01-04-2021, 04:15 PM | #45 |
General
21132
Rep 20,742
Drives: 2021 911 turbo
You still have a lot to learn young padawan.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-04-2021 at 04:29 PM.. |
01-04-2021, 04:45 PM | #46 | |
General
21132
Rep 20,742
01-04-2021, 04:51 PM | #47 | |
Rep 7,037
That’s enough arguing for me on the reason, something I’m not that interested in. I have no intent to mess with it and I really only interested in the result. Some of the best car companies decided to do it on their cars with some track intent, I’m not about to argue against them when I don’t really care Last edited by solstice; 01-04-2021 at 05:14 PM.. |
01-04-2021, 05:17 PM | #48 | |
General
21132
Rep 20,742
Remonster825.50 |
01-04-2021, 05:27 PM | #49 | |
Rep 7,037
And if so, how does the relation to the rear tire wall increase front end grip? My comments here was solely for the rear upsize. I agree that a smaller front wheel with larger tire wall has positive impact on the front axle as for grip and steering. Never argued that. |
01-04-2021, 05:29 PM | #50 | |
Moderator
7526
Rep 19,368
I guess my point is that once you have a sufficiently complex set of variables, you can't necessarily argue absolutes because things have a way of yielding surprising results when they combine in the real world. So, it may very well be that until recently, BMW simply used the same (or virtually so - as close as they could using common tire widths, inside diameters, and aspect ratios) sidewall height front and back because they had no reason to expect appreciably better results from using different sizes. But, if they came to learn from simulation or experimentation that traditional wisdom wasn't necessarily true in all cases, then certainly they'd want to apply those findings to product design, even if they could not immediately explain the results. |
01-04-2021, 07:16 PM | #51 | |
Rep 14,147
Drives: G82 M4C X-Drive
01-04-2021, 07:34 PM | #52 | |
Rep 7,037
https://www.motorauthority.com/news/...r-the-2020-911 In relation to this thread: August Achleitner, vice president of the 911 and 718 product lines 2) Enlarge the diameter of the rear wheels. Calculations and simulations showed that enlarging the diameter of the rear wheels would improve dynamics even though it would also add weight. The 2020 Porsche 911 S and 4S now ride on 21-inch wheels at the rear and 20s up front, though the tire sizes haven't changed at 305/30 rear and 245/35 up front. While this influenced all of the surrounding areas of the suspension and the packaging of the car, Porsche felt it was worth the effort because it would make the handling more neutral and controllable. The company had experience with the practice as the 918 Spider and GT2 and GT3 cars already use staggered wheel sizes, and there are no better handling Porsches than those. Handling becomes more neutral because the bigger rear wheels provide greater rear end stability and grip without having to go with a wider tire. Here’s the other one and it’s actually Achleitner again but a different outlet: https://www.roadandtrack.com/car-sho...specs-details/ So what's the effect of the increase in wheel size and track width. I'll let Achleitner explain: - When you widen the track in the front and in the rear...you can transmit rolling forces a little bit more with just the spring and damper, and then you can soften the stabilizers. When you soften the stabilizers, you get better traction out of the car, [which] makes the car faster. -We have a bigger rear wheel, and that's the first time in the history of the 911 Carrera, that the rear wheel is a diameter bigger than the front one...From this, we get a better, bigger [contact patch] not only by width, but also by length. And with the enlargement of the tire, we were also able to reduce the tire pressure a little bit. So it’s interesting that they actually soften the impact of the tire wall by reducing tire pressure and by that further emphasizing traction and grip over stiffness and response in transitions. Not one word on front axle advantages, staggering is all about the rears for Porsche. Main take away from this should not be who is right or wrong of us but for BMW to step up and provide similar insight about the G8X as Porsche does in these two articles. That’s currently sorely missing leaving the friends here argueing about it. Last edited by solstice; 01-04-2021 at 08:18 PM.. |
01-04-2021, 08:24 PM | #53 | |
General
21132
Rep 20,742
Balancing over and understeer is a question of matching front and rear grip. To reduce understeer, one needs to increase front-end grip relative to the rear, hence the staggered rim diameter setup. Be it 18"/19", 19"/20" or 20"/21", the purpose is to have more front end grip relative to the rear but by always keeping the rear with a sharper response through a lower profile than the front to obtain the desired overall handling characteristic.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-04-2021 at 08:46 PM.. |
solstice5459.00 |
01-04-2021, 08:35 PM | #54 | |
General
21132
Rep 20,742
My comprehension from the Porsche text above is that their reference to "wheel" is the tire/rim combination as you had earlier interpreted. A larger tire diameter does result in a longer contact patch. But a larger rim diameter for a given tire diameter DOES NOT translate to a longer contact patch (with all else being equal). As I've stated before: while Porsche have indeed increased the tire diameter stagger with the 992, BMW have not done so for the G8X (they have actually reduced it compared to the F8X). I fully agree with you, technical insight is definitely lacking with this G8X launch.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-04-2021 at 08:45 PM.. |
01-04-2021, 08:42 PM | #55 | |
General
21132
Rep 20,742
said it would help in achieving the desired result. I doubt they tried it just for the sake of trying it. Many things have indeed changed over the years and through the different M3/4 generations, such as tire and damper technology that have evolved significantly just to state those as examples. But also weight distribution. The G8X carries more weight on its front axle than previous generations. That also needed to be addressed to achieve the desired handling characteristics.
01-04-2021, 08:52 PM | #56 | |
Rep 7,037
01-04-2021, 08:56 PM | #57 |
General
21132
Rep 20,742
Again: it was "very involved" for Porsche because they significantly changed the rear TIRE diameter by 1", which impacts wheel well clearances, ride height and chassis rake. On the F8X CS/GTS and the G8X, they only changed the RIM diameter without significantly altering the tire diameter, so no required changes to the body in BMW's case.
Boss3301721.50 |
01-04-2021, 09:05 PM | #58 | ||||
Rep 14,147
However combine the small (minimal) amount of increased contact patch due to an increase in diameter with the ability to run a lower pressure with less sidewall flex, and you get the benefits stated by Achleitner. Engineers smarter than I have probably done the math and determined the increased weight is worth the gains. Think of it this way: take a tennis ball and set it on the ground. Take a bowling ball and set it on the ground. What is the difference in contact patch? Minimal. Only when to take into account material compression or in this case tire deflection does the contact patch change significantly. Quote:
I also have an M3 CS which has a staggered 19 front 20 rear setup from factory, so obviously I can't argue against the fact that they did it for a specific reason.
solstice5459.00 |
01-04-2021, 09:15 PM | #59 | |
Rep 7,037
01-04-2021, 09:34 PM | #60 | |
General
21132
Rep 20,742
This is demonstrated by the M4cs achieving the highest recorded skidpad figure by a significant margin for any F8X they tested despite being shod with PSS tires in C&D testing. And BTW, you are dragging yourself into this, you even started it .
01-04-2021, 10:25 PM | #61 | |
General
21132
Rep 20,742
But this is all moot for the G8X discussion, because they did not increase tire diameter to a significant extent.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-05-2021 at 09:19 AM.. |
jmg18879.50 |
01-04-2021, 11:02 PM | #62 |
Rep 850
Does anyone have a photo of the recommended tire specs and pressure on the metal tag below the B pillar? The one I have seen on the G80 does not have any 19/20 inch listed. It included 19/19 and 19/21 but did not include 19/20. I don't recall the details of the specs.
2013 F10 M5 FG, 12.7 E92 M3 ZCP sold
01-04-2021, 11:02 PM | #63 | ||
Rep 6,121
Drives: 2022 Porsche Boxster GTS
there's a lot more to the picture that we should consider. Of course we cns find a good balance between the two for the best daily set up
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
01-05-2021, 12:10 AM | #64 | |
Rep 287
When I was getting my F80 with 20's, the sales guy was warning me about cracked wheels because there is not as much rubber around the wheels to protect them against impact. Bigger wheels don't improve performance, the ride is harsher, and they're more likely to crack...they look f**** great though! Back to the topic, the difference in size between front and rear wheels is fairly noticeable. I pointed this out in another thread a few weeks ago. I am pretty sure I'm being too picky, but they would have been better off sacrificing performance if they were picking the 20's to begin with. Now, they've kind of half assed it. It doesn't look that great, the ride is as harsh and the performance is probably not as good as it could have been. They should have done what they did with the F8* |
01-05-2021, 12:23 AM | #66 | |
General
21132
Rep 20,742
