01-15-2025, 02:11 PM | #9835 |
Rep 6,727
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.75]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.70] 2006 BMW 330i Sport [6.12] 2004 BMW 330i ZHP [7.40] 2000 BMW 328i [6.17] |
I don’t know the third one in the first row or the fourth one in the second row, but I have an idea about that one.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
01-15-2025, 02:44 PM | #9836 | |
Fleet Mechanic
13708
Rep 1,988
Drives: E86 3.0si
Garage List '19 VW Golf R [10.00]
'55 Ford F100 [0.00] '08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [9.50] |
"These bags (1900-1960s) were used on road trips especially in the desert. The bag was soaked first, then filled and hung on the car’s hood ornament or from the bumper. As water seeped slowly to the surface, it evaporated and cooled keeping the water about 12 degrees cooler than the air. As both air conditioning and coolers for cold drinks were both unavailable to drivers, these offered a somewhat refreshing drink on a long drive." Additionally, if hung in front of the radiator, cooler air was passing through it and if overheating still occurred there was the water in it to replenish the boil over. |
9
MaxVO2369.00 tturedraider5939.50 Buug95925035.00 shannon1698.50 sygazelle14926.00 Llarry23196.00 JJ 911SC27453.00 3.0L12224.00 hubbahubba12023.50 |
01-15-2025, 02:46 PM | #9837 | |
Rep 5,863
MaxVO2369.00 tturedraider5939.50 3798j13707.50 Buug95925035.00 shannon1698.50 sygazelle14926.00 Llarry23196.00 hubbahubba12023.50 |
01-15-2025, 02:48 PM | #9838 | |
Rep 138
Newer versions look like the below, or one can use a wideband O2 sensor setup or other similar device(s) now but old school people used old school tuning devices... like their ears, basic vacuum gauge, etc.. The Weber carburators were finicky but when they were tuned well, the car just idled beautifully, especially the old F1 cars, and some exotics like the Weber's on top of the Ford Cammer engine below. |
10
3798j13707.50 dscabra5429.00 Buug95925035.00 shannon1698.50 sygazelle14926.00 JJ 911SC27453.00 Pauly Wauly6020.00 vreihen1623050.50 3.0L12224.00 hubbahubba12023.50 |
01-15-2025, 02:51 PM | #9839 | |
Rep 5,863
3798j13707.50 |
01-15-2025, 03:00 PM | #9840 | |
Rep 138
The Earth is covered with the stuff (water), not all fresh, but it's still funny people will pay $10 for a small bottle of water because it is allegedly from Fiji, or some amazingly clean and clear spring in Norway, or some not so clean nor clear puddle in Zimbabwe, etc.... |
9
3798j13707.50 ezaircon4jc5790.00 Esteban58680.00 cmyx6go17090.50 Buug95925035.00 shannon1698.50 JJ 911SC27453.00 Pauly Wauly6020.00 vreihen1623050.50 |
01-15-2025, 03:02 PM | #9841 | |
Rep 6,727
3798j13707.50 |
01-15-2025, 03:10 PM | #9842 | |
Rep 5,863
01-15-2025, 03:14 PM | #9843 | |
Rep 7,241
01-15-2025, 03:51 PM | #9844 | |
Fleet Mechanic
13708
Rep 1,988
Drives: E86 3.0si
01-15-2025, 04:09 PM | #9845 | |
Rep 389
Drives: GMC Denali
01-15-2025, 06:13 PM | #9846 | |
Rep 3,477
*On a funny note: That girlfriend ended up sticking with me, funny fuel lever and all. We married in '72 and just celebrated our 52nd anniversary. To this day, she whines when the gas gauge goes below a 1/4 tank, fearing that we'll run out. Last edited by sygazelle; 01-15-2025 at 06:19 PM.. |
01-15-2025, 06:17 PM | #9847 | |
Rep 3,477
01-15-2025, 08:16 PM | #9848 | |
Rep 138
Below is a pic of a 66 Pontiac GTO Tri-Power setup. Not Weber, but made by Holley. The linkage was quite complex and tuning was an absolute royal PITA and required significant finesse to do correctly. It was always a great idea to have additional fuel filtration as the jets in the carbs plugged fairly easily causing unbelievable frustration to a tuner. The car was quite fast for its day and had bias ply tires that were laughably poor at maintaining traction - so much so that it would just smoke the tires to the rims if you hit the gas really hard from a stoplight. Very very impressive car and an amazing piece of auto history. Adding even 20-30 hp to a car like this with a large displacement motor (389 cu inches) required significant bolt ons and money. Now, we are spoiled with our BMW's insofar as just buying a RaceChip, or JB4, etc... and adding 30-50hp or whatever without having to tear into the motor, or even get our hands dirty. Even a lower tier non M modern BMW is faster than the 1966 Pontiac GTO Tri power which was beastly for its day. Progress! |
01-15-2025, 08:31 PM | #9849 | |
Rep 6,727
One of the wonderful things I discovered when I moved to Chicago is the Lake Michigan water I can get straight from the tap is wonderful!!!
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ Last edited by tturedraider; 01-15-2025 at 08:37 PM.. |
01-15-2025, 08:32 PM | #9850 | |
Rep 138
That is an amazing old school piece of tuning. I never used one but some of the old timers I knew had used them before other tech for tuning somewhat supplanted it. It was the same with ignition systems. The old points, and non-HEI type distributor systems were often replaced with newer tech on the older motors. I remember taking my distributors to the speed shop so they could grind down the weights and put different centrifugal springs to adjust the timing curves to better match the mods on my cars. Otherwise it was just hit or miss. Worth the $3.... Some of the crazy stuff we did to make our cars faster in hindsight were kinda laughable now - but they were legit and plenty of guys spent countless hours making tuning adjustments that in total probably often were worth less than a couple HP here and there. Now? Dyno tuning and adjusting fuel/timing curves using a laptop. I still have a bunch of metering rods and hangars for Rochester Quadrajet carbs somewhere in my basement. I'll probably never need them but it took me forever scouring junkyards to find them. Old times, good times. |
01-15-2025, 08:42 PM | #9851 | |
Rep 2,014
dad pulling the reserve lever a few times. Also, when dad judged we were getting low on gas, but not yet on reserve, he’d switch to reserve just before passing a car on a 2-lane highway, then off the reserve after the pass. He didn’t want the engine to quit halfway through the pass. And now folks are probably wondering how a heavily loaded 36 HP VW micro bus could pass anything. Well, dad was a master at energy management and drafting.
2014 BMW M235i
2024 Mercedes Benz GLC300 Has it been 4 years yet? |
01-16-2025, 08:03 AM | #9852 |
Recovering Perfectionist
23051
Rep 1,039
Currently BMW-less.
10
cmyx6go17090.50 JeffL01932.00 kscarrol9922.00 dscabra5429.00 hubbahubba12023.50 Esteban58680.00 sygazelle14926.00 JJ 911SC27453.00 ezaircon4jc5790.00 shannon1698.50 |
01-16-2025, 10:02 AM | #9853 | |
Rep 2,014
after having the engine rebuilt. I had to buy the intake manifold from a parts house in Canada. Also, I had my overhauler install the Cortina GT camshaft. Between the 2-bbl Weber, new cam and tubing headers, that little pushrod engine really perked up. As the the Weber, I got pretty familiar with fine tuning it with the jets and emulsion tubes. This required some experimenting, but it was very driveable.
2014 BMW M235i
01-16-2025, 12:09 PM | #9854 |
Rep 3,477
...when you dressed like this at your wedding and you thought you looked cool. (I'm the groom - second from the left) - 1972
10
cmyx6go17090.50 Esteban58680.00 vreihen1623050.50 JJ 911SC27453.00 3798j13707.50 hubbahubba12023.50 kscarrol9922.00 ezaircon4jc5790.00 shannon1698.50 MaxVO2369.00 |
01-16-2025, 12:12 PM | #9855 |
Rep 7,241
Was going to put this in the "Bumper stickers" thread but thought it would go better here.
14
vreihen1623050.50 JJ 911SC27453.00 cmyx6go17090.50 3798j13707.50 sygazelle14926.00 Pauly Wauly6020.00 3.0L12224.00 hubbahubba12023.50 Roadcrew432.50 Buug95925035.00 kscarrol9922.00 ezaircon4jc5790.00 shannon1698.50 MaxVO2369.00 |
01-16-2025, 01:22 PM | #9856 |
Rep 3,477
...when you see this modern parent approach to getting your children to help with chores around the house and say, "If today's kids had my mom as a mother, they would most certainly be doing household chores for free with a smile because they were lucky to be alive, didn't want their asses sore, and wanted to eat their next meal with the family."
ps Thanks Mom! |
9
vreihen1623050.50 cmyx6go17090.50 3.0L12224.00 JJ 911SC27453.00 hubbahubba12023.50 Buug95925035.00 shannon1698.50 tturedraider5939.50 SpeedBuggy976.00 |
