11-09-2021, 01:36 AM | #23 |
Rep 1,103
I would get under the car and measure the distance between the 2 lift point pads. I don't remember the exact numbers but I think the spread between the pads was 68" and to the outside edges was 76". So center to center was 73". So the 6000 ELX would make that reach with its max reach of 76". However, when the jack is flat on the ground it will be much longer. Maybe too long to fit between the tires. Again, these numbers are off the top of my head and may not be exact. You need to measure the distances yourself to see what will work. The 5000s work for me with the 1x3 square bars.
11-09-2021, 01:58 AM | #24 | |
Rep 171
The frame length of the 6000 is 86" which should fit just fine between the front and rear wheels, but I'd have to go and measure again to confirm.
Steve
'22 Black Sapphire M3 6MT '23 Individual Signal Green X5M Competition Sold: '17 Ibis White R8 V10 Plus Instagram: @par__m3 |
11-09-2021, 07:37 AM | #25 | |
Rep 263
11-09-2021, 03:21 PM | #26 |
Commander-In-Chief
2206
Rep 8,950
Drives: 2023 M2 Coupe, 2020 GLE 450
Jacking points
Has anyone run across a pic of the bottom of the car, like this one of the E46? This shows the jacking points.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
M4Tejas847.50 |
11-20-2021, 07:50 PM | #28 |
Rep 72
Drives: '22 G80 Portimao XDrive Comp
I use jackpoint jackstands. you use the hat or top to lift the car with a floor jack and then slide the stand around and lower the hat onto the stand. I have had them for years.
11-20-2021, 10:39 PM | #31 |
Rep 1,683
I've developed a system on how to jack up the car on all 4 wheels. You'll need a puck that's compatible with BMW, 4 jack stands, and a jack.
Step 1: Lift up the car from the front jack point on either side of the car and lift it high enough where you can place a jack stand on the rear jack point. Step 2: Repeat above step for the other side of the car. At this point both rear tires should be on jack stands. Step 3: To lift the front tires, underneath the car in front center there is a jack point (circled in red in the pic below) which would lift both front tires up, lift it high enough where you can place jack stands on either side. Now your car should be on all 4 jack stands. Note: If your jack is not a low profile jack then you'll need to put 2x4s under your front tire to give it a lift so you can slide the jack underneath. If you have the crescent style jack stands you'll need an adapter to convert them to the BMW style. I bought those off ebay. |
11-21-2021, 05:25 AM | #33 | |
Rep 359
The F10 M5 being rwd had the front center jack point, but with the F90 going awd this point does not exist. I read of someone damaging their car trying to lift there in the f90. So just a heads up for those with AWD G80s to check to make sure. |
11-21-2021, 08:50 AM | #34 | |
Rep 1,683
11-23-2021, 09:28 AM | #36 |
Rep 1,367
11-23-2021, 01:09 PM | #37 |
Rep 281
11-23-2021, 01:41 PM | #38 | |
Rep 72
11-23-2021, 08:06 PM | #39 |
Rep 164
These are a great idea! Did you get the BMW adapters or are you using one of the standard plates?
11-23-2021, 08:18 PM | #40 | |
Rep 72
https://shop.jackpointjackstands.com...ads-JSBPMF.htm |
11-23-2021, 08:38 PM | #41 | |
Rep 1,683
evanescent031033.00 |
11-23-2021, 09:11 PM | #42 | |
Rep 72
http://www.jackpointjackstands.com/t...fications.html |
11-23-2021, 09:39 PM | #43 | |
1967
Rep 1,927
Drives: E92 M3
But if you're not getting a great deal on them (I did), I'd spend a bit extra and go the Quickjack route.
11-24-2021, 08:14 AM | #44 | |
Rep 2,142
How did you get a deal on them? I agree the Quickjack would be better for slightly more. |
