BMW Lease Deals
      04-05-2021, 10:23 PM   #23
HK4
Drives: 2008 Scion TC, 2023 G80 M3
Excellent analysis. Looking forward to my experience soon!
      04-05-2021, 10:32 PM   #24
khanyam4
Ring Leader of G8X Trolls
khanyam4's Avatar
839
Drives: 16 F10 535i 25 xDrive G82
Nice! LFG!
If you do not like the car your opinion is best expressed by not buying it
      04-05-2021, 10:59 PM   #25
stevehifi
Drives: 17 F80 M3 ZCP
Excellent review from an avid owner.
Can you explain how you got -2deg camber ? I assume the only adjustment is toe in the front so not sure how you coaxed more camber.
JTO245898.50
      04-06-2021, 01:02 AM   #26
blackmamba3
blackmamba3's Avatar
Drives: 2024 BMW M3 CS
Originally Posted by PeregrineFalcon View Post
Thanks for great and very informative post!
Regarding brakes, one more reason they were so good and didn't overheat could be the fact that this time they have made actual air duct that goes from the front part of the car strait to the brakes for cooling?
I think you're right! Not only are they a cool visual element to the front of the car but surely functional too, especially on track!
      04-06-2021, 01:04 AM   #27
blackmamba3
As you can tell just by looking at the front wheels, the car comes stock with some pretty serious negative camber, much more than on the F8X cars. Stock was -1.9 (left) and -1.5 (right) but the shop was able to adjust the control arms to get -1.9 and -2.0 after the alignment. Not bad for a stock car without camber plates!
JTO245898.50
      04-06-2021, 01:08 AM   #28
blackmamba3
Originally Posted by Nkr15 View Post
Cant wait to join the GGC chapter once my car is delivered!!
You absolutely should! If you're on Facebook, be sure to join the local "Norcal G8X" group too. Good luck with the new car!
Nkr151140.50
      04-06-2021, 01:38 AM   #29
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Terrific and accurate review. The new G80 M3 is a winner. Thanks for sharing!
      04-06-2021, 02:21 AM   #30
stevehifi
Impressive, do you happen to know if the front lower control arms have an eccentric bearing that is adjustable?
Also do you happen to know the size of the front wheels? Are they 19x9.5"?
      04-06-2021, 03:02 AM   #31
Ikester19
Ikester19's Avatar
Australia
2237
Drives: G20 M340ix; F30 330i Msport
Thanks for sharing a great review
      04-06-2021, 04:36 AM   #32
M5ZRH
Drives: M5
Thank you for sharing such a detailed write up.
Although 150lbs does not sound much it raises a key question on the weakest link: tires.
With a continuous increase in weight they have much more to deal with and with potential overheating.
You can get bigger brakes, have a stiffer chassis etc but the contact patch with the track cannot be increased proportionally. BMW seems to have done once again an amazing job but at some point you cannot go against the laws of physics.
Instead of adding power, sports cars manufacturers should maybe think of focusing on reducing weight.
      04-06-2021, 05:53 AM   #33
flanast
flanast's Avatar
Drives: e92 M3
Would love to see you follow up this review with another once you are able to time your laps. Butt dynos are not always accurate.
      04-06-2021, 06:19 AM   #34
jmg
jmg's Avatar
19626
Drives: G87 M2
Thanks for the review! I frequent Big Willow and I would be curious to what your corner speeds at each turn was, especially 8 and 9. -2.0 is not a lot of camber for that track and with the extra 150lbs I'm wondering how the outside of the driver front tire held up? Even with -2.7 I would see some decent wear from 30+ laps. How fast was the front straight?
I'd also like to see a timed streets of Willow lap. It's a shame your timer wasn't working, a cheap smartphone app like Harry's or RaceChrono would have done the job quite easily.
2025 G87 ///M2 LCI - Stock
Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3
      04-06-2021, 08:23 AM   #35
///Motivated
Drives: '18 X5M, '18 M3, '16 X3
I don't know the OP, so only making a point, but the butt dyno IS often wrong. I'd be curious to see if it felt planted because the lap times were slow, or if the brakes didn't turn colors, because... the lap times are slow. The stopwatch don't lie!!!
flanast145.50
      04-06-2021, 09:42 AM   #36
GOLFFRR
GOLFFRR's Avatar
11271
Drives: GOLFFRR cart
not wasting anytime! great write up.
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      04-06-2021, 09:45 AM   #37
erictrainer
Drives: 16 F80 6MT MG on SO
Yes they're 9.5. The beauty of this car is that Imran@Evolve already fitted the rear 10.5 to the fronts and it seemed like there was still plenty of room left. If this car can run 305 squared on 11s this will be a track beast.
      04-06-2021, 10:01 AM   #38
uniqueMR
uniqueMR's Avatar
1926
Drives: ...
Thank you
Currently: '22 Ferrari F8T | '24 Mercedes G63 | '24 Porsche GT3RS | '25 BMW M3C | Ducati Pani V4
Previous Others: Audi, BMW, Ducati, Honda, Infiniti, Land Rover, Mercedes-Benz, MINI, Mitsubishi, Porsche, Toyota, Volkswagen
Insta: @theuniquemr
      04-06-2021, 01:32 PM   #39
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
Great seeing you and the G80 on the drive last month!
See you at the GGC Laguna event this year, right!?
I think the two issues that M GmbH faced when creating the the F80/2 were:
1. They were stuck with the base F30/2 platform as a starting point.
2. They weren't allowed to radically re-engineer the chassis because of cost.
I once drove an ex-boss' F30 330i and despised it. BMW went too far toward the cushy
car-for-the-masses end of the spectrum with that generation of 3/4 Series.
And if M were allowed to completely fix the handling with a serious redesign, the cars would have
ended up with a $10k higher sticker, which may have hurt sales.
Engineering is about doing the best with what you're given to work with, and the F80/2 was
the best that M could do with the base car, engineering budget, and price target.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
      04-06-2021, 02:48 PM   #40
BMthusiast
BMthusiast's Avatar
Drives: BSM F80 M-DCT
With a little blackwork it looks more Bavarian to me.
///Meant-to-be-sent
      04-06-2021, 03:36 PM   #41
adc
Drives: 2018 F80 M3 ED
A lot of assumptions there.
You have no idea what the engineering budget was for these two generations of M cars...
You still cannot excuse them putting a common 8at in the car.
You're forgetting that tires make incredible progress across the years. The F80 came out with PSS, and now I have PS4S on it, the increase in traction over the PSS is not subtle especially in the wet. And they're not even "BMW spec" Michelins, still they improve over the PSS in all aspects.
Since now I run tires similar to the G80, an engine tune which puts me in the neighbordhood of the G80 ZCP, I'd be very curious to see if there are any real life differences on the street.
2018 991.2 Carrera T
2019 Z4 30i
2022 X2 M35i
      04-06-2021, 03:39 PM   #42
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
27184
Both sides of the aisle make assumptions.
      04-06-2021, 05:53 PM   #43
calbears
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
2018 M3 CS  [10.00]
2011 M3  [9.50]
2017 M2  [9.67]
Final spec was -1.9 and -1.9 front
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser
2011 E90 M3 ZCP
Past: E90 328i, F10 535i, F80 M3 (murdered)
      04-06-2021, 05:59 PM   #44
adc
My (2018) F80 came with -1.6 and -1.4.
1.9 is not sufficient for track, you need -2.5 and above.
Hmm, I'll amend this, that's what you need on previous generations up to E36. I doubt the geometry on the new car has changed that dramatically to make the car happy with just -1.9, but I could be surprised. I guess we'll know once the fast people start tracking it.
2019 Z4 30i
2022 X2 M35i
