04-18-2023, 07:39 AM | #23 | |
Rep 744
04-18-2023, 08:36 AM | #24 |
Rep 384
I am waiting to hear back from the dealer. I have never run into problems running catless downpipes without a tune. I have owned several bmw's and M's car up to now and all of them was modified. Some was tuned and some was not.
From researching this code, some have had a bad batch of gas, cracked charge pipes, and if anything aftermarket tune was too aggressive, various of reasons. I haven't seen any catless dp's without a tune cause any issues unless it was not installed correctly. Another possible culprit is the O2 sensor are damaged but I think it would have thrown a whole set of different codes. I will keep you guys updated once I hear back. |
04-18-2023, 08:39 AM | #25 | |
Rep 384
That maybe the case but It has been running months without any problems. Only codes pop up before would be the catless codes. The 02 spacer is really just to trick it so it doesn't throw CEL for catless |
07-28-2023, 01:52 PM | #26 |
Rep 338
07-28-2023, 01:53 PM | #27 |
Rep 384
Cleared the code and it never pop up again lol
hellcat2m4228.50 |
07-28-2023, 02:15 PM | #29 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
bad batch of gas?
had that happen to me once when driving on the highway and i was passing a vehicle. the car started stuttering and threw codes. i freaked out a bit since it was on a mini road trip. filled up at a gas station, cleared the code, hasnt appeared since. S58 stock (no tune, no downpipes).
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
bilal6.50 |
07-28-2023, 02:21 PM | #30 |
Rep 384
Yeah I think so too. That happened when I pumped out of a nearby Exxon that I never been to. I went back to my usually Shell station and it has been fine
07-28-2023, 05:47 PM | #32 | |
Rep 124
07-28-2023, 10:38 PM | #35 |
Rep 744
07-28-2023, 11:21 PM | #36 |
Rep 4
Lean means to much air in the combustion chamber causing burnt valves, ringland failure. Numerous amounts of problems. The problem with running catless anything without a tune is you have a pre cat sensor and a post cat sensor. That pre cat sensor is your AFR sensor. It counts on the post cat sensor to send its signal to the DME. The DME than will adjust the air/fuel mixture. Because that cat has to burn off the hydrocarbons. So when you take a cat out of the equation. That post cat sensor is sending information to the DME and the car is trying to correct it. That code will be back unfortunately. I’ve seen way to many people run high flow cats and or catless WITHOUT A TUNE and destroy engines doing that. The off the shelf tunes are not it. You want to do it the proper way get on a dyno get tuned properly. And go back every once in awhile to get retuned. Properly tuned cars don’t have that issue. Because the AFR sensor has a value it’s looking for that’s programmed by the tuner. And doesn’t need the post cat sensor to tell it what to do since there is no cat there. PAY TO PLAY IS THE NAME OF THE GAME.
07-29-2023, 11:56 AM | #38 |
Rep 1,467
Bingo. I see no reason to run catless DP with no tune. 🤷🏿‍♂️
Needsdecaf6949.50 |
07-29-2023, 12:21 PM | #39 |
Rep 259
07-29-2023, 09:55 PM | #40 |
Rep 124
07-30-2023, 07:50 AM | #41 |
Rep 4
The problem with running catless anything without a tune is you have a pre cat sensor and a post cat sensor. That pre cat sensor is your AFR sensor. It counts on the post cat sensor to send its signal to the DME. The DME than will adjust the air/fuel mixture. Because that cat has to burn off the hydrocarbons. So when you take a cat out of the equation. That post cat sensor is sending information to the DME and the car is trying to correct it. You want to do it the proper way get on a dyno get tuned properly. And go back every once in awhile to get retuned. Properly tuned cars don’t have that issue. Because the AFR sensor has a value it’s looking for that’s programmed by the tuner. And doesn’t need the post cat sensor to tell it what to do since there is no cat there.
DieselG80XC118.00 |
07-30-2023, 08:41 AM | #42 | |
Rep 259
07-30-2023, 12:15 PM | #43 | |
Rep 744
I've run catless DPs for years with JB4 on multiple platforms, never had any issues. |
07-30-2023, 12:22 PM | #44 | |
Rep 744
