03-27-2023, 04:02 AM | #23 | |
Rep 18
03-27-2023, 07:18 AM | #24 |
Rep 152
I've had my IS1500 fronts for about 200 miles now. I had EBC yellows (kept the rears). So far the isweeps have ZERO noise and significantly less dust. I can't tell much difference in braking performance. Very pleased so far.
M416Comp64.00 |
03-27-2023, 08:38 AM | #25 |
Rep 935
What's the difference in dusting in your experience from yellows to isweeps?
Make today your best day!
03-27-2023, 08:49 AM | #26 |
Rep 152
LuckyBrand1451.50 |
04-22-2023, 03:40 PM | #27 |
Rep 948
I finally got around to installing these with a few local G8X buddies after having them sit in my garage for 4 months. Install was fairly straightforward, and if I was going for time and not socializing (which is far less fun) I think all four corners could be done in under 2hrs easy. I've only driven 20mi or so, but feel is essentially like stock and squeal is completely gone. I took the opportunity while the wheels were off the car to clean the barrels, so we'll see how much less dusting I get, but I'm optimistic. Anything less than OEM is a win. I reused my brake wear sensors so I didn't need to install the extra set I bought. And although there was nothing said about bedding them in, I did a series of 60-0mph stops to be sure, and again, bite is very similar to stock. Maybe slightly less, but I can't tell for sure. In normal driving, you can't feel the difference at all. The lack of squeal alone makes this worthwhile to me, but I'm looking forward to less dusting as well. They're more expensive than other options, but all in all, I'm happy (again, 20 miles in anyway).
(Rears purchased and installed but not pictured)
Previous notables:
'05 S2000 | '07 335i | '09 ISF | '08 911 Turbo | '09 911 C2 | '15 Cayman | '15 RCF | '17 MX-5 RF | '17 C7 Corvette |
fanofbmwe462104.00 PipeM3200.50 LuckyBrand1451.50 CaptBoaty106.50 evoi191560.50 r33_RGSport13121.00 6empty12.00 |
04-23-2023, 01:29 AM | #28 | |
Rep 37
Did you use bimmerlink to place the car in service mode for the rear change? |
04-23-2023, 06:30 AM | #29 | |
Rep 948
And yes, the car was placed in service mode with bimmerlink for the rear pad changes.
Previous notables:
fanofbmwe462104.00 |
04-23-2023, 07:39 AM | #30 | |
Rep 1,163
04-23-2023, 08:08 AM | #31 |
Rep 948
Do I think so? No. The front side is also a proper jack point, and in the 10 seconds or so it is high enough that the rear jack stand can be placed and the car can be let back down I don't think that puts too much flex on the chassis at all. In fact, I personally feel better doing it that way than putting that load on the rear diff, even though I know the manual says that's ok too.
Previous notables:
04-23-2023, 08:28 AM | #32 | |
Rep 935
On the rear electronic parking brakes I just used the 9 volt battery trick with some 14 gauge speaker wire I had. Worked fine. |
04-23-2023, 08:03 PM | #33 | |
Rep 37
04-23-2023, 09:33 PM | #34 | |
Rep 37
04-26-2023, 09:26 PM | #35 |
Rep 37
When changing brake pads i had the rear sensor on do I need to also change front pads , i mean is it recommended to do front and back or can be done depending on which one is worned out?
04-27-2023, 08:58 PM | #36 |
Rep 948
You can do just fronts or just rears...so if your rears are worn down but your fronts aren't (which would be a bit unusual, but possible), you can just replace them.
Previous notables:
04-29-2023, 06:21 AM | #37 | |
Rep 37
My rears were worn out from a HPDE weekend. Front held on pretty good. |
05-07-2023, 12:12 PM | #38 |
Rep 948
Update:
I just wanted to check back in for a 2 week update. My only regret is I didn't do this as soon as I bought my car. These pads are a game-changer. I don't feel any difference at all in my brake feel. Same bite whether I'm doing a hard stop or just commuting. It has taken me practically the whole two weeks to stop slightly wincing when I creep to a stop, expecting the high-pitched squealing I had come to know. There hasn't been a single peep. And the dusting? While they still dust slightly, it's just as others have reported... the dust is of a different quality. It's a lighter colored dust that doesn't stick to everything and it is much, much less. I have less dusting in a week from driving then I did in a day with the OEM pads. Plus, with the black 826M wheel, it's nice that they aren't brown mostly all the time. I highly recommend doing it if anyone else is sitting on the fence.
Previous notables:
12
seirk196.00 m4ml1895.00 Anderson11458.00 LuckyBrand1451.50 r33_RGSport13121.00 Mp3Supply259.50 JustinHEMI7453.00 Kaiz3n0.00 79 911SC85.00 Berzerker3107.00 6empty12.00 mathys215.00 |
07-12-2023, 02:44 PM | #39 |
Rep 106
Drives: 2023 M3 Comp X-drive
Update from me as well, ^^ agree completely.
The dust is now minimal, so much so that after 1000 miles of daily driving it’s barely noticeable. I do sense a slightly higher brake pedal force to stop than what I’m used to, so might try the iSWEEP 2000 next time. But the 1500’s still perform well in stopping distance by seat of the pants feel. zero noise and insignificant dust with the 1500’s, a step-function improvement over OEM. |
LuckyBrand1451.50 |
07-18-2023, 09:06 AM | #41 |
Rep 1,955
I use pledge...
07-19-2023, 10:03 AM | #42 |
Rep 353
Wait, your isweep 1500's only lasted a weekend for that? I am worried about regular daily driving length now on mine with spirited driving (the odd slowdown from 90mph to 55 in a crunch.
07-19-2023, 05:44 PM | #43 | |
Rep 751
It's hard to explain, but I'll likely be looking at the 2000's as well next time. (I did wonder if it was partially because a proper bedding was not done)
09-26-2023, 02:12 PM | #44 |
Rep 948
5 months and however many miles update is more of the same for me. I continue to wish I had done this the first day I got the car, and can't believe I put up with the excessive dusting and squealing from the stock pads for so long. I get it, high performance cars need high performance brakes, and dusting and noise are part of the package. That said, I don't have any plans on tracking my car, and these pads have handled spirited drives, one 500+ mile round trip through the mountains, regular commuting use, and one emergency braking situation where I was cut off without a single issue. I haven't heard a squeal since I installed them, and the dusting is way, way down.
10/10 would buy again.
Previous notables:
