grow right up to the side of the road. This means that being able to use every last ounce of your headlights makes a huge difference. Now with anti dazzle coded on, my highbeams stay on nearly 90% of the time when I’m outside my village driving. I can see the headlights selectively shielding cars that I’m following or oncoming cars so that they’re not blinded but the rest of the highbeam is doing its work. The effect is high beam brightness and spread with a clearly visible shadowy demarcation around the other motorists. It’s pretty impressive.
If it’s NOT properly coded in and working 100% correctly, it’s not gonna be that impressive. Furthermore, if you find yourself mostly doing in-city driving, it will not be particularly useful or impressive.
The system seems to know when you’re in the city based on street signs and lights etc, and as a result, won’t activate the highbeams. It’s really on dark country roads and less crowded sections of the interstate/motorway where you’ll see the feature activate.
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels
FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels
FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels
FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels
      11-26-2023, 03:08 PM   #99
Berzerker
Not exactly the most helpful. Do you know of a step by step guide for what to code in those modules?
      11-26-2023, 04:34 PM   #100
G82DravitWolf
^this would be super helpful! 🙏🏼
      11-26-2023, 07:29 PM   #101
dmr
Drives: G87
I posted this in G87 forum some time ago. That might be what you're looking for:
https://g87.bimmerpost.com/forums/sh...ght=antidazzle
      11-26-2023, 07:39 PM   #102
G82DravitWolf
thanks discreet_mayor very helpful and much appreciated!
      11-26-2023, 11:50 PM   #103
Berzerker
How does this translate to only using BimmerUtility?
Limegrntaln13704.00
      11-27-2023, 06:46 AM   #104
dmr
Drives: G87
Honestly not sure, but the recipe is low-level enough that you should be able to use it with any software that lets you program values in the car's various modules, maybe through some advanced mode?
      11-27-2023, 05:50 PM   #105
Berzerker
So I'm a bit confused. Your post says "recipe to code this using BimmerUtility" but step 1 is doing stuff through eSys as well.
You're saying you used ESYS *and* Bimmerutility? i.e. Step 1 through ESYS, then Steps 2, 2a and 3 through bimmerutility?
Do you know of a good ESYS tutorial relevant to iDrive 8?
      11-27-2023, 05:55 PM   #106
thatguyM4
Drives: 2021 M4
I've coded my lights well over a year and no issues what so ever and just using Bimmercode - The only thing I really noticed is that its a little sensitive as to coming on but it works great
      11-27-2023, 05:58 PM   #107
Berzerker
Yes I'm aware that can be done and have already done it, but I'm interested in getting that last 20% of the functionality, hence my questions.
      11-28-2023, 05:45 AM   #108
dmr
Drives: G87
That is correct. I used esys only in Step 1, because I had found clearer instructions on how to vo code/decode using it, though BimmerUtility is also capable of doing so. You don't technically need esys, but would have to translate step 1 into the BimmerUtility equivalent.
      11-28-2023, 09:55 AM   #109
Berzerker
And BU is completely capable of accessing every ECU on iDrive 8 as well? I noticed ProTool doesn't have access to the same stuff you do on ESYS, so I'm hesitant to buy yet another license to something.
      11-28-2023, 03:01 PM   #110
Hyura
Hyura's Avatar
Drives: 2023 M4 Competition xDrive
Having both, BimmerUtility is just an add on to ESys. ESys should have access to all the modules but it’s not labeled so you’ll using BimmerUtility to label what these options are. The amount of labeled options vary from BimmerUtility vs ProTools, but from my experience, BimmerUtility should have a bit more labeled options while on ProTools just have unlabeled options in raw hex values. Still editable, you just wouldnt know what you’re changing.
