09-15-2024, 01:43 PM | #24 |
Rep 197,574
im not aware of any issues
Sigzy16.50 |
09-15-2024, 02:56 PM | #26 |
Rep 197,574
09-16-2024, 01:04 AM | #27 |
Rep 85
I just spent the last few hours searching Vargas turbos and there’s been a few failures and broken wheels in the civic and supra community 🤷🏼*♂️
09-16-2024, 08:44 PM | #28 |
Rep 1,089
I like them and they suit my needs. They are only a tiny bit laggier than stock around 200-300rpm laggier and with a lot more mid range and top end. They didnt give me any explanation. Just that they are discontinuing them. I assume that they didnt sell well and they seem to have discontinued all their BMW products
2022 M3 XDrive - Full Race Turbos - BMC Filters - MAD Fatboy catless downpipes - AA EL Resonated Midpipe - BM3 Flex Fuel Kit - Paul Johnson Flex Fuel - Rod Sutphin - Ohlins R&T - Vorshlag - Millway - SPL - iSweep 2000 - Apex VS-5RS - PS4S(*)
2023 IX M60 2013 Ferrari F12 Berlinetta - BMC Filters - Capristo X-pipe + Axleback - PSC2(K1) |
09-16-2024, 11:22 PM | #29 | |
Rep 2,581
09-17-2024, 01:37 PM | #30 | |
Rep 180
this may give you insight to meet your goals with the right parts check out this- https://www.bendcalibration.com/blog/s58-build-path |
peterfromsd190.00 daddyjaxx116.50 |
09-18-2024, 02:31 PM | #31 |
Rep 33
Figured I would keep you all up to date!
I also have an Instagram that has updated pictures etc with the build coming along Instagram: M3_Sigs DME from ship to receiving back in hand was 6.5 days via DHL. I received the rest of my exhaust and upgraded turbos today and everything is scheduled to get put on this upcoming Monday. |
somer1057.00 |
10-02-2024, 11:13 AM | #32 |
Rep 33
Update:
Should Have Dyno numbers either today or tomorrow and have the car back in my possession by Friday then will proceed to get some draggy times this weekend if the weather permits pretty excited and thank you to everyone who has been following the thread |
Xanston22.50 |
10-02-2024, 10:25 PM | #33 |
Rep 450
I may have missed it but can you share you build details?
10-02-2024, 10:27 PM | #34 |
Rep 33
Schedule: 9/10/24 - Full stage 2 build starts
• Stage 2 Hybrid Turbos @rkautowerks • Catless Downpipes @masteryofartanddesign • Valvetronic full equal length system @valvetronic • Top mount Intakes @burger_tuning • XHP Trans tune @xhpflashtool • Ported Manifold @mishimoto • ID 1050 injectors @injectordynamics • LPFP Upgrade @precision_motorsports • 91 octane and E85 MHD+ Custom Tune |
10-02-2024, 10:29 PM | #35 |
Rep 33
Ran into some issues today - Turbos are only wanting to push 33-35 psi on 100 %wastegste. Currently have VTT inlet pipes and going to pull them off tomorrow to see if we are getting restrictions. Per RK sight these are capable of 40+psi. We are at 85% E and putting down 784awhp 680 torque. Hopefully we can get this issue straightened out tomorrow and get these pushing 40psi for more favorable numbers.
somer1057.00 |
10-03-2024, 12:20 AM | #36 | |
Rep 1,293
575RWHP F87 M2C 875AWHP F97 X3M 1000+RWHP Turbo E46 M3 ALL TUNED BY BEND CALIBRATION |
10-03-2024, 03:56 AM | #37 | |
Rep 181
2. I heard rk turbos are not good on that car. I recommend gc+ or pure for hybrid. Last edited by papaman1234; 10-03-2024 at 03:56 AM.. |
10-03-2024, 09:27 AM | #38 | |
Rep 33
2. I reached out to RK directly and was told they flow 900-1000hp. So far we are not finding that. Today the inlets are being removed (aftermarket VTT) if still won’t go past 33-35 psi at 100% waste gate than it’s a turbo issue at that point. If they do flow more without the inlets it’s a matter of modification which I’m not a fan of ( I like turn key stuff) I slept like 3 hours last night wrapping my head around it lol still couldn’t. Super frustrating but need to get the final verdict. No doubt in my mind a set of LM or pures this car shakes 850-880awhp. Last edited by Sigzy; 10-03-2024 at 09:29 AM.. |
somer1057.00 |
10-03-2024, 09:30 AM | #39 |
Rep 33
10-03-2024, 10:51 AM | #40 |
Rep 2,581
Might wanna check that Valvetronic. The restriction could also very well be past the turbos if you can’t evacuate the gasses quickly enough. Disconnect after the downpipes and see where you’re at there too to rule everything out.
10-03-2024, 10:59 AM | #41 |
Rep 1,293
Both, can't run that way daily but remove both to do your own test to verify.
10-03-2024, 11:01 AM | #42 |
Rep 33
Currently on 3.5” catless dp and valves are 100 percent open.
10-03-2024, 12:28 PM | #43 |
Rep 2,581
That’s not what I said. Don’t care if the valves are open. Sometimes exhaust flow build can affect back pressure. Only way to truly rule it out is to disconnect it. Hell, even a bad downpipe bellhousing design can cause issues with boost onset and even full turbine speed, but generally for our designs, there’s not much you can fuck up on that.
On some Valvetronic exhausts their second pipe that comes into the main one comes in at a 90° T into the main exhaust. This is generally a bad design the closer you are to the engine because the two flows collide and both can back up rather than flow out. There’s also literally no “collector” type setup where this happens so that doesn’t help matters much either. If you’re at the point of intakes being taken off to narrow down the issue to the turbos being it, you might as well spend the 10 min to take the midpipe down for a run as well. At that point you’ll also have additional ammo to throw at RK in regards to their hardware being the issue. Also, don’t forget the obvious… boost leak between turbos and engine, but I’d think your tuner would have checked this first before anything else. |
10-03-2024, 12:33 PM | #44 | |
Rep 33
