12-03-2023, 07:46 AM | #353 |
Rep 33
Has anyone tried a 20x11 +15 square setup? I compared with a wheel fitment calculator and it would only have 1 mm less inner clearance than running the OEM rear wheels (20x10.5 +20) up front, and outer clearance is the same as those running the 20x10 +15 with a 12 mm spacer (which it seems some are doing successfully). I assume it would be tight up front (and would likely rub on the fender liners) and finding the right tire size would be key, but seems like it could potentially work. Just curious if anyone has tried it?
03-13-2024, 05:24 PM | #354 | |
JY01
697
Rep 304
Second pic is the rear wheel up front, and third is the front. |
03-14-2024, 06:01 AM | #355 | |
Rep 33
03-15-2024, 01:30 PM | #356 |
JY01
697
Rep 304
Just an update, I tried bolting the 11” wheel with 295 tire on the front but the sidewall sticks out too much and hits the shock. I think you’d need at least a 5mm spacer or a narrower tire.
03-17-2024, 03:07 PM | #357 |
DHS
229
Rep 4,043
Drives: 2023 M4, 2020 Land Rover
I am running TE37s with custom offsets with a 20x10 +8 front and 20x11 +10 rears with a 275 and 295 tire and lowered front and rear and don’t rub at all. I could also run a 305 rear tire. You could probably run 295s up front in a square setup. I should have tried it but it’s flush as is. I could run a 285 front tire and wouldn’t rub as well.
You could run a 285 square tire on a 20x10 setup or 10.5 setup. |
OGOverkill172.00 |
03-25-2024, 11:29 AM | #358 | |
Rep 97
OGOverkill172.00 |
04-15-2024, 07:21 PM | #361 |
Rep 33
04-15-2024, 07:29 PM | #362 |
Rep 33
Here is mine. Needs a small spacer up front at least.
calbearz2437.00 JY01697.00 |
04-17-2024, 01:18 AM | #363 |
DHS
229
Rep 4,043
04-17-2024, 03:10 PM | #364 |
Rep 429
I'm going to run 8mm up front and 5mm in the back. The rear can come out a bit too.
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive |
04-17-2024, 05:02 PM | #365 |
DHS
229
Rep 4,043
04-18-2024, 07:06 PM | #366 |
Rep 194
Drives: 2020 M2 Comp.
04-19-2024, 10:03 AM | #369 |
Rep 25
04-21-2024, 11:59 PM | #370 |
DHS
229
Rep 4,043
04-29-2024, 10:43 PM | #372 |
Rep 11
