11-21-2023, 06:12 AM | #23 |
Rep 1,001
Drives: 2024 M4 Comp X-Drive
In the end what matters is what’s to the wheels and trap speed.
The trans, differential, light forged wheels are all likely to be very efficient compared to what’s being used as the correction factor by the chassis dyno to guesstimate crank horsepower. For example you compare the efficiency of a drag car with built TH400, 5000rpm stall non lock up converter, 9 inch rear end, 35spline axles and a heavy driveshaft against the BMW and it’s no comparison in terms of parasitic loss. (A 20-25% loss on a drag car could be 8-10% on a modern car like the G80/G82) Either way any car trapping 122-123mph at 4100pds with driver is flying for a stock street car.
11-21-2023, 07:30 AM | #24 |
Rep 127
What if BMW/ZF have figured out a way to reduce the drivetrain losses from the crank to the wheels? Has anyone been able to measure both on the same vehicle to compare? I think most people/dyno operators assume a 15% DT loss? What if it's actually <10% putting the crank and wheel HP numbers closer together?
MT6736.00 TractionControlDelete4604.00 |
11-21-2023, 10:19 AM | #25 | |
Rep 447
11-21-2023, 11:44 AM | #27 |
Rep 27,645
nice,
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
MT6736.00 |
11-21-2023, 11:57 AM | #28 | |
6923
Rep 3,276
Drives: E46 M3 Coupe/G80 M3CX
11-21-2023, 06:18 PM | #29 | |
Rep 388
Also, I think the $25B penalty that VW was hit with is probably a disincentive to any OEM contemplating knowlingly breaking the rules. Additionally, I am not sure what BMW would gain by certifying at a lower power output than the engines actually deliver. If they were consistently delivering 8-10% over the certified level, they would want to use that in the marketing material…
TJR
11-21-2023, 06:52 PM | #30 | |
6923
Rep 3,276
They also wouldn't be hit with anything like 25b in penalties for this because there really are no damages to consumers (ie, no misleading fuel consumption and environmental emissions figures). Like VW killed people and they still didn't care. |
DavidXJ669.50 |
11-21-2023, 08:23 PM | #31 |
Rep 165
I said it had to be at least 540hp the first time I drove my G82 comp two and 3/4 years ago!! Good to see the numbers verified!!
11-22-2023, 06:13 AM | #32 |
Rep 402
11-22-2023, 11:02 AM | #33 | |
Rep 388
Agree, they wouldn't be fined anything substantial. VW cheated because with the parameters needed to meet the emission requirements the cars performance was unacceptable. So they sensed that the vehicle was on a test cycle and ran a different calibration from what the vehicles ran on the road - I seem to recall that it was steering related, when no steering input was detected on the emission chassis rolls it ran one setting, when steering input was detected on the road it ran a different one... or maybe that was a cheat used by somebody else ) This situation is different... the vehicle (engine) is performing better than they claim, so why not take credit? Perhaps the truth is that they now have enough conformity of production data to say with certainty that the engines are consistently giving more power, hence the rumored power bump in 25MY. I'm happy either way.
TJR
Forzanerazzurri6922.50 Tobster3638.50 |
11-22-2023, 11:33 AM | #34 | |
6923
Rep 3,276
s58551.00 |
11-23-2023, 02:06 AM | #36 |
Rep 324
I think I might have said this before in another similar thread. The engines will give a range of outputs due to air pressure (altitude), ambient temperature, fuel quality etc. the DME will aim to compensate but I am not surprised that sea level and reasonable temperatures give a bit more power than quoted. Plus someone previois stated that dyno’s are only good at measuring relative power differences as they are not calibrated and comparing between machines is a fools errand.
MT6736.00 |
11-23-2023, 05:52 AM | #37 |
Rep 488
It's a matter of choosing your poison. When I had my custom/performance shop I owned an 'engine' dyno. For me the engine dyno was more convenient because I built engines and a lot of the engines went into racing boats which would make a chassis dyno impractical. I felt the engine dyno was more accurate when comparing data between dynos as it was direct drive, force is measured with calibrated load cells, and all ambient factors were compensated for in a known fashion with the exception of fuel quality. However, it wasn't real world because of the losses in the vehicle/boat it was installed in.
Chassis dynos make getting horsepower numbers easier without removing the engine from the vehicle and give a better idea as to how the engine/vehicle will perform in real life. But since there is a lot more variables due to mechanical parts and coupling the dyno to the vehicle there can be a lot more inaccuracy between dynos making them more valuable as a reference in tests performed on the same dyno. Another factor is how the tests are performed. Energy gain or loss due to rotational mass can add or detract from the numbers depending on rate of change of speed or direction of the test. If one is trying to convert between BHP and WHP that is a crap shoot unless one has consistent data on the vehicle losses. Last edited by turbojg; 11-24-2023 at 12:07 PM.. |
MT6736.00 davidmct-M3237.00 |
11-23-2023, 06:10 AM | #38 |
Rep 577
I think they do it for competitive and marketing purposes. Isn't it fun to see a head to head competition with a ~3/4/500hp Audi, MB and BMW and for some reason the BMW is (almost always) punching above its weight class.
11-24-2023, 10:06 AM | #39 | |
Rep 426
“And so the BMW, with the worse power/weight ratio, somehow managed to win this drag test!” |
MT6736.00 |
11-24-2023, 10:24 AM | #40 | |
In the Details
1812
Rep 867
Drives: Yes
Garage List 1963 Split Window [0.00]
2022 R8 Quattro Spyder [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Grand Highlander [0.00] 2024 Civic Type R [0.00] |
Put them all on the chassis dyno back to back and they make what they make. Put them all on the drag strip same day/time and they run what they run. I'm not saying that the BMW making more power than BMW rates them at is a lie, I am saying the testing method is different and if you test them all like BMW does, they will all show less power. That's not the same thing as saying a car makes 500 and it really makes 550. If you don't take the same test, you can't compare answers. I am not talking about the "what" but rather the "why." |
stormlv939.50 |
11-24-2023, 10:32 AM | #41 |
Rep 477
Interesting point! Has there been anything publicly announced on what changes with the 2025 Car have resulted in more power?
12-23-2023, 12:08 PM | #42 |
Rep 7
Hi my results on a dyno seems low? 23 Comp xdrive.
I think they didn’t even put a fan in front of the car. Just 1 run. Mods = 300c dp + single mid pipe and a MST intake. Otherwise stock. 326wkw is 437whp I’m going backwards lol ? |
MT6736.00 |
12-23-2023, 01:21 PM | #44 | |
Rep 283
