10-07-2021, 03:00 PM | #23 | |
Rep 897
2017 M3 Comp Pack 450PS
2017 C63S T 510PS |
10-07-2021, 07:50 PM | #24 | |
Rep 618
I know I’ve poked at you guys about the power claims and until I see a dyno of a S58 M3, I’m sticking with the stance that these are claims not proven. You show me a stock S58 G80 dyno where it makes 10 whp, I will absolutely buy two today. Until then, I’ll wait until it’s time to replace the stock filters and then I’ll pick up a couple. |
10-07-2021, 08:56 PM | #25 |
Rep 3,730
Plenty of testing has been done on YouTube on performance air filters. I think the topic has been beaten to death.
For turbo BMWs, you'll gain some whp up top and lose a little wtq at the low end. BMC filters have always been my first mod on a new car and I've never been let down
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
11-04-2021, 03:30 PM | #26 |
Rep 1,685
Installed these today and removed charcoal filter in about 10 min. Didn't bother removing the braces. Can't say I notice anything different but my cars already fairly loud because I put in new mid pipe. Either way, for just over $100 bucks I figure why not.
tom @ eas8310.00 |
11-04-2021, 10:24 PM | #27 |
Rep 1,446
11-05-2021, 11:25 AM | #28 | ||
Rep 725
Drives: BMW M3 xDrive
11-05-2021, 12:42 PM | #29 | |
Rep 21,785
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
01-01-2022, 12:25 PM | #30 |
Rep 570
Drives: '19 GLA45AMG(his) / '21 X3M40i
Easy carbon filter removal:
- Rectangular filter: pull from the black tab side, so that it slides out - Triangular filter: pull from the middle with two needle nose pliers Above instructions allow you to re-install the filters, just in case. Otherwise: pull at will, and destroy carbon filters. Just make sure you wipe any carbon residue.
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 |
01-02-2022, 06:16 PM | #31 |
///M-Thusiast
3688
Rep 955
Drives: '23 X5 M50i
Why are these filters oiled? What benefits does the oil have to a non-oiled filter?
Current: 2023 G05 X5 M50i xDrive
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i |
01-02-2022, 09:37 PM | #32 | |
Rep 18,878
Generally speaking, vehicle such as automobiles or motorbikes require total particle filtration efficiency up to a minimum dimension of 10 micron, in order to avoid any risk of foreign bodies passing through large enough to damage the mechanical components downstream the intake system. OEM air filters are made of paper, and their main function is to protect the engine. These filters feature high resistance to the air flow which, consequently, reduces the pressure and the engine performance. BMC’s air filters allow the passage of a greater air flow. Moreover, compared to traditional paper filters which must be replaced when carrying out maintenance, BMC filters can be re-used so that they last as long as the vehicle itself. More questions covered in the BMC FAQ here: https://www.bmcairfilters.com/eng/fr...questions/7/fq
playswcars3687.50 |
01-05-2022, 05:29 PM | #33 |
Rep 1,001
Drives: 2024 M4 Comp X-Drive
Any forum vendors have these in stock and ship to Ontario Canada?
01-15-2023, 07:37 PM | #34 |
Rep 85
Drives: 2023 M3C
I ordered the aerosol kit from BMC from Soul. I think there would be a better chance at an even application using the aerosol oil.
01-16-2023, 01:30 AM | #36 |
Rep 18,878
Yes, you will hear a slight increase in induction noise with combination of new filters installed and charcoal liners removed.
11-30-2023, 04:52 PM | #37 |
Rep 2
You can simply remove the five T25 screws and you should be able to get the filters (2 each side) out... the charcoal one is the #2 filter for each side. Then the BMC goes in very easily. It gets tight but you do not need to remove anything but the filter housing. I just did it in 15 minutes max. Tip - it really helps having a LONG t25 torx driver... 8 inches or longer.
https://www.amazon.com/RUBY-Q-Extra-...s%2C129&sr=1-8 |
Tags |
bmc, cotton gauge, eas, filter, intake |
