| 11-11-2025, 06:51 PM | #67 |
Rep 663
Great! I am glad I opened this thread and it is interesting for many users here.
I suggest you to wait for the black Friday week, they will have a big sale. I am waiting for that to place my order. If you use the car mostly for track days/spirited driving you could go with the offset bushes. I am considering if I should do the same for my application also, or be more conservative with sealed non-offset bushes. I would like to know the opinion of the experts here. Can I ask you why you moved from rwd to xdrive? What's your impression with xdrive? |
| 11-11-2025, 08:44 PM | #68 | |
Anesthesia
1659
Rep 762
I already have Millway monoballs and camber plates so I wouldn’t need the CS+ handling pack. |
| 11-12-2025, 02:49 AM | #69 |
Rep 663
Yes, they confirmed me the BF sale.
SLE3PER1658.50 GolfCoyote2141.00 |
| 11-12-2025, 02:20 PM | #70 | |
![]() 23
Rep 30
Giak232.00 vwSHANEg803.00 |
| 11-16-2025, 09:23 AM | #71 | |
Rep 663
| 11-16-2025, 12:28 PM | #72 |
...bitching about brake trouble...
4151
Rep 2,582
Drives: 21 X5MC | 23 M4CSL
More details needed about your front geometry - are you lowered, if so how much? Have you altered the offset either with spacers or lower offset wheels? Are your front control arms and tie-rod ends stock? What is your front toe setting? Do you drive in the rain a lot?
In general, more caster is a benefit but depending on your setup it may be even more helpful in steering feel, centering than the added protection of sealed bearings. |
| 11-16-2025, 04:00 PM | #73 | |
Rep 663
Probably I will install coilovers in the future, but I decided not to install lowering springs in the meantime, I am afraid the car could handle worse and the oem shocks could suffer more. I tried spacers (15mm F, 12mm R) but I removed them after 2 days because they introduced a lot of understeer and I experienced more body roll. If I will buy new wheels I will take them with lower offset for sure, but only for an aesthetic reason. This is my only car and I use it in every weather condition. I don't drive it daily, but I use it in the rain, even in the snow (very rarely), whenever I need. Actually, toe in is +0°05' in the front. Installing the control arm bushes is a PITA, then I don't want to have any issue in the future and need to do the job again. Thank you Last edited by Giak; 11-16-2025 at 04:04 PM.. |
| 11-16-2025, 04:04 PM | #74 |
4151
Rep 2,582
Yes, RWD is a huge pain I know first hand. Given what you said it’s really dealer’s choice on which caster bush to go with but I’m leaning towards the neutral sealed for you.
Giak232.00 |
| 11-23-2025, 07:50 AM | #75 |
![]() ![]() ![]() ![]() 944
Rep 742
Giak
What are your tire pressures and what does the tire wear look like? The only way to know if you need more camber is to look at the tires. Adding tons of extra camber if you are not rolling over the tire and getting excessive outer edge wear won’t improve anything and will just come with compromises. If you are rolling over the tire, then sure the sudden breakaway in grip can lead to less steering feel but if you aren’t pushing the car that hard adding more camber does nothing at all to improve steering feel. Similarly, while more positive caster is always good, it increases self centering force and improves dynamic camber, the stock setup is already aggressive at ~8 degrees. Installing camber plates with caster offset and only gaining 0.5 degrees will do very little at expensive costs and potential increase in NVH. As others have said your best bet is do monoballs on the front thrust arms first. You can also add some spacers up front, the extra track width will also increase self-centering force and give a little more feel (make sure to get high quality hub centric so you don’t get vibrations). Also rear traction arms will help mostly with wheel hop. Rear toe links are needed if you have very aggressive track alignment. You can get close to ~-2 to ~2.2 negative camber on the rear stock toe arms using the eccentric bolt before you can’t adjust the toe anymore. Unless you are running over -2.8 camber in the front (which you won’t for a street setup) there is no need for rear toe arms yet. You will just increase NVH with little improvement. ETA: You want to improve steering feel you need to tackle the deflection in bushings. ![]() ![]() Top mounts (via camber plates) when done right will have minimal increase in NVH. Thrust arm mono balls will help a lot longitudinally under braking and acceleration and a bit under cornering. Will add a little NVH. Front Lower Control arms will tackle a lot of the lateral slop but will add quite a bit of NVH. Do all three and you really tighten everything up and significantly improve feel but the combined approach will introduce a lot of NVH. Last edited by AdonisP91; 11-23-2025 at 08:33 AM.. |
| 11-23-2025, 03:34 PM | #76 | |
Rep 663
My usual cold tyre pressures are 2.3 bar front and rear, for street use. When I go to the track, I start at 1.9 bar cold, which gives me around 2.3 bar hot. Michelin PS4S* Front tyre wear is almost even, with slightly more wear on the outer edge. After a track session, the outside shoulder shows more visible wear, up to the Michelin lettering. After installing the SS camber plates, I wouldn’t go for excessive negative camber — just about –0.60° more than stock, reaching around –2.4/–2.5°. Combined with the +0.5° caster, that should already be a solid improvement. Front control arm bushes are on the list as well, most likely the sealed non-offset version. I tried wheel spacers last year (15 mm front / 12 mm rear), and I had to remove them because they caused unwanted understeer. I don’t really see how running front spacers only would be beneficial. Rear toe arms are important not only for static alignment but also to prevent toe changes under load. NVH increase shouldn’t be very noticable with the three planned mods: – SS Camber plates + caster – SS Monoball front control arm bushes – SS Rear toe arms What you’re saying is theoretically correct, but are you speaking from direct experience with the G8x platform? Last edited by Giak; 12-07-2025 at 10:18 AM.. |
| 11-23-2025, 05:24 PM | #77 | ||||||
Rep 742
Take a look at this photo, and the triangle/arrow marking built into the ps4s*. If you wear past it (like if it disappeared), you need to either increase pressure or add more camber. You can increase pressure only so much before the tires get greasy. The PS4S*’s sweet spot in my experience is around 2.3 to 2.5 hot on track. If you are wearing below it (only half gone or not even reaching it), too much towards inside of tire, you can decrease pressure or decrease camber to let the tire use more contact patch area. The ideal pressure and ideal camber front and rear will not be the same. Quote:
Aside from steering feel, a lot of these issues are just fundamentally about changing the factory configuration which is severely biased towards understeer and daily driving. Same pattern repeats itself, start with dialling in the alignment for track or aggressive driving, now you notice the car with all the extra grip suffers from too much body roll, so you lower it and stiffen it up. Now you notice it really exposes the play in rubber bushings, so you go full spherical/monoballs. Next after you maxed out mechanical grip it is time to slap on some aero kits for down force, but then you need more power, etc. Eventually when you reach the end of the line on the platform so it is time to move to the next platform and start the process from scratch. Last edited by AdonisP91; 11-23-2025 at 06:48 PM.. |
| 11-23-2025, 06:54 PM | #78 |
![]() 23
Rep 30
Suspension Secrets black friday sale is live! (UK time difference FTW!)
pdxgardener148.00 |
| 11-24-2025, 06:56 AM | #79 |
Rep 663
I have placed the order right now.
Hope that NVH will not be too much noticeable. This is my outer edge, tyres have 19kmiles anda total of 3 sessions {25min each) on track. It seems I defenitely need more neg camber. |
AdonisP91943.50 vwSHANEg803.00 |
| 11-24-2025, 07:15 AM | #80 |
Rep 742
Yep definitely need more up front, and in the rear if they look the same as the fronts. Your pressures are good and the arrow/triangle indicator looks like it wore off completely (my tires look exactly the same). At least the tires look like they are wearing well, no chunking/cording yet.
| 11-24-2025, 12:31 PM | #81 |
![]() 23
Rep 30
Order Placed. Was originally going to order the:
- CS+ kit - Rear traction arms - Offset caster bushing. I spoke to SS (awesome customer service) and since I already have the KW HAS kit ready for install, they suggested to order the handling pack 1 which includes everything but adds the drop links and rear toe arms with Lock-out. I added the traction arms as well. This should keep me planted on my spirited morning coffees runs. HA! I also confirmed that they also include the set up sheet for fitting/adjusting for the service techs. |
| 11-24-2025, 12:47 PM | #82 | |
Anesthesia
1659
Rep 762
| 11-24-2025, 04:35 PM | #83 |
![]() 23
Rep 30
Yup. Not sure if it was because it was already in the previous order though. From my endless reading, its on the top of the rabbit hole if you're going down the parts list. Good addition if youre already back there
| 11-25-2025, 11:35 AM | #84 | |
Rep 663
| 11-29-2025, 08:54 AM | #85 |
![]() 62
Rep 68
For those of you still following this thread, if the goal is to add more feel (at the expense of some NVH) on a road and sometimes track situation, do you think adding the camber plates and toe arms from SS would satisfy that itch? Similar to what Giak suggested above.
Or would adding front LCAs be worth while too? I'm not lowered although perhaps in the future that might change a smidge, would prefer to keep the EDC. |
| 12-01-2025, 09:15 AM | #86 |
![]() 23
Rep 30
Had the KW HAS on my 2023 g82. There's about a finger gap between the fender and tire. I took those off and will be running them in in 2026 g82 at the same height. Pics of my 2023 lowered, attached.
vwSHANEg803.00 |
| 12-01-2025, 11:00 AM | #87 |
Rep 663
I am also considering to install the KW HAS kit, but i will set it to the minimum drop of 15mm front and 10/12mm rear.
In my opinion there is no need to install swaybar endlinks for such minimal drop, since it is not introducing any preload to swaybars. Only reason to have them is if you want to corner weight the car. About KW HAS kit, do you consider it an upgrade from the performance point of view also? I mean lower bodyroll, better handling, etc. Last edited by Giak; 12-01-2025 at 12:53 PM.. |
| 12-01-2025, 04:05 PM | #88 | |
![]() 23
Rep 30
| Bookmarks |
