08-20-2022, 09:00 AM | #67 |
Rep 116,037
08-24-2022, 10:20 AM | #68 |
Rep 116,037
08-31-2022, 03:51 PM | #69 |
Rep 116,037
09-05-2022, 04:39 PM | #70 |
Rep 116,037
09-10-2022, 01:43 PM | #71 |
Rep 116,037
09-17-2022, 11:44 AM | #72 |
Rep 116,037
09-26-2022, 12:13 PM | #73 |
Rep 116,037
09-29-2022, 11:38 AM | #74 |
Rep 116,037
10-11-2022, 01:46 PM | #75 |
Riding the knock sensor
2431
Rep 1,616
Drives: 21 X5MC | 23 M4CSL
How does the JB4 behave across the various OEM tune levels? For example, will a non-comp (18.4psi), a comp (24.7psi), and a CSL (30.5psi) all produce the same power on the same map (ie #2)? Is it possible the JB4 would add no power to the CSL on pump gas?
10-12-2022, 12:35 PM | #76 | |
Rep 116,037
I've not seen any factory maps that run more than around 24psi. Comps seem to peak at around 22psi. Mike |
10-12-2022, 02:06 PM | #77 |
2431
Rep 1,616
You have to question with the CSL whether a piggy back will make any more power on pump gas. The additive maps can request more peak boost over stock, but if stock peak is already 30.5 I can't imagine there's any more juice to squeeze.
10-13-2022, 12:22 PM | #78 | |
Rep 116,037
Like I mentioned above I don't think I have seen anything above 24 range.. Mike |
10-13-2022, 12:40 PM | #79 | |
2431
Rep 1,616
The turbocharger's power output is further enhanced by the use of an indirect intercooler supplied by a low* temperature circuit and specially designed compressors. Boost pressure has been increased from 24.7 psi in the M4 Competition to 30.5 psi in the CSL. Engine management has been modified accordingly to guarantee the constant power delivery up to the top end of the rev range that has come to be expected of BMW M.
10-17-2022, 09:19 AM | #81 | |
Rep 116,037
Did you need the bluetooth module with that or just the JB4? Mike |
10-18-2022, 08:13 AM | #82 | |
Rep 14
10-26-2022, 09:41 AM | #84 |
Rep 116,037
10-31-2022, 08:53 AM | #85 |
Rep 116,037
11-01-2022, 07:55 AM | #86 |
Rep 116,037
11-02-2022, 12:15 PM | #87 |
Rep 116,037
11-08-2022, 12:40 PM | #88 |
Rep 116,037
