View Poll Results: DCT or traditional AT? | |||
I prefer a DCT. | 235 | 60.57% | |
I prefer a traditional AT. | 32 | 8.25% | |
Either is fine with me. | 53 | 13.66% | |
I don't care. No manual, no purchase. | 68 | 17.53% | |
Voters: 388. You may not vote on this poll |
07-21-2020, 11:09 AM | #375 | |
Moderator
7526
Rep 19,368
Those looking for controversy will have to wait for the next generation factory GT4 BMW. We don't know yet if it will be also be based on the G82 M4 or if they will switch to the G87 M2. But since it is highly likely that the G87 will also switch to a ZF8 transmission (with a 6MT still an option), it is a good bet that the GT4 racer will also use that transmission. |
07-21-2020, 03:28 PM | #376 | |
Barge driver
8715
Rep 12,456
You've had short test drive so maybe you should leave the commentary to others....rather than just making stuff up? (just a suggestion...) If you don't like the thought of the ZF8 that's fine I get that many hate the MDCT and prefer a manual, but car forums are often plagued by people making statements about cars that are untrue and that helps no one in the community gain insight, you do the forum a disservice with posts like this.
730d/Z4C
07-21-2020, 06:11 PM | #378 | |
General
21132
Rep 20,742
Drives: 2021 911 turbo
M8 GTE M4 GT3 M2 GT4
07-22-2020, 10:20 AM | #379 |
Rep 585
Didn't notice lag or any noticeable difference compared to DCT when I was doing fast laps in F90.
Let's be honest, ZF 8 speed will have a broader range of talents compared to DCT. Not to mention having a switchable RWD should offset some of the fun you'll miss with DCT. When it comes to ZF8, it all comes down to software that each car manufacturer puts in it. I am sure there will be software updates (from bmw or aftermarket) if there are issues. |
07-22-2020, 01:47 PM | #380 | |
Rep 2,370
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Now that I acquired a mint DCT E92 M3, I really don't get the complaints about its shift quality. If you drive it like a manual-give it a half clutch respect for creeping- it is a very fast and smooth transmission. Actually much smoother than ZF8 that can't seem to figure out the right revs each shift.
Pass me if you can.
Nugget649.50 |
07-22-2020, 06:54 PM | #381 | |
Rep 1,067
07-22-2020, 11:18 PM | #382 | |
Rep 761
07-22-2020, 11:55 PM | #383 | |
Rep 1,067
07-23-2020, 12:34 AM | #384 | |
Rep 267
It does indeed seem not to be that snappy compared to the DCT. Too bad... |
somer973.50 |
08-03-2020, 12:54 PM | #385 |
Rep 106
I was able to drive today a longer stint in an M5 F90. I REALLY hope the G80 won't feel like the M5. In full acceleration the "rubberness" of the transmission really disturbed me. If the G80 feels anything like that, I can say with certainty that the F80 is going to be my last M3. The front I can get used to, but the F90 felt also so "distant". Better than the F10 yes but not good. F10 is in my opinion is the worst M-car ever made in road and tyre feel, so thats not a good comparison.
stein_325i25175.00 |
08-03-2020, 01:14 PM | #386 | |
Rep 7,037
An X3M owner here with a lot of DCT experience wrote that the mechanical feel of the DCT is not there and that indicates the rubbery feel you talk about. |
08-03-2020, 08:43 PM | #387 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I noticed the same with the F90.
I've never understood the hype about the ZF8, it just feels like a pretty good auto box to me. Hopefully it feels a bit sharper in the G80. |
08-04-2020, 07:05 AM | #388 | |
Rep 106
I hope so too. In the F90 I had to change gears in first and second at 5k rpm as otherwise I was hitting the limiter and then it was game over. Recovering from limiter seemed to take an eternity. Its a fast car yes but that doesn't explain the slow reaction of the transmission. |
08-04-2020, 09:06 AM | #389 | |
Rep 1,067
Keep hoping though it will be the same 8HP76X unit in the X3M/X4M with the same exact programming with the same exact gear ratios. Trash. |
08-05-2020, 08:28 AM | #390 |
Rep 361
So I see there is a lot of discussion about the different transmissions. There are some points you always hear in favor of the DCT (and let's be honest here, the converter is the better option in many scenarios except very spirited driving or track use) and the main point is the faster shifting time.
If anyone is interested in some more or less factual evidence, I did some research and timed multiple videos of M4s and X3Ms to see their shift times. It actually took a bit of time to find videos for both cars where you could see the shifting time setting, the person was manually shifting at full throttle and see the padels and the rpm gauge at the same time. For the X3M in the fastest transmission setting from the moment the shift pedal is pressed until the rpm gauge is fully in the next gear (i.e. when the needle is dropped down to ~4k rpm) it takes pretty much exactly 0.5s (14-16 frames in 30fps videos). You can time the shift time in the linked video above and I also used some videos uploaded by carwow (e.g. this one). The M4 Competition with DCT I used multiple videos from AutoTopNL and it indeed shifts quicker. From pedal press until the gear display changes it's 10 frames (60fps video), but the rpms didn't drop at that point at all. (I think at that point the next gear is engaged, but the clutch is not yet released). Until the rpms start to drop it takes another 10 frames and until the rpms fully drop to 4k rpm it takes yet another 20 frames. I do think there is some delay in the gauge (not digital) so in the best case scenario if you say the gear is engaged when the rpms start to drop its 20/60s = 0.33s and if you say the gear is engaged when the rpms hit 4k its 40/60s = 0.66s. The truth is probably somewhere in the middle. I'm leaning more towards the first scenario, so the shifting times are ~0.33s for the DCT vs ~0.5s for the converter. Not that big of a difference as I expected. Of course there are other factors that play into it, e.g. the shifting characteristic/emotions (the little jerk from the clutch in the DCT). Maybe some members that have a X3M or a M4 can make dedicated videos to let facts speak instead of emotions. Alternatively, maybe it is possible to log the shifting times. |
08-05-2020, 09:28 AM | #391 | |
Rep 1,067
I did a quick search and found an AutoTopNL vid with a decent example showing the gauge cluster along with the audible click of the paddle and following shift and "slam" into the next gear. Similarly he shifts at ~7100 in second gear and doesnt run into the 7200rpm limiter because its a dual clutch and not a slushbox. Edit: Also I want to make clear the distinction of "shift time" as being a term for the entire delay from paddle input to actual gear shift. To me those are 2 separate actions and the main gripe is the "paddle delay" from the ZF not the actual physical gear change. From what I understand the physical gear shift time is actually less than the DCT but the paddle delay is much much longer. Starting ~4:50 in this video: Honestly I'm tired of beating this topic to death, people are gonna believe what they want to believe. Last edited by somer; 08-05-2020 at 09:43 AM.. |
Flamingi532.00 |
08-05-2020, 10:16 AM | #392 | ||
Rep 361
Again, to see if the converter is that much slower it might be possible for some tuner or experienced coder to log those values and report back with numbers, which do count more than anyones feelings. Frankly, in an objective discussions your feelings just don't matter (not your personal ones, somer, I mean feelings of any person in general). Unfortunately, there are just far too many people talking about heritage, homologation cars or whatever bs, they just are delusional and stuck back in 1990 when the M3 E30 was the hot shit (and back then they may were right, but things change people!). Sums up this whole thread perfectly. |
somer973.50 |
08-05-2020, 10:52 AM | #393 |
Rep 2,601
08-05-2020, 12:14 PM | #394 |
Rep 7,037
“Sums up this whole thread perfectly.“
Agreed but I find this thread as one of the better here, it’s a good mix of technical, observational and subjective comments without excessive “fighting”. The change of DCT to AT is one of the major technical changes and deserve some discussion. I’m not very partial since I have enough experience to know I’m ok with any of the later iterations of the transmission types MT, DCT and AT but I’m still interested in the detailed differences technical and observed. |
08-06-2020, 06:14 AM | #395 |
Rep 106
I have my second DCT now, the first was in the E92 2011. The only problem with DCT in my F80 is when changing into reverse. It takes some time to engage the R but its not a big issue.
My F80 feels very fast when changing gears in full throttle. Also downshifting several gears no problem. For me its more how it feels and the AT in the F90 felt reeaalllyyy slow. |
somer973.50 |
08-06-2020, 02:11 PM | #396 |
Rep 4,118
