03-11-2024, 02:09 AM | #68 |
Rep 7,033
Id like to see someone doing these single setups with the XONA rotor turbos.
YT: G Dubyou |
03-11-2024, 02:25 AM | #69 |
i can haz horsepowr ??
3870
Rep 1,951
Not looking to push more than about 850whp or so on E85. On 93, I'll take any safe amount of power that the stock manifold and torque my clutch can take. Being a 6MT means being RWD and not being able to put down power easily. The primary purpose of the single turbo has been to bathe my ears in aural pleasure from turbo sounds, waste gate fluttering, and big smiles from being hit by big boost after every shift.
Tough to say as its based off if you're doing the install yourself or paying a shop, which turbo you choose, port and fueling, already unlocked DME, etc. I'd say, set aside close to $20k to ensure everything is running smoothly. Figure the following costs I've incurred: DOC Race: $9kish RTP Turned MaxxECU port controller (includes ethanol sensor): $2kish Precision Raceworks LPFP: $1.5 ~ $2k Precision Raceworks fuel rail + injectors: $1k ~ $1.5k Tune: $700 ~ $2k depending on tuner and how much they cost assuming you're on MHD/bootmod3 already. Parts alone can run around $15k. Figure around $2k~$3k for install. This doesn't include a transmission upgrade from Pure Drivetrain Solution for xDrive folk.. something you'll want as you'll start slipping on big power from a big single turbo.
Dakar Yellow G80 M3
BrikM36.00 Limegrntaln13707.00 |
03-11-2024, 07:52 AM | #70 | |
Rep 1,467
03-11-2024, 08:16 AM | #71 | |
Rep 102
For the exhaust blow down, with four or more cylinders, the cylinder that fired previous to the current firing cylinder will still have its exhaust valve open when the current cylinder opens the exhaust valve and has a blow down. This will shove exhaust gases back into the "previous" cylinder, increasing hot residual gases and knocking propensity. Twin scroll separates the engine into halves to eliminate the pathway for that interference. With a three-cylinder, which is effectively what each half of a S58 with twins is, the firing events are spaced far enough apart that there is no chance of interference, so no point of separating things into multiple scrolls. For the "smaller" turbine, when the manifold is segregated to make twin-scroll, it cuts the effective volume of the manifold in half, so more of the blow-down energy stays as high pressure going into the turbine, instead of the energy being wasted raising the pressure of the larger manifold, but now by half as much. An S58 with twins already has a small enough volume in each exhaust manifold that there wouldn't be much of gain trying to make three scrolls. Prototypes do exist, but the cost-benefit isn't there. Also, the benefit with twin-scroll is mainly around low-rpm performance. At high rpm the smaller scrolls end up being constrictive and it's better to be mono-scroll. Twins have better drivability because, in addition to their native twin-scroll-like performance, the shaft inertia is smaller allowing for faster spool. If you want your high-BMEP engine to feel like a larger naturally aspirated engine, the twins are great. OEM's aren't designing for big turbo hits, spooling noise, whooshes, etc. Like everything in life, it's all about the tradeoffs. |
Blue Angel1042.50 |
03-11-2024, 08:16 AM | #72 | |
3870
Rep 1,951
Such is life, unfortunately. But yeah, GTR is still top dog for now alongside TT Huracans for sure.
Dakar Yellow G80 M3
03-11-2024, 10:46 AM | #73 | |
Rep 1,467
03-11-2024, 03:25 PM | #74 |
Rep 192
For big big gains a higher compression 10 or 11:1 stroker (with factory 84 mm or increased to 85mm) with headwork will be the leader in power. Mid range with higher compression will be a monster and allow increased spool on bigger turbos then the 7275 or 7480 we are running. I was about to do this to mine but I don't have any use to go over 1300 wheel right now so I just sent mine off to get Kelford cams, valves, springs and a fire ring gasket.The head doesn't really like when you put over 50lbs of boost to it lol
Still super early in the game. We just got our first standalone (just ordered that so I can throw my Motiv in the trash lol).GT-R has had 15 years of R&D compared to the S58 platform. Plus to go for 1700 wheel in a GT-R you could buy 2 of our cars lol I love me a GT-R, it's just cool to watch this S58 advance over time. |
DocMus0.00 |
03-11-2024, 11:25 PM | #75 |
Rep 984
Don't we already have a 2.9sec 100-200kmh G80? I'm sure once we put a stroker in it, it would be able to keep up with 1500whp TT Huracons then
2022 M3 XDrive - Full Race Turbos - BMC Filters - MAD Catless downpipes - MAD single midpipe - BM3 Flex Fuel Kit - Paul Johnson Flex Fuel - XHP - MPHAS - EBC Bluestuff - PS4S
2023 IX M60 2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09 |
03-12-2024, 09:36 AM | #76 | |
Rep 192
My buddies TT lambo is currently around 3.8 on his regular setup but he has another 400hp he can throw at it on the fly haha. My other buddy has a procharged viper on motec and hes mid 3's. Our cars have come a long way and soon enough you will see a 2.xx 60-130 when some of these shops get more testing and products. 3 years in to a platform for BMW I'd say we are doing very well lol. Rick's car from MLIFE when it comes out is going to be an animal considering he trapped 8.5 at 137 with him coasting from 1000ft. |
03-12-2024, 02:29 PM | #77 | |
Rep 984
2023 IX M60 2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09 Last edited by SE7EN335; 03-12-2024 at 02:37 PM.. |
03-12-2024, 03:36 PM | #78 |
Rep 310
Rooting for you guys to take down GtRs and Huracans.
Love how much progress is being made in this platform in such a short amount of time. 🔥🤝
//M is awesome
03-12-2024, 05:48 PM | #79 | |
BM3 Tuner
391
Rep 325
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, Nostrum Big Bore HPFP, VTT PCV and Oil cap, HnR springs.
Paul Johnson Tunes Shop/Development Car |
FSociety3816.50 |
03-12-2024, 09:25 PM | #80 | |
Rep 1,069
03-13-2024, 10:21 AM | #81 |
Rep 192
03-13-2024, 11:31 AM | #83 | |
Rep 137
03-13-2024, 11:41 AM | #84 |
I'd hit it
1066
Rep 1,107
Something new from RK Autowerks… they haven’t released it yet but I believe it’s 3 fuel pumps…. They know my goals and said that it will support them
2023 M4 xd BSM IG: MFor_YourPleasure |
03-13-2024, 04:56 PM | #85 |
I'd hit it
1066
Rep 1,107
Kept it pretty tame… lots of potential for when I go built engine
03-18-2024, 10:31 AM | #86 |
I'd hit it
1066
Rep 1,107
The RK team put together a vid of the build:
I had to change the song because it wouldn't display on YT because of copyright but this one works lol
Sinister84035.00 |
03-18-2024, 11:16 AM | #88 |
I'd hit it
1066
Rep 1,107
