06-19-2022, 08:37 AM | #67 | |
![]() 171
Rep 233
-2022 G82 M4 Comp Xdrive: Portimao Blue, Fjord Int., P.A.P, Exec.Pkg, Laser lts., Carbon Fiber Ext., M Performance Rear Spoiler
-2018 F80 M3 Fully Loaded -2011 F10 550i M-Sport -2006 Saleen S281 Supercharged |
06-19-2022, 09:47 AM | #68 | |
![]() 29017
Rep 199,386
Posts ![]() |
Like everything else in life, nothing is 100% guaranteed. The odds of running into issues are very close to zero. If you are not comfortable with these odds, you are not ready to tune your car yet, and that's okay; the vehicle has more than enough power stock.
https://x-ph.com/sale/ Phone number 702-494-9435 ![]() |
06-19-2022, 10:41 AM | #69 | |
![]() ![]() ![]() 300
Rep 518
No one here is going to know the real details of how any of this works. BMW won't share how they detect and tuners won't share how they avoid detection. |
08-01-2022, 11:51 PM | #70 |
![]() 71
Rep 58
Drives: 2021 BMW M3 Comp
Newb questions. I see all the videos on how to install the JB4, but I dont see anything about how to load the files once installed and what each map means. I see there are a ton and each map seems to do something different. Any info on this?
08-02-2022, 09:39 AM | #71 |
![]() ![]() 422
Rep 298
When you pull up the JB4 app and it's connected to your vehicle, I believe you press Settings and then press Map. The maps on the next page should say what they are and required fuel (91, 93, e30, etc). Verify map change on the Gauge layout screen.
![]() C8Z 3LZ Z07, E92 M3 6MT Previous cars: '22 M3Cx, '21 Supra, '17 GT-R, '15 GT3, '13 GT-R '09 GT-R, '06 Z06, '06 Evo MR, '05 M3, '03 Evo, '00 Miata. |
Celticsfan34life70.50 |
08-02-2022, 05:23 PM | #72 |
![]() 29017
Rep 199,386
Posts ![]() |
Select map from the homepage, next to each mao you can find a brief description on what its recommended to be used
08-04-2022, 05:12 AM | #74 | |
![]() 29017
Rep 199,386
Posts ![]() |
08-04-2022, 01:52 PM | #76 | |
![]() 120
Rep 109
I will when I install. I plan to double-side tape it inside the plastic cover. |
08-04-2022, 04:13 PM | #77 |
![]() ![]() ![]() ![]() 556
Rep 583
Drives: '19 GLA45AMG(his) / '21 X3M40i
This is a must (flexfuel kit), if you ask me.
E85 accuracy varies from pump to pump. Then add the tedious task of keeping track of how much of what you have on the tank. And I believe the recommended usage of e85 is 3:1 Run 1 full tank of premium after running 3 tanks of e85mix; they say is good for the fuel system components (just fyi).
Currently: '23 X3M white (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2019 GLA45AMG (grey) 2014 BE GTR FBO/e85 |
08-04-2022, 05:39 PM | #78 | |
![]() 120
Rep 109
iirc, JB4 measures octane... i swore i wasnt going to mod this car. lol. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. i WILL NOT remove the cats. |
08-04-2022, 08:08 PM | #79 |
![]() ![]() 264
Rep 374
Here's how mine is installed. I normally have a zip tie around the jb4 box buy took it out to rewire the flex fuel kit wire to it. I need to reattach the zip tie.
08-05-2022, 02:58 AM | #81 |
![]() 29017
Rep 199,386
Posts ![]() |
08-05-2022, 11:51 AM | #82 |
![]() 120
Rep 109
08-05-2022, 01:21 PM | #83 |
![]() ![]() 3864
Rep 2,933
Only if you fill up the whole tank with ethanol then it shouldn't matter. But if you think you have e50 in there don't run the e50 map, go with something lower to be safe.
08-05-2022, 03:54 PM | #84 |
![]() 120
Rep 109
my approach would be to run the most aggressive map for 93 octane and when that is empty, most aggressive map with a 1/4 tank or so of e85. id make the decision pretty quickly, i think.
08-07-2022, 10:01 AM | #85 | |
![]() ![]() ![]() ![]() 999
Rep 786
2022 M3 Xdrive Frozen Dark Grey - 4/27.
2016 Charger Hellcat - 908 RWHP & 988 WTQ 9.9@ 140 - 2012 - Charger SRT 392 - Sold 2009 - Charger SRT 6.1 - Sold |
08-10-2022, 04:10 PM | #86 |
Rep 15
holy f*** i'm in the middle of installing it a second time (first time there was an issue with the bluetooth connection) and for the life of me i cannot get that tmap sensor all the way at the bottom removed. i don't know how i got so lucky the first time around.
08-10-2022, 06:01 PM | #87 |
Rep 15
i'm so flipping angry. finally got everything installed (figured out the trick with the tmap sensor too) and i'm still getting the same errors. drivetrain issue, chassis stabilization issue, and no bluetooth connection. i'm 99% i have a defective unit and am so very excited that i get uninstall it yet again. debating if it's even worth asking for a new unit vs. a refund and keeping it stock.
08-11-2022, 01:46 AM | #88 |
![]() 29017
Rep 199,386
Posts ![]() |
i would not run it without the flex fuel kit.
