R44 Performance
      05-29-2023, 07:11 AM   #45
BMWRacer523
BMWRacer523's Avatar
2567
Drives: 992 Carrera T
Originally Posted by sleepingplant View Post
I use a Garmin Catalyst now, but I used to use TrackAddict on my phone. The G data is pretty consistent between the two for me, so anecdotally as long as you mount your phone somewhere (and it's not just sitting in a cupholder or something), it should be fairly accurate.
Going a bit off topic but what do you like better with the catalyst? Is it the coaching?
      05-30-2023, 11:47 AM   #46
ember.m4
ember.m4's Avatar
Drives: G82 M4 Competition xDrive
I've enjoyed the experience of using it overall:
  • Compared to a more comprehensive setup involving multiple cables, components, and ports, the Catalyst is very easy and quick to setup.
  • My friends also have Catalysts, and it lets you easily compare lap telemetry which is pretty cool.
  • The UI is sleek and easy to use.
  • There are leaderboards where you can see other people's lap times.
  • You can easily watch your laps and make videos of them with overlays, no manual time-syncing of any data required.
  • It tells you your optimal lap time based on your own demonstrated driving.
  • There's also the coaching like you mentioned, although I feel like the usefulness of this varies.
All in all, I think it's the best available package for someone who wants more than a smartphone, but doesn't care to analyze car telemetry data (steering angle, pedal application, etc.) through the OBD port. The price and inability to integrate with OBD are the two main things holding it back imo.
      05-30-2023, 04:36 PM   #47
BMWRacer523
2567
Thanks. I've been considering one to use with students as well as my own driving. I do like that it is all in one and easy to use. Agree on price and lack of obd support but then again ease of use trumps extensibility for this kind of stuff imo.
      05-30-2023, 06:06 PM   #48
BrendanZ0402
BrendanZ0402's Avatar
Drives: G80 M3 GTP 6MT
2023 BMW M3  [0.00]
According to your video, you're at 0.6g braking on the straight. You have a LOT more braking force at your disposal. I'm usually around 1-1.2g when braking hard. Your windows won't come up until you brake harder.
FWIW I had plenty of 1.2g+ stops ar Buttonwillow the past weekend with cars in front and had 0 experiences with the frontal collision warning and window coming up/sear going forward..... Just a data point.
      06-21-2023, 06:46 PM   #49
seals9121
Drives: bmw
Yeah, the fact that they don't have a way to turn this off is pretty dumb. Happened to me multiples times last week at Buttonwillow. What's the point of having a track mode if it still thinks you're crashing when you push hard?
happen every lap for me. I just drive with the window close now.
turn the AC max, enjoy my music while doing the lap. it's quiet and fun.
      10-30-2023, 04:20 PM   #50
BzsBimmer
BzsBimmer's Avatar
3444
Drives: '23 G80 FO M3 & '23 G05 X5 M50
2023 Xdrive M3 - No active cruise, have M Drivers Package
Doing some intentional drifting this past weekend. Had windows roll up and seat move forward along with tightening of seatbelt.
Once in driver seat and once in passenger.
Had track mode on. Full DSC off. Had car in 2WD mode.
Also will add that the car during the last run went into engine overheat alarm. Haha.
      10-30-2023, 06:02 PM   #51
eugenebmw
eugenebmw's Avatar
2171
Drives: G15 M850i G82 M4, G22 M440
Originally Posted by reNT View Post
Just got back from a track day and confirming that I haven't experienced any window closing issues. Was braking hard from 132mph down to like 40. My car does have the m drivers package, the one that enables the 10 way traction control and the drift analyzer, not the one that raises the speed limit. If that even matters? Anyways just wanted to share my experience.
My G82 has the same configuration as your. I have done 4 track days this years and my car windows never rollup.
      10-30-2023, 06:05 PM   #52
eugenebmw
eugenebmw's Avatar
2171
Lucky you All the racing tracks I went to will not allow cars with windows rollup during the lap run.
      05-12-2024, 12:47 PM   #53
rafaeldelrey
rafaeldelrey's Avatar
Drives: 2024 BMW M3 CS, 2023 BMW M4 Co
Just been to my second track day.
G83 2023 BMW M4 Convertible. No track pack, no M driver pack.
Things I tried:
- Put collision system on late or All Off (pressing the button for a few seconds): doesn't work. Still getting collision mitigation system triggering multiple times;
- Removed the fuses: avoided the windows rolling up. So you get only the belts tigthening;
- Easing on the brakes. Works, but that caused the brakes to overheat as you end up braking earlier and longer. No to mention your lap times will be affected, as this is definitely not a good technique. I was using cobalt brake pads and Motul RBF 600. I didn't have brake fade in my previous track day with all stock parts, but I wasn't also trying to smoothen brake pedal application.
- MDM mode on (4WD Sport): no triggering of the collision mitigating system. All the previous tests I had DSC ON. After the brake failure, an experienced racer, tracking his BMW M4 (prev gen), and my instructor in the previous track day, helped me reset the car brake system with Bimmerlink. We saw a bunch of DSC related errors and he suggested I used MDM to reduce the frequency of brake interventions that could be overheating the brakes. This ended up "fixing" the anti collision annoyance. I did another test with DSC On in the next session and the anti collision was back. So it becomes clear the MDM is the reason for change.
      05-13-2024, 01:19 PM   #54
NYG
NYG's Avatar
Drives: Audi R8
To the people having this issue, do you have Driving Assistance Package with the sensor up front?
      05-13-2024, 02:15 PM   #55
Ximian
Ximian's Avatar
Drives: E92 M3
2011 BMW M3  [0.00]
2021 BMW M3  [0.00]
No, it's not package related. I've only had it happen under very hard braking and on bumpy corners. Hasn't happened with very hard or full braking and a smooth track.
NYG12504.50
      05-13-2024, 03:26 PM   #56
NYG
NYG's Avatar
Drives: Audi R8
Got it.
I didn't get that package on my build so I thought besides the cooling gains, it would prevent this too
      07-07-2024, 05:39 PM   #57
rafaeldelrey
Update: Tracked my M3 CS this weekend (so it has track pack and M-driver). I had zero interventions of the Anti-Collision system, unlike my wife's G83 M4 Comp Convertible (no track pack, no M-Driver).
With the CS, in my second session, I even forgot to enable Track Mode, and still no triggering of the anti-collision system.
NYG12504.50
sly1types459.00
      09-21-2024, 01:53 PM   #58
Kung Fu English
Kung Fu English's Avatar
147
Drives: 2017 F80 M3 ZCP MG/SO
I get this almost every autocross lap. Super annoying. It’s definitely related to how hard you brake. When I slam the brakes hard they roll up. If I ease into it they don’t.
Everything off. M mode sport + DSc off m mode track.
What is the solution do we know yet?
      09-22-2024, 12:11 AM   #59
Drives: S4
According to one post MDM.
      11-05-2024, 01:52 PM   #60
NYG
NYG's Avatar
Drives: Audi R8
Did not have this issue a single time. I over-brake like a mofo on all of my track cars.
Ran the car in Track mode even with DSC on.
