04-12-2021, 11:06 AM | #23 |
Rep 2,175
Did you post the pix???
04-12-2021, 08:46 PM | #24 | |
Rep 67
The Dream is free, the Hustle is sold separately.
04-12-2021, 11:57 PM | #25 |
Rep 91
Drives: 2016 340i
Just installed 15mm in front and 13mm in rear. Front rub very slightly for me when moving in reverse, and weight is shifted slightly forward. Moving forward, no issues. Again, my experience, 15mm has slight rubbing so I would think 18mm would definitely be a problem. My car has P-zeros fwiw, since tires are not exactly identical, when talking about mms.
M4Tejas846.00 |
04-13-2021, 08:28 AM | #26 | |
Rep 2,175
And interesting that it's rubbing in the front with 15mm, in reverse, but not when you have multiple passengers, or when you hit a big dip in the road, or when you turn the steering wheel from lock to lock. I'd assume if it rubs in reverse, that in one of these aforementioned scenarios, it will begin to rub as well. Hmmmmm... Thanks for the update! |
04-13-2021, 08:36 PM | #27 | |
Rep 91
Drives: 2016 340i
M4Tejas846.00 |
04-17-2021, 11:56 AM | #28 | ||
Rep 67
04-28-2021, 09:24 PM | #31 |
Rep 2,175
04-29-2021, 03:48 AM | #32 |
Rep 67
Michelin 4S. And yes, I have the G82.
06-22-2021, 07:09 PM | #35 | |
Rep 1,386
I'm installing 15's on the front with Pirelli's and 10's on the rears. I'll swap them around if they rub badly or else just run 10's on the front. The rear doesn't need much IMO |
JTO245282.00 |
07-21-2021, 01:36 PM | #36 |
Rep 1,299
What is the "Wheel Hanger Pin Set" listed as an option in the IND website?
07-21-2021, 06:38 PM | #37 | |
Rep 1,661
You can find them on Amazon as well -- just be sure to get the M14-1.25 thread (for Gxx BMWs). |
Sedan_Clan25301.50 |
08-08-2021, 02:20 PM | #39 |
Rep 754
Drives: 2022 M3 Competition
It looks like the most popular setup per IND is 15F/12R. Does this offset size even out the wheels so they're at the same depth? It's a little hard for me to tell by the photos.
TIA
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay Last edited by HTTP 410; 08-09-2021 at 04:11 PM.. |
MocoLoco53.50 |
08-29-2021, 12:16 AM | #40 |
Rep 1,083
I ordered 15 and 13 from BMS as well since IND is out of 12mm. They are still en route.
Now I’m a bit worried if those will be too wide. I saw this video where they installed 10 in the front and 15 in the back. |
08-29-2021, 10:19 AM | #41 |
Rep 144
I can confirm if you have the Pirelli’s the 15 will rub up front. For me it only rubbed left front wheel when in reverse with the steering wheel turned right. There is a cooler right in front of the fender liner on the left side. That fender liner has small vents that pass through to the wheel well. After one time of me backing into my driveway 3 of the plastic vents broke which I am having to go and replace. I am going to change to 12 or maybe 10 up front. Moral of the story if you got the Michelin’s you won the spacer lottery too.
09-01-2021, 11:45 AM | #44 |
Rep 630
Drives: 2021 G80 M3
voyagergab634.00 Patton2502939.50 |
