10-09-2022, 01:41 PM | #309 | |
Rep 708
When you’re putting back to stock, you’ll definitely need ISTA to put the solenoid motor into the installation position.
There is a workshop function to do this in ISTA. Quote:
10-09-2022, 03:21 PM | #310 | ||
Rep 1,001
Drives: 2024 M4 Comp X-Drive
10-10-2022, 03:04 PM | #311 | |
Rep 1,001
Great suggestion on this mod.
10-11-2022, 05:29 PM | #312 |
Rep 609
As I was the first to do this almost 18 months ago, I can tell you the plastic ties do not melt. Not on hot exhaust piping.
10-12-2022, 01:12 PM | #313 |
Sith Lord
3460
Rep 893
Drives: G80X, Mazda 3 6MT (daily)
I just did this today after debating whether to spend $600 on a valve controller or not (Dahler). It was extremely easy, and I used zip ties. I'll keep an eye on them now and then. The car isn't even loud with the valves open so I see no reason to even get a controller. I just hope there's no drone on the highway (shouldn't be).
Always two there are.
Gfit2758.00 |
10-12-2022, 02:26 PM | #314 | |
Rep 1,001
MMM.PWR3459.50 |
10-12-2022, 02:42 PM | #315 | |
Sith Lord
3460
Rep 893
I know when I had the AA midpipe + axleback I had terrible drone, especially around 2K, hoping the valves alone don't affect anything.
10-15-2022, 06:47 AM | #316 |
Rep 20
Hi everyone!
Has anyone tried to do this on an European spec M3, one with OPF as well? I wonder if it’s going to be ok or it will interfere somehow. In case you do the tie modification with a wire and want to get back to the factory setup can you reconnect the actuator without having to use the ISTA? I suppose you should be able to do that but you have to realign the valve with the actuator motor and this may take couple of tries. Thx |
10-15-2022, 10:54 AM | #317 |
Sith Lord
3460
Rep 893
You don't need to do any coding. Mount the servos back on the car and plug them in. Start the car and hit the exhaust button, that should move the servos and catch the valves as they move. I did this in the past when reinstalling my OEM exhaust.
10-17-2022, 11:01 PM | #319 |
Rep 483
10-18-2022, 03:35 AM | #320 | |
Rep 426
I have done this on my EU car and no issues at all. If you want to return to stock, you just get a screwdriver and align the valve to the actuator. There is no need to use ista. That's all there is to it. |
10-18-2022, 12:07 PM | #321 | |
Rep 20
But I really don’t think it is going to be the case |
10-18-2022, 01:11 PM | #322 |
Rep 426
Yea. Free mod. You will be surprised. It can be loud but in a good way and not obnoxious. And if the rest or your exhaust is stock then you'll be okay.
12-24-2022, 02:03 AM | #323 |
Rep 20
I opened the valves fully and removed the inner piece and spring that are connecting the valves with the actuator, as described above here.
All good, sound is great not very loud. I am happy about it. I had a CEL after a while. Checked it with OBD fusion and it was P24FD - something with the particle filter. I cleared it and everything is fine now. I will see if it is going to reappear or not. Hopefully not. |
12-24-2022, 04:47 AM | #324 | |
Rep 1,319
Hi Mate, Just to check, you are running standard exhaust, OPFs and all ?, do you get any more pops and bangs, or is it just more perceived volume, from valves open at 100% all the time ?. |
12-26-2022, 08:49 AM | #325 |
Rep 67
so if someone wants to play around, there is a remote module that can be close/opened as long we can tab in. Of course, a voltage meter is required to check whether is 12v or input from the existing wiring plug.
If all is tested and works , of course, nêed a new connector for male and female. $200 is not worth the trouble however if someone is interested on figuring out stuff, this is a fun wêekend project/ https://www.amazon.com/Wireless-Tran...08CCVJWL9&th=1 |
12-26-2022, 11:56 AM | #326 | |
Rep 1,954
12-26-2022, 02:19 PM | #327 | |
Rep 426
With this mod, you get the maximum volume all the time but the overall volume is not increased. I hope I am making sense. Hence it would only make the pops and bangs more pronounced. I am currently running 200 cells, VT midpipe and MPE. its extremely loud. I ran this mod for a while but used to be very nervous when starting my car late or early in the morning as the cold start becomes unbearably loud. So I had no choice but to go for a valve controller and turn cold start off. |
01-27-2023, 09:29 AM | #328 |
Rep 1,001
Hi does anyone know the specs of the exhaust valve housing bolts? (Length, M? X ?)
Thanks!
03-02-2023, 07:14 PM | #329 | |
Rep 146
Think this is a good method for anyone concerned about warranty or service tech’s noticing the harness being unplugged, the module missing, or it being fastened in the open position. Thank you. |
03-07-2023, 07:56 PM | #330 |
Rep 15
Thanks all. I just did this and it’s amazing. I have 1000 miles on it, going for break in this weekend.
I have my exhaust coming next week. Scorpion Axle back exhaust NVM Downpipes Avior Performance midpipe Last edited by Koala0802; 03-07-2023 at 09:49 PM.. |
