02-12-2023, 03:00 PM | #67 | |
Rep 720
02-14-2023, 02:10 AM | #68 | |
///MFlight Member
458
Rep 249
Current - 2022 M3 G80X Competition/Brooklyn Grey/Silverstone
- 2022 X3 M40i/Brooklyn Grey Sold - 2021 M3 G80 RWD Competition/Brooklyn Grey/Merino Black Follow Me on IG: BrooklynGreyM3 |
Limegrntaln13705.50 M4Tejas846.00 |
02-14-2023, 11:08 PM | #69 | |
Rep 8,364
02-15-2023, 03:11 PM | #70 |
Rep 720
It is an independent, but with all the computers and program access from BMW, the dealer sometimes sends cars for him to dx as he used to be their master mech. He promised me he will. Only time will tell.
02-15-2023, 03:13 PM | #71 |
Rep 720
We are friends so I am sure if he can do it, it will be done. If not, no more wine for him. lol.
02-16-2023, 07:19 AM | #72 |
Rep 620
I lost my coding after the software update.
I see now there are two different coding for anti dazzle. What’s the consensus? Do you guys use the original coding or the new one? Thanks! |
Unimatrix074.00 DocWeatherington2949.50 |
03-19-2023, 07:13 PM | #73 |
///M
120
Rep 108
Drives: 2023 M3C (due May)
Has anyone programmed anti-dazzle with idrive 8 using BimmerCode? (I know it is only 90% anti-dazzle)
03-20-2023, 03:23 AM | #74 | |
Rep 8,364
Not programmed, but coded; yes. |
03-24-2023, 02:48 PM | #75 |
Rep 36
I followed this guide (https://g80.bimmerpost.com/forums/sh...php?p=27650517) on my iDrive 8 2023 M3 and am not getting the anti-dazzle lights to work. Anyone have an updated guide? Or does anyone have Vmaxx's guide but showing what category in the BDC Expert Mode?
03-24-2023, 02:59 PM | #76 | |
Rep 47
03-24-2023, 06:45 PM | #77 |
Rep 36
I have the headlights on at night with auto high beams enabled. I'm not seeing any high beams enabled when driving above 40MPH where the tunneling of low beams on cars in front. I only see high beams enabled when no cars are in front of me at all.
03-25-2023, 06:54 AM | #78 |
Rep 47
Coding must be off or you missed something.
Mine works, I used only Bimmercode so it's not fully activated. Works when: Over 40 mph when there are cars in front and on the highway. (Can see the "Tunneling" going around the vehicle in front or moving to the right or left) It does turn off when: Street lights are plenty and bright, strait upcoming traffic or lots of reflective street signs. Try using a backup to undo your changes, then try again. When coding I always go in airplane mode on the phone, turn of lights, radio and heating/cooling and buckle up the drivers seatbelt. (Stops the car from turning off) and leave the drivers door open. |
M4Tejas846.00 |
05-04-2023, 05:16 AM | #79 |
BMW DRIVER ///M
106
Rep 317
Is there a code sheet on the correct values to code anti dazzle on a 2022 g80 m3 ?
I have esys and bimmer utility Just looking for the correct values |
05-04-2023, 02:53 PM | #80 | |
Rep 47
BDC LA1 C_BLC_PRE_ENA | 1 LUT_FLC_FORWARDLIGHTING_Y | AFS LA2 C_AFS_ECO_LEVEL_3_ENA | 01 C_AFS_ENA | 01 LA3 LUT_AFS_CODRV_HOR | standard/init LUT_AFS_DRV_HOR | F040_G005_AHL... C_CLC_CURV_V2 | 23 C_CLC_CURV_V3 | 28 C_CLC_EXT_ENA | 01 C_HBA_DIM_ENA | 01 C_HBA_GFHBA_ENA_V_HI | 3C C_HBA_GFHB_ENA | 01 There are 4 more codings in the lane assist camera "KAFAS04" which we cannot currently access with bimmercode. Supposedly these will make the auto dim less aggressive while also making the beams tighter. The HBA will still perform extremely well without these changes. These can be changed with Esys. I HAVE NOT TESTED THIS AT ALL ON G8X. IF YOU HAVE ESYS, PROCEED WITH CAUTION. C_FLA_COUNTRY_WITH_MULTIPLE_REFLECTORS | 01 C_FLA_US_SENSITIVITY_MODE | 00 C_FLA_BS_ENTER_THRESH | 03 C_FLA_BS_EXIT_THRESH | 02 Again this is not my coding, used it from a fellow member... |
05-07-2023, 08:59 PM | #81 |
Rep 3,446
Gonna have to re-code the car after the OTA update, so I figure I'll give anti dazzle a go. However I can't make sense of everything you need to do in order to get it coded. I've read the guide linked above and genuinely can't make any sense of it. Can someone point me in the right direction.
Car is a 22 with iDrive 7, using Bimmercode with an iPhone plugged directly into the OBD port with a dongle. I've coded the basic stuff in Bimmercode like chimes, warnings, etc...is anti-dazzle just another menu I may have missed, and it's a simple on/off toggle? Or do you have to go into advanced settings and mess with stuff? If so, is there a good how-to on this? Last edited by FC4; 05-08-2023 at 12:09 AM.. |
05-08-2023, 07:24 AM | #82 | |
Rep 898
For Example : The Module you want to code is BDC, then find LA1 section, open it, and code those 2 parameters per the instructions (it's just a checklist of params). Repeat for the remainder. |
FC42759.00 |
05-11-2023, 02:50 PM | #83 |
BMW DRIVER ///M
106
Rep 317
When you code the euro style and the headlight modules you can have it with out the side markers
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey 2004 E46 M3 White END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci |
05-11-2023, 03:19 PM | #84 |
BMW DRIVER ///M
106
Rep 317
I have also seen posts saying that when the anti dazzle is running for a long time it can cause fogging in the headlamps.
I’m not sure if this 100% true but I have seen others forum posts about it. I have checked the temps after the headlights have been running for 30 minutes in 80 degree weather using the anti dazzle and haven’t noticed any heat issues.
Current
05-11-2023, 04:13 PM | #86 |
BMW DRIVER ///M
106
Rep 317
I think it’s related to coding in the light module it’s self to remove it.
In Europe or other markets they don’t have the light marker I noticed clearly it’s a DOT thing in the US
Current
05-11-2023, 08:31 PM | #87 |
You got my money?
3248
Rep 4,716
Drives: Ice Cream Truck
Say that again? How did you accomplish this?
05-11-2023, 08:42 PM | #88 |
BMW DRIVER ///M
106
Rep 317
You need esys and bimmer utility to code the light modules.
It won’t work with bimmercode Bimmer code only allows you to code the BDC module
Current
