BMW Lease Deals
      07-22-2024, 06:31 PM   #991
AiBiasEdi
Drives: BMW M3
Limegrntaln
I just got the kit delivered and was wondering if you know the adjustments for the G80. I want to go max front but trying to find how low I should go with the rear.
Front 20mm
Rear 5 or 10mm
Limegrntaln14340.50
      07-22-2024, 10:33 PM   #992
cozye
cozye's Avatar
635
Drives: 2024 M3 Comp - 328ix (hers)
Originally Posted by AiBiasEdi View Post
Limegrntaln
Front 20mm
Rear 5 or 10mm
5 wont be enough. Thats less than 1/4”. I would say 10mm and go from there.
      07-22-2024, 10:35 PM   #993
Limegrntaln
Limegrntaln's Avatar
14341
Drives: 2024 Model S Plaid
Agreed. 5 would barely be noticeable. 10 minimum.
SOLD: 2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou
      07-25-2024, 03:54 PM   #994
Tatted
Drives: 2019 Z06
First time poster so bare with me.Me and by dealer are building my M4 comp. XDRIVE and I have a few questions :
1)What part # do u use for the 2025 MPHAS system ?
2)When u add this to the build,is it paid separately or add to the cost of the build ?
3)Is it automatically done at the port when on the build sheet ?
Thanks in advanced.
      07-25-2024, 04:27 PM   #995
mjj
Drives: 2025 M4 Comp Verde BR
Thanks in advanced.
1) Dealer has the info to add it to the order
2) paid all together. Not a separate charge.
3) Yes it is auto installed at the port assuming it was included in the original order/build.
Tatted1.50
      07-25-2024, 04:30 PM   #996
Tatted
Drives: 2019 Z06
Thanks
      07-25-2024, 04:44 PM   #997
Limegrntaln
14341
Thanks
Go back to page 45. I posted the 2025 Port installed options list. The part number is on there. The only thing I don’t recommend is ordering wheels, because you pay for them, and they keep the stock set, you don’t get both.
If you’re leasing, you can residualize the cost of the springs into the lease. And yes, if you order them, they will be on the window sticker.
YT: G Dubyou
      07-27-2024, 10:17 AM   #998
chris3g
chris3g's Avatar
3157
Drives: 2023 M3 xdrive
Originally Posted by Limegrntaln View Post
You “should” get an alignment with any suspension adjustments. And from listening to my installer, he had to readjust my rear springs after he drove it, and he had to remove the inside lower control arms to take the tension off the rear springs, even with the car in the air. So, after that, it definitely needs to be aligned.
it's not that there is too much tension to turn it, it's because there is more tension on the adjuster than there is on the perch in the mount, so when you turn it the whole perch spins instead of the adjustment ring. such an annoying issue for something that should be simple. im wondering if anyone has come up with an easy way to hold the perch in place so the adjuster can be moved. if not i'm going to try to figure something out.
Limegrntaln14340.50
      07-27-2024, 03:18 PM   #999
BzsBimmer
BzsBimmer's Avatar
3462
Drives: '23 G80 FO M3 & '23 G05 X5 M50
There was a trick on the F8X chassis MPHAS that using a long flat head screwdriver up the center with a jack removed the preload and allowed adjustment of the collar. I never tried that method so not sure if that worked, specifically but there is/was a special BMW tool in the workshop instructions that removed the spring preload for that same chassis. I was never able to locate that tool via Amazon but I think the principle remains the same.
I just mark my camber bolts and realign to that.
chris3g3156.50
      07-31-2024, 11:41 AM   #1000
Vic55
Vic55's Avatar
23503
Drives: 2024 BMW M3 CS-2025 BMW M4 CS
So quite possibly a stupid question but fuck it...
My M4 inbound has the MPP HAS on the MSRP so it will be installed at the port...
Will they align it there?
What do they do with the OEM springs that were on the car?
2025 BMW M4 CS Black Sapphire Metallic
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      07-31-2024, 12:23 PM   #1001
mjj
Yes it is aligned at the port. I assume we do not get the OEM springs. Factored into their pricing.
I will confirm tonight as I am picking up my 25 M4 with port installed suspension at 5:00
Vic5523503.00
      07-31-2024, 12:33 PM   #1002
Vic55
Vic55's Avatar
23503
Helllllllllllll yaaaaa
Im getting mine today too--- told the dealer to flat bed it to me
Ill be getting mine around the same time. Whats your build?
Mine:
      07-31-2024, 03:53 PM   #1003
mjj
Mine:
I don’t have my build sheet handy but:
Verde British Racing
Tartufo Sport Seats
All packages
Carbon Exterior Package
M Perf Suspension
Did not get Carbon Ceramic brakes (street car)
Did not get buckets (Not as young and flexible as i once was)
Vic5523503.00
      07-31-2024, 04:35 PM   #1004
Vic55
Vic55's Avatar
23503
Tartufo Sport Seats
All packages
M Perf Suspension
I didnt build mine, just found it inbound on the Minnow and grabbed it---I have buckets in the CS so this will be my more comfortable car.
      08-01-2024, 05:22 PM   #1005
Vic55
Vic55's Avatar
23503
FYI- my steering wheel is not on center so I am assuming they forgot
How is yours?
Limegrntaln14340.50
      08-01-2024, 05:53 PM   #1006
Limegrntaln
14341
How is yours?
The factory uses a jig when they assemble the car. It’s bolted to the steering column, without the steering wheel. When the port does it they just sit in the seat and adjust the wheel, which the steering rack has a little play in it and it’s never completely straight.
YT: G Dubyou
Vic5523503.00
      08-01-2024, 06:10 PM   #1007
mjj
How is yours?
Steering wheel is good on mine.
      08-01-2024, 07:49 PM   #1008
Vic55
Vic55's Avatar
23503
This my minute dilemma but actually driving it a few more miles today and its so slightly off I didnt even notice it...
Limegrntaln14340.50
      08-01-2024, 08:51 PM   #1009
Limegrntaln
14341
I hate getting my car aligned anywhere, because most alignment shops make the wheel centering worse, when they align the car. They sit in the car and straighten the wheel, then go mess with the tie rods when they don’t need to be messed with. The rack tells them they need to be adjusted based on how well the aligned the wheel up. Which, there is a little play in the wheel, or you know, trying to adjust the wheel with the car off, yields different results then when the car is off and the wheel is adjusted into position.
YT: G Dubyou
      08-01-2024, 11:10 PM   #1010
cozye
cozye's Avatar
635
FWIW, mine was centered
      08-03-2024, 12:41 PM   #1011
M4Tejas
M4Tejas's Avatar
1081
Drives: 22 G82 M4xDrive
Lightbulb Clear Vision
The manufacturers allow for a generic averaged driver body weight when adjusting for CLEAR-VISION. Clear-vision has become a generic term describing if the steering wheel is properly centered or leveled during alignment adjustment. The best way is to sit in the car and don't move an inch and hold the wheel centered. This allows for your specific weight etc. My buddy ran Fort Worth Champion Spring alignment services for over 20 years. I will ask TTW for this type of alignment next gig.
When at GM Arlington Assembly Plant in 1978. The alignment pit was a 15 second clear vision set. Many autos on the new car lots are not centered properly. Quick play at the auto plants..........
Fort Worth Champion Spring, 90 year old spring shop. The faciilty was at one time a Greyhound bus depot for service. Greyhound (Dallas based). The owner sold the property off at the corner of Lancaster and Henderson for 5 million and built a lake house on Eagle Mountain Lake. The building was historic, early to mid 20's. QT bought the property, in addition to Haws Paint and Body next door, built their gas station convenience store.
When I worked at GM Arlington Assembly Plant, Local Union 146, Steamfitters & Pipefitters Local we worked the plant. I watched the alignment pit amazed. 15 seconds Clear Vision set. Many new autos on dealers lot has suspected alignment. Most if not all manufacturer makes will provided for one free alignment during the first 12,000 miles. This they do not advertise!
2022 M4 Comp xDrive Aventurin Red Metallic
https://wieninger.de/ Seit 1666
somer1057.00
      08-20-2024, 10:59 AM   #1012
KingMota1
Drives: 25 M3xD 19 Cayman 17Mini JCW
Can someone measure ground clearance from ground to bottom of front lip spoiler (or lowest rubbing point) after MPHAS installation? I have steep driveway and even with Bridjit my Porsche has to enter and exit at angle. My Cayman front end sticks out quite a bit and has 6.5" clearance and is tight.
I am looking at M3 xDrive without exterior carbon kit.
Thanks in advance!
Tags
g80 lowering springs, m performance accessories, m performance has, m performance suspension
