05-16-2024, 08:37 PM | #23 |
Rep 255
Prior owner of an F82 and MB E63S with CCBs. They definitely looked great and had so little brake dust. Also had an F90 with steel.
Performance-wise I didn’t really notice much of a difference in street driving. While maybe it’s true that there is more unsprung weight from the rotors, the calipers seem to be bigger than the steel so that kinda eats away at the rotor advantage. And let’s be real, is anyone really gonna notice the difference in performance handling from less unsprung weight? I just ordered a ‘25 G82 with the steel on FBWM with the Fiona interior. Maybe it sounds lame but one reason I went steel was to get the red calipers to match the red interior. And for me, the gold calipers don’t go well with FBWM compared to other exterior colors. So I’m in the camp that the CCBs are great but aren’t a must. |
KevinGS4117.00 |
05-16-2024, 11:48 PM | #24 | |
#savethemanuals
2565
Rep 2,044
I thought Tanz + CCB + Fjord worked well, maybe Brooklyn as well, or a Frozen color with Fjord. Specced CCB’s and actually changed from Fiona to Black buckets. I may do custom headrests outlined with a touch of gold alcantara to spice it up a bit. |
utsteve98184.50 |
05-17-2024, 01:29 AM | #25 |
Rep 62
ObsessedM3C118.00 Limegrntaln14080.00 |
05-17-2024, 07:37 AM | #26 | |
Rep 485
Seriously, the best mod you can do for the money if you have steelies.
StreetLethal62.00 |
05-17-2024, 08:53 AM | #27 |
Rep 3,264
Plenty of users here that have first-hand experience. The iSweep 2000s produce much less dust and still perform as good or slightly better than OEM.
StreetLethal62.00 |
05-17-2024, 10:09 AM | #28 |
Rep 1,793
This is the biggest downside of CCB’s and why I passed on a G80 that my buddy had in stock equipped with the CCB’s and ordered my car without.
~ 24 M4 Comp
~ 24 X3 M40 ~ Prior BMW's - Too many to list here (27) |
05-17-2024, 10:18 AM | #29 |
Rep 102
I have CCB, only optioned them because I hate brake dust and don't want early onset arthritis in my fingers from cleaning wheels. They do squeal occasionally but squealing never bothered me even with my current and past performance cars that had stock Brembo's.
I'm registered for 3 track events (6 days' worth since each event is 2 days) this year with my g80. So, I'll see how they hold up. But other than that, stock steelies with ceramic brake pads are the way to go if you don't track and want less brake dust/noise. Last edited by Trevorr; 05-17-2024 at 10:49 AM.. |
05-17-2024, 10:33 AM | #30 |
Rep 1,889
I was recently at the bmw performance center in SC and was a little surprised to find that every single m3 , m4 and m5 that is used for M driving school and other programs were equipped with the CCBs. Those cars get absolutely absused all day every day, and the instructors mentioned that they still get quite a long life out of each set of rotors.
beaver9ght62.50 Limegrntaln14080.00 |
05-17-2024, 10:41 AM | #31 | |
Rep 312
2022 M3 Competition xDrive
2022 M340i 2018 M3 Competition 2015 335i |
05-17-2024, 10:50 AM | #32 | |
Rep 312
1) Steel brakes are much cheaper, and you can have two sets of pads. Street vs track. 2) CCBs are very expensive, but they're even more expensive to maintain. The full replacement set is ~$18k and if they get rock chips, you're paying a few thousand bucks just to repair one rotor. Plus, aren't the CCBs worse than steel brakes when it comes to squeaking? They look great, no dust, and weight less, but I don't think they have a serious advantage in performance or make sense financially.
Trevorr167.50 |
05-17-2024, 11:20 AM | #33 | |
Rep 62
On the other hand, there’s a few user feedback confirmed isweep can’t last autocross or track events where oem pads have no problems. https://g80.bimmerpost.com/forums/sh...&postcount=181 An extremely quick wear under this circumstance indicates the pad can’t handle high heat repeated stops like oem did. Neither facotory steel or CCB will have that much issue when driving your M like a M. With CCB, one can worry no dust and still do occasional casual track without safety concern. And I repeat the suggestion of picking CCB is based on the condition money is no issue. |
05-17-2024, 11:27 AM | #34 | |
Rep 62
05-17-2024, 11:31 AM | #35 | |
Rep 102
I have another car that I do the swap like you say. It sees 3-4 events, which is 2 track days each event and like 1000 miles per year on track. Can't imagine how often I'd replace CCB. I rarely see people with CCB when I go because they don't really provide any tangible advantage other than virtually no brake fade, but you can do cheap mods that really advance cooling such as air deflector plates to cool the brakes to have virtually no brake fade. |
05-17-2024, 11:52 AM | #36 |
Rep 38
All brake pads are a compromise. The rotor's job is to dissipate heat, ceramic does better with this than steel. Pads create the friction, and you have to pick your balance of bite, fade, noise and wear. I'll take my quiet iSweep 2000s over the stock pads any day. Takes the squeal out of daily driving, and so far they've held up well on my backroad blasts with repeated high speed stops. Haven't tracked, so can't speak to that. But I find it unacceptable to be squealing to a stop in a $90K car, despite the stock pads supposedly making it track-worthy. No one is a clown, you both just have different needs/wants from your pads. I do find it interesting that the M Performance cars are fitted with CCBs, kinda upends the rumor that CCBs aren't as favorable for the track...
05-17-2024, 11:55 AM | #37 | |
Rep 180
How is the initial bite on the 2000s? My main motivation is reduced brake dust, but I don't want to lose factory feel/performance either. I've read some hit or miss reviews about 1500/2000s. I hear they are great for reducing dust. |
05-17-2024, 12:39 PM | #38 | |
Rep 1,878
05-17-2024, 12:50 PM | #40 | |
Rep 2,204
Nobody comparing CCB to anything else. But as far as Non CCB pads iSweeps are very good and produce less dust. You can foam at the mouth all you want but has been tested by lots of people on this forum. So yes you are a clown. Nobody else. Just you. |
05-17-2024, 01:50 PM | #41 | |
Rep 62
Isweep is good pads but can never be compared to factory full CCB, which is what we are discussing here. And again, I urge you get Corolla to suits you use case better. |
05-17-2024, 02:18 PM | #42 | |
Rep 2,204
My comment was and is regarding stock steel pads and dust. |
DTMfan479.00 |
05-17-2024, 02:32 PM | #43 | |
Rep 62
We already got that you love your isweep. Now move on and let us hear more ccb owner’s opinion. |
05-17-2024, 02:35 PM | #44 |
Rep 7,147
If you drive spiritedly and plan to keep your car past the 50k mile mark, the CCBs will end up paying for themselves. For the people that drive rather aggressively, on the norm, will find out that you need to replace the OEM pads in 12k to 15k miles. If and thats an "If" (I know you can do them, yourself) have zero know how or capability on changing BMW pads, and you go the dealer route, you're going to need 3-4 sets of rear pads, and possibly a set of rotors, and by that time, your front pads, and possibly rotors are going to need to be replaced, by the time you get to 60k. All the while the CCBs, have barely even started to wear. The benefit of getting them up front, is, not having to deal with dusting, and them not wearing out, unless you track heavily. And its not even the fact that the CCBs rotors wear out, they get heavily oxidized from the excessive heat cycling. I would imagine you could double or even triple the life of CCBs with some good quality brake ducts.
My service writer has a 2016 F82 with CCBs, with 115k miles on his car, and its seen 1-2 track days a year, and the factory installed pads are at 8mm, 11mm is new.
YT: G Dubyou |
beaver9ght62.50 seis-speed2564.50 |
