12-23-2023, 04:12 PM | #45 |
Rep 1,953
Your mods aren't adding any power anyway, if the car is rated for 500hp 437 seems reasonable, but it depends on the dyno and its settings so best to ask the dyno operator why the low numbers compared to other dyno's.
12-23-2023, 04:30 PM | #46 |
Rep 422
You should have done a before and after Dyno session. Some dynos read low, some read high, their biggest benefit is showing the difference any of your modifications made.
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive |
m2not1LE67.50 |
12-23-2023, 08:26 PM | #47 |
Rep 7
They just say every dyno is different and say all types of reasons. Like how tight the clamps on the the car. I guess, after a tune. We will see. The workshop said this is normal and says look at the graph it’s a smooth curve. factory tune and looks very good, and says don’t worry about 326kw number, once we flash tune it. I’ll see the proper figures. Oh and they did put a fan in front. Sorry I wasn’t at the dyno session.
12-23-2023, 09:02 PM | #48 |
Rep 822
Drives: 23 G80 M3 6SPD
Does anyone know what the world record is for a g80 m3 base manual is? Whether it be stock motor/turbos or built, etc?
Acura RSX-S K24a2 JRSC Swap - SOLD CPO BMW 335i 6MT - SOLD |
05-05-2024, 01:42 PM | #49 |
Rep 125
Yes, you are right.
US gasoline also used to be rated under the RON system, though that changed to AKI ([RON + MON)/2] in the mid to later 1970s here. |
05-05-2024, 01:44 PM | #50 |
Rep 125
Absolutely. Dyno's are primarily intended to be tuning devices. Same dyno should always be used when making mods for the sake of consistency.
There is no fixed "percentage loss" that can be applied to get accurate "at the crank" numbers with chassis dynos. Almost better off using Patrick Hale's related quarter mile trap speed formula for that purpose. |
05-05-2024, 03:13 PM | #52 |
Rep 1,334
Drives: 2024 BMW M4 Base
I have not put my M4 on the dyno yet but as has been said, every dyno is different. I had my ‘22 X3MC on a dynojet and a Mustang dyno and it made 500 on the Mustang dyno and 478 on the Dynojet. No mods on either runs. I think Mustang dyno’s tend to be more gracious with the numbers.
05-05-2024, 06:12 PM | #53 | |
Rep 422
Planning on FEMTO unlock and basic bolt ons, then doing another Dyno session on the same Dyno to measure my actual gains.
mathys215.00 |
