07-23-2023, 08:43 AM | #45 |
Rep 283
Pool Shark527.00 |
08-11-2023, 06:33 PM | #46 |
Rep 6,819
Yes! Sorry for the slow followup, but see my post following this one in a moment.
I believe it was, but I don't have details on what parts were used or the approximate drop. -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
08-11-2023, 06:35 PM | #47 |
Rep 6,819
18" VS-5RS Wheels: Forged VS-5RS Front & Rear: 18x10.5 ET18 Tires: Nitto NT01 Front & Rear: 305/35-18 Additional Modifications: KW V3 coilovers 5mm spacers front (required) and rear (optional) Modified front fender liners or RKP front liners recommend for rub-free fitment when turning Not compatible with CCBs. Still Can't Find The Right Picture? Check Out Our Wheel Galleries For More Content!
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 08-14-2023 at 01:12 PM.. |
08-12-2023, 04:26 AM | #48 |
Rep 4,529
[QUOTE="Expert@ApexRaceParts;30392303"][CENTER]
18" VS-5RS Wheels: Forged VS-5RS Front & Rear: 18x10.5 ET88 Tires: Nitto NT01 Front & Rear: 305/35-18 Additional Modifications: KW V3 coilovers 5mm spacers front (required) and rear (optional) Modified front fender liners or RKP front liners recommend for rub-free fitment when turning 18” cw fat sidewalls 😍 for the win Typo - should read ET18 ? Are the 5mm spacers required due to combo of KWV3 paired with NT01 305/35/18 having a wide/square profile ? If using say 275 or 285 front tyre would spacers still be necessary ?
Current '22 X3M LCI.. |
Expert@ApexWheels3593.00 |
08-12-2023, 01:10 PM | #49 | |
Rep 478
2024 BMW M3, 6MT, Alpine White
08-14-2023, 02:20 PM | #50 | ||
Rep 6,819
[QUOTE=Bee Pee;30393162]
I suspect any configuration with the 305/35-18 tire size will require a 5mm spacer regardless of the suspension type. Narrower tires likely won’t require it unless the suspension configuration is aftermarket and extremely limited. Quote:
-Tom
08-15-2023, 02:47 PM | #51 |
Rep 6,819
Wheels: Forged VS-5RS - Motorsport Gold Front & Rear: 19x10 ET12 Tires: Bridgestone RE71RS Front & Rear: 275/35-19 Owner's IG: @chrisfri13
08-16-2023, 11:09 AM | #53 | |
Rep 6,819
https://apexwheels.com/gallery/bmw/m...shed-clear-283 https://apexwheels.com/gallery/bmw/m...shed-clear-385 https://apexwheels.com/gallery/bmw/m...anthracite-147 https://apexwheels.com/gallery/bmw/m...shed-clear-857 https://apexwheels.com/gallery/bmw/m...atin-black-634 -Tom
08-16-2023, 11:15 AM | #54 | |
Rep 478
08-22-2023, 07:20 PM | #55 | |
Rep 283
Thanks |
08-24-2023, 02:52 PM | #56 | |
Rep 6,819
-Tom
08-24-2023, 02:53 PM | #57 |
Rep 6,819
19/20" VS-5RS + OE tire notes Wheels: Forged VS-5RS in Anthracite Front: 19x10 ET12 Rear: 20x11 ET18 Tires: Michelin Pilot Sport 4S Front: 275/35-19 Rear: 285/30-20 We’ve had a number of G80 customers reach out to ask what the best Apex wheel setup is for those who want to reuse their OE tires that the car came with from the factory. While our wheel setups are optimized around wider tire fitments than stock, we understand many G8X owners want to reuse their original tires to save money before moving on to wider fitments. There are also some who prefer to use the OE michelin star BMW spec tires engineered for the car specifically. For either camp, choosing a great set of Apex wheels should be easy. This feature showcase focuses on the setup we recommend most often for those looking to reuse OE tires. Most of the G8X M3s and M4s as well as all of the G87 M2s we’ve seen come equipped with 19” front and 20” rear wheels. The stock 275/35-19 front tires fit well on our 19x10 ET12 wheels providing a great amount of sidewall support. In the rear, we generally recommend our 20x11 ET18 wheels. While this is a wider wheel than we’d generally recommend for a 285-section tire, the tire stretch is not bad overall as you can see below. We’d still recommend running wider tires once you wear through the original set of tires, but hopefully this photoset helps those of you considering this fitment for your OE tires. Photo Credit: @basicperformance_korea Still Can't Find The Right Picture? Check Out Our Wheel Galleries For More Content!
09-24-2023, 01:05 PM | #58 | |
Rep 283
Would you happen to know if the 19x10.5 version - using 305/30R19 NT01s fit (same clearance)? Diameter would be 0.2" less. and sidewall less 0.6". Can you tell us about the passenger side using 19s? |
09-24-2023, 11:42 PM | #59 |
Rep 283
Hi Apex. Any reason for removing the 305/35 R18 option from your fitment webpage?
Now only list 295s. https://apexwheels.com/fitment-guide...onal-resources |
05-07-2024, 06:22 PM | #60 |
Rep 2,662
BMW G80 M3 with 19” VS-5RS in Brushed Clear Wheels: VS-5RS in Brushed Clear Front: 19x10" ET12 Rear: 19x10" ET12 Tires: Michelin Pilot Sport 4s Ultra High/Max Performance Summer Front: 275/35-19 Rear: 275/35-19 Photo Credit: @basicperformance_korea Fitment Guides We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our M3 Guide
Fidiman114.00 |
