| 10-31-2025, 08:16 PM | #45 | |
Anesthesia
1659
Rep 762
| 11-01-2025, 02:31 AM | #46 |
![]() 148
Rep 78
I am a bit confused with the Suspension secrets front monoballs, namely, which one is the correct one:
Suspension Secrets Solid Front Control Arm Bushes: https://shop.suspensionsecrets.co.uk...ush-bmw-g80-m3 or Suspension Secrets Front Offset Caster Bushes: https://shop.suspensionsecrets.co.uk...-g80-m3-g82-m4 |
| 11-01-2025, 07:32 AM | #47 |
![]() ![]() 6795
Rep 5,260
^^^ Either one fits and works, but one is offset to provide dynamic camber as you turn the wheels and the other one doesn’t. Both provide a solid bushing to get rid of play and improve steering feel.
| 11-01-2025, 07:03 PM | #48 |
![]() ![]() 258
Rep 350
I have the SS camber plates and rear toe arms, and will be doing traction arms and offset caster front bushings next, their product is incredibly high quality and they’ll send you a Geo setup for your shop to do based on what you want.
| 11-01-2025, 07:56 PM | #49 | |
Rep 663
I didn't expect there is such a big gap between the first and the second position of the camber plates, that's not very good for a fine tuning. How difficult it is to move from one position from another? Just need to take the front wheels off the ground? Also, how much increase in NVH did you notice after the installation? |
| 11-01-2025, 08:36 PM | #50 | |
![]() ![]() 6795
Rep 5,260
I wonder if there’s anyone in your area that might have an M equipped with SS components to get a ride in before you purchase/decide. |
| 11-02-2025, 05:40 AM | #51 |
Rep 663
Unfortunately not... I may ask the Italian M club, but I don't think anybody bought parts from UK. Most of the people here do what their mechanic/tuner suggests and sells.
So, I wouldn't be able to change the camber setting in 15 mins in my garage the morning before going to a track day and put it back in the previous position right after, without having to unbolt many things. I used to have Cusco camber plates in a Subaru impreza STi (20 years ago) and I could slide the plates from the top pretty easily, just lifting up some weight from the wheels. Those from SS don't slide but have 3 fixed positions and they seem more tricky to adjust. Also, I see all the monoball joints in SS components are not rubber sealed, could that be an issue in the long term? I don't want cluncking noise after the first year, when some dirt or dust get into the ball joints and they begin to get some play. Is this not going to happen for some reason? Last edited by Giak; 11-02-2025 at 05:45 AM.. |
| 11-02-2025, 09:45 AM | #52 |
![]() ![]() 6795
Rep 5,260
No, these plates are not like the ones you’re used to, but regardless, other alignment measurements change dynamically when moving camber around, so moving camber in and out like you used to isn’t optimal either even though I’ve heard many do and tout as the benefit of the normal design plates. I personally am one of those people who runs what they brought.
As for the bearings, they have extremely tight tolerances and because of that, there won’t be any of that clanking bs you get with other ones… at least this is what they advertise and say in their videos. You really should probably go to their YouTube channel and watch every single one to get a good idea of what you’re buying into. If you think you’re in a super harsh climate and literally have had personal experience with your other car’s undercarriages and components getting quickly ruined by that, then maybe you should just run stock CSL front hubs for the camber gain and rear arms from that same car and you’d get a non-adjustable OEM solution to what you’re looking for. |
| 11-02-2025, 11:03 AM | #53 |
![]() 146
Rep 168
This is why I think the SPL control arms are a good opinion they have camber adjustment and allow you to keep a lot of the OE bushings if you choose that.
| 11-03-2025, 10:50 AM | #54 |
![]() 62
Rep 68
God, I hope I'm asking this question properly
![]() Are there any differences between the Falline/Millway monoball spherical front end and the SS Front offset bushings/Solid Front Control Arm Bushes? |
| 11-03-2025, 11:32 AM | #55 |
Rep 663
Fall-line and Millway are both monoball spherical and remove the flexibility of the oem rubber mounts, but don't modify the position of the front arms. Instead, SS makes 2 different types of bushes, one very similar to the two above and another which has an offset position and allows to get more caster angle.
| 11-04-2025, 04:16 AM | #56 | |
Rep 663
Do you use the car as a daily? How many miles you have on SS parts? Do you know if they require any maintenance over time? thx |
| 11-04-2025, 04:23 AM | #57 |
Rep 663
I am finally taking the route of ordering both the CS+ Hanlding pack and the front control arm bushes.
![]() I have a doubt between offset or non-offset bushes. I will already have more caster from the camber plates, will I need the extra caster from the offset bushes also? Another difference between the offset and non-offset bushes is that the non-offset ones have sealed bearings, while the offset version runs uncovered. Could that difference have an impact on lifespan, considering this is my daily car and I don’t want to deal with noise or issues in the long period? Last edited by Giak; 11-05-2025 at 05:23 AM.. |
| 11-05-2025, 12:31 PM | #58 |
![]() 148
Rep 103
Drives: 2025 M3 Comp xDrive in TBII
Is it possible to adjust the camber plates in place, without dropping the strut? If not, do others like Millway allow this adjustment? This might be a dumb question, sorry about that if so
| 11-05-2025, 12:48 PM | #59 |
Rep 663
The answer is no for the SS camber plates. Don't know for other brands.
pdxgardener148.00 |
| 11-05-2025, 12:49 PM | #60 | |
![]() 663
Rep 220
Yeah, you just have to lift the car and remove the plastic trim piece over the strut. |
pdxgardener148.00 |
| 11-05-2025, 03:58 PM | #61 |
Rep 1,227
Will buying Millway camber plate improve the handling characteristics over the Oem top hats? I do not track the car, and have spl lower control arm to adjust camber also but just wondering if adding the camber plates will another layer of improvement.
| 11-05-2025, 09:43 PM | #62 |
![]() ![]() 6795
Rep 5,260
I don’t believe the Millways have any caster gain benefits in them. Yeah, you can adjust them without a ton of work, but they can also slip. I personally would rather have a locked down solid adjustment, but that’s just me. I don’t change stuff around all the time. I dial it in and keep it like that and go with it.
| 11-05-2025, 10:00 PM | #63 |
Rep 204
Not enough increase in NVH to be noticeable, it’s a daily but I don’t have a normal commute for work or anything. I prob have less than 5000mi on them, but don’t expect them to have any problems even though they don’t have boots. I’ve had full sphericals on my s2000 for about 7 years now without any issues. SS also claim that these are maintenance free
Giak232.00 vwSHANEg803.00 |
| 11-06-2025, 05:40 AM | #65 | |
Rep 663
vwSHANEg803.00 |
| 11-11-2025, 06:09 PM | #66 |
![]() 23
Rep 30
Just picked up my second g82. First one being a 2023 RWD (traded) and now my new ordered 2026 Xdrive. I already have the KW HAS kit I pulled from my 2023 that I haven't installed yet. Wanting to do all of this all at the same time. This is a GREAT read and exactly what I was searching for!
Added to cart currently: SS Adj. Rear Traction Arms SS CS+ Handling Pack SS Front Offset Caster Bushings OR SS Solid Front Contol Arm Bushings Not sure which one to go with. This will not be my daily and used primarily for spirited driving/ track days. ![]() |
| Bookmarks |
