      08-25-2020, 06:11 PM   #67
JTO24
JTO24's Avatar
Drives: 2022 G80 M3 6MT
Originally Posted by lemetier View Post
Der Fledermaus wasn't mentioned
"The Bat" aka the batmobile aka the concept Frosty posted... interesting
      08-25-2020, 06:23 PM   #68
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Have to mark the occasion with something more than a concept
JTO245282.00
      08-25-2020, 07:25 PM   #69
brad850csi
Drives: 16 F13 M6 Comp
Turbine Energy Recovery System (electric-compound turbochargers)
https://www.garrettmotion.com/electric-hybrid/
or
https://demanddetroit.com/engines/dd16/ (probably not)
Can the current Garrett tech work both ways? The name sounds like it might be able to (instead of a wastegate???) then be used to spool the turbo back up again
      08-25-2020, 07:30 PM   #70
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
or
Borgwarner eTurbo.
Holset278.50
      08-25-2020, 07:40 PM   #71
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
Drives: A Car
Borgwarner eTurbo.
I Wonder if it will be similar to the system in my CLS which uses an electric supercharger that runs off the 48-volt mild-hybrid system. Its awesome technology, gives the engine incredibly smooth output (almost NA-like), and provides plenty of power before the turbo is finished spooling, and even makes start stop so seamless I never have to turn it off. I love this tech in my CLS and would love to see BMW adopt it.
This instagram post by Jason Cammisa better explains the awesome technology
The 3.0-liter M256 straight-six ⁣⁣⁣⁣makes 429 hp and 384 lb-ft. But forget everything you know about turbo engines: it responds, sounds, and pulls like a big NA V12. ⁣⁣⁣⁣Bonus: same MPG as the 4-cylinder E300 4Matic!
⁣Its trick? It a @borgwarnerincperformance electric supercharger called an eBooster.⁣⁣⁣⁣
⁣⁣⁣It spins from idle to 70,000 rpm in only 0.25 seconds and generates almost 7 psi of boost.⁣⁣⁣
⁣⁣Powered by 48V battery and takes 5000 watts (7 hp!) to spool up... but that boost gives you ~10x that power out the engine. That means you don't need to have a huge, heavy 70-hp electric motor to fill in. ⁣⁣⁣
⁣⁣⁣⁣(The McLaren P1 used a 177-hp #torquefill motor. Acura NSX used 3: 36, 36, and 47 hp! That is HEAVY.)⁣
⁣⁣⁣⁣⁣The M256 also has a small electric motor — 21-hp, 184 lb-ft — and it replaces the flywheel, starter, and alternator. It also provides torque-fill while the eBooster and turbo spool.⁣⁣⁣
⁣⁣⁣⁣Once the regular turbo spools up, the eBooster and motor fade out. ⁣With so many things to coordinate, this could have been a bucky, surgy disaster. Mercedes knocked it out of the park — this has the best boost control of any engine I've ever experienced. Coming on the throttle or off the throttle (which is just as difficult to manage), it responds like an na engine. And best of all, it's a #straightsix with all the smoothness and sound. ⁣⁣⁣
KoenG1440.00
///M TOWN22185.50
      08-25-2020, 07:46 PM   #72
brad850csi
https://cdn.borgwarner.com/docs/defa...sn=93bccf3c_19
Electric motor can assist the turbine to provide supplemental boost air to the engine
Electric motor (generator) can be driven by excess turbine energy from the exhaust flow
Exciting
BMWGirlFL6377.00
      08-25-2020, 08:10 PM   #73
ukr
Drives: bmw
In the video sounds like 4 cylinder. Exhaust doesn't look like it's routed from the front engine. Kidney grill shut indicates less cooling requirement, all pointing to a 4 cylinder with some hybrid tech.
      08-25-2020, 08:33 PM   #74
BMWGirlFL
BMWGirlFL's Avatar
Drives: Z4 M40i
Exciting
https://www.borgwarner.com/newsroom/...bo-application
Ibiza3649.50
KoenG1440.00
      08-25-2020, 09:28 PM   #75
HolyChitMeng
HolyChitMeng's Avatar
Philippines
1300
Drives: 2009 E93 M3
2008 E90 M3  [0.00]
1995 BMW M3  [0.00]
2004 BMW M3  [0.00]
2011 BMW 335xi  [0.00]
2011 BMW 335is  [0.00]
2009 BMW M3  [0.00]
Really interested to see what this is, haven't been intrigued by a BMW test mule in a while.
Ibiza3649.50
      08-25-2020, 09:46 PM   #76
BeeMdblU
BeeMdblU's Avatar
Drives: F86, F25, G16
It's most likely an LCI, the lights are similar to the 4 series
Ibiza3649.50
      08-25-2020, 10:35 PM   #77
Ibiza
Ibiza's Avatar
Drives: 22 G83 comp & 2024 X5 M60
Something else is up, the engine if it's a P58 sounded great!
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD
      08-25-2020, 10:36 PM   #78
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
What lights are similar to the 4er?
      08-26-2020, 02:32 AM   #79
marckwan
Drives: 2013 E92 M3
These news are a joke, it's just a twin turbo v8 with hybrid technology.
      08-26-2020, 05:34 AM   #80
KoenG
Belgium
1440
Drives: i4 eDrive40 & Cupra Leon 300
A PHEV with a 4-cyl TERS combined to ~500hp would make perfect sense! Upcoming Mercedes C AMG will presumably also get this configuration!
https://mercedes-world.com/c-class/m...ic-4-cylinders
JustChris17607.00
      08-26-2020, 05:36 AM   #81
Boss330
Boss330's Avatar
I think lemetier inside knowledge has debunked that theory...
It definitely sounds like a straight six in the video that I posted on the previous page (listen with headphones to get the best sound).
The info provided so far points towards a anniversary special limited edition model that has a P58 engine with MGU-H and possibly MGU-K (to use F1 lingo) and a transaxle. The CSL hommage is a pointer as to what kind of car this will be (hopefully).
Oh, and the Batmobile celebrates 50 years in 2023 btw...
This article on the CSL hommage also gives som hints as to why the mule has the air ducts in the rear side windows:
https://www.carmagazine.co.uk/car-re...e-2015-review/
The engine is hooked up to 4-series coupe running gear, a stock eight-speed automatic transmission and the largest brakes Brembo could supply. There is no word on power and torque, but with two turbos and one e-boost device, 500bhp or more should be a realistic. The boost system’s twin energy reservoirs sit under eye-catching covers atop the rear axle, where lesser coupes would accommodate second-row seats.
And I also remembered this YouTube video on the CSL Hommage by Supercar blondie where the head of BMW Design said something very interesting about possible production of the car.
The whole video is worth seeing, but skip to the 13:00 mark to hear what he says about production possibilities
      08-26-2020, 06:30 AM   #82
KoenG
Belgium
1440
Apparently, it's none of the above. It's just a test mule used to test all kind of new technologies.
Source: auto motor und sport:
Bei dem Erlkönig-Modell handelt es sich – wie schon vermutet – um einen Entwicklungsträger, mit dem unterschiedliche Abteilungen des Konzerns neue Komponenten testen. Das kann von Fahrwerkselementen, Reifen, Bremsen, Motor-Neuentwicklungen, Abgas-Komponenten bis hin zur Multimedia-Technik alles sein. In diesem Fall hat BMW einen M8 als Träger verwendet.
Also BMW denied working on any config with central mounted engine.
stein_325i25175.00
      08-26-2020, 07:12 AM   #83
Boss330
Boss330's Avatar
Exactly and that doesn't contradict anything I posted...
It's not mid engined (that was debunked early on in this thread) but it's most likely a test mule for the upcoming (hopefully) CSL Hommage drivetrain etc.
Front engine, straight six, hybrid tech, possibly transaxle.
JTO245282.00
JustChris17607.00
      08-26-2020, 07:47 AM   #84
BMWGirlFL
BMWGirlFL's Avatar
Drives: Z4 M40i
May 2022
Originally Posted by Boss330 View Post
The info provided so far points towards ... a P58 engine with MGU-H and possibly MGU-K (to use F1 lingo) and a transaxle.
I think Boss330 is right about 'info' but confused because May SOP suggests Spartanburg?? Wondering if equipment being tested is for more than 1 vehicle.
JTO245282.00
      08-26-2020, 08:50 AM   #85
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
May 2022
The 50th Anniversary of Bmw ///Motorsport and launch of the E9 3.0 CSL is May 1, 2022.
JTO245282.00
Boss3301721.50
      08-26-2020, 10:38 AM   #86
Boss330
Boss330's Avatar
More sights and sounds of the test mule.
      08-26-2020, 12:26 PM   #87
530iDriver
530iDriver's Avatar
Drives: 2017 BMW 530i
Interesting that the wheels, front arches, brakes and front bumper are m850i spec, not m8 spec but it has 4 round pipes
edit - while the 4 pot calipers look the same as on the m850i the discs are drilled which is more in line with the X3M front brakes.
There's a lot of weird parts bin stuff happening, even the mirrors look like they're from an E36 M3.
Mmmm is a test mule. It will be a strange mish mash parts bin special.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness....
      08-26-2020, 01:25 PM   #88
supra93
Drives: Z4, E500, Supra, RX7
Maybe another collaboration with Toyota?
https://bestcarweb.jp/backnumber/186524
