04-06-2023, 11:54 PM | #26 |
Rep 1,360
Glad I saw this thread...the one piece gloss version it is.
Subjective, I know, but the fact that it sits further "inside" the grille holes...does it bother you or look odd in any way?
2022 M3 Competition xDrive Portimao Blue
04-07-2023, 01:49 AM | #27 |
Rep 751
I actually really like it to be honest. At first I was skeptical, but then I saw it and I really liked it.
04-07-2023, 01:07 PM | #28 |
Rep 18,880
I agree 100%. The "less is more" approach really works on this.
m4ml1895.00 |
04-18-2023, 06:07 PM | #29 | |
Rep 196
Drives: BMW M3
04-18-2023, 07:02 PM | #30 |
Rep 751
EAS ended up removing the front foam bumper completely. The rear foam bumper is still there. If this wasn't done then you'd have to cut out a large chunk where each PDC sensor sits. From other posts about the ABS install, it looks like about a 4"x4"x4" section on each side.
05-02-2024, 07:32 PM | #31 |
Rep 94
Well, it's 2024 now. I ordered the carbon fiber Vorsteiner grill completely unaware that this issue even existed, and I had it installed today.
Just like OP described, my PDC sensors were going berserk at practically every stoplight I happened to be behind a car. Even at the drive-through, it was incessantly going off. I've probably pressed the PDC button like 20 times on my drive back. Needless to say, this is a very frustrating situation. Honestly, this issue shouldn't be tolerated from what one would assume to be a reputable quality brand. I could have gotten an Alibaba one for like $600 and saved some money, but explicitly decided to go with the Vorsteiner one to avoid issues like this. I've already paid $500 to have it PPF'd and another $700 to have it installed along with the front lip. Not sure what to do now honestly. I basically work two full time jobs, I don't have the free time to chase after this issue. I'll probably contact Autocouture and see what options I have. Last edited by jamabdi; 05-03-2024 at 02:56 PM.. |
05-02-2024, 08:25 PM | #32 |
Rep 539
I got the one piece Vorsteiner black gloss grill. The sensors fit a bit funky. I want to code out ACC if possible and install OEM CSL grill. Probably need a bit more fabrication. TTW spent too much time getting the GD thang to fit the ACC bracket. NOT impressed with this "authentic" bullshit.
05-02-2024, 09:15 PM | #34 | |
Rep 751
I thought I remember Vorsteiner redesigning the CF grill to fix this issue. I haven't heard much about this problem in the past year. Either people stopped buying them, or they fixed it.
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70 Last edited by m4ml; 05-02-2024 at 09:22 PM.. |
05-02-2024, 10:08 PM | #35 | |
Rep 94
I also wasn't even aware that there's a rubber grommet, but upon closer look, it seems mine are either missing or recessed into the grill. I checked my factory grill, and the grommet isn't there either, so I'll call my shop tomorrow and ask about it. Hopefully, this is the issue since it looks like a simple fix. In the meantime I'll either try to reset the iDrive or turn the PDC sensors off altogether. Someone mentioned that doing this got rid of their issue in this thread so might as well give it a try: https://g80.bimmerpost.com/forums/sh....php?t=2027286 |
05-02-2024, 10:23 PM | #36 | |
Rep 1,779
Sensor fitment on the NW Carbon Haus grill for reference. No PDC issues. |
05-04-2024, 08:49 AM | #37 |
Rep 65
I had the same issue as well as others with my vorsteiner grille. In speaking with them, the rubber grommet is not supposed to be installed in the latest version of the grille...Yes my sensors do stick out further than in the stock grille.
05-04-2024, 12:20 PM | #39 |
You got my money?
3250
Rep 4,716
Drives: Ice Cream Truck
I had vorsteiner rear diffuser on my old E92 M3. That shit never fit properly. I even had vorsteiner install it and they used a dremel on it to make it fit better. lol.
Never bought another carbon piece from them again. I did buy some of there venomrex wheels for my old raptor years ago. The wheels were good quality and held up nicely. Them sensors look like long nipples to me. lol.
