12-19-2023, 10:50 AM | #265 |
Rep 191,448
12-19-2023, 03:20 PM | #266 |
Rep 24
Is there no way to reprogram the valve button in the center console area to be some of the same presets? Say making A the same as open and C the same as the old closed? So that's now just a dead button?
12-19-2023, 06:10 PM | #268 |
Not my first rodeo
810
Rep 481
Got mine installed the other day with about 20 miles on the car 😄
Does seem a little louder, I have two buttons programmed on the Homelink mirror. |
12-20-2023, 11:34 AM | #269 |
Rep 191,448
Congrats
12-20-2023, 05:28 PM | #270 |
Rep 204
Just got mine from Mike at XPH, thanks Mike! Install took about 30-40 minutes, very simple and straightforward. I have a single midpipe and It definitely gets much louder with the valve fully open compared to the OEM settings. This is what I was looking for, as the OEM setting in sport+ still sounded muffled. Having trouble pairing to the home link though, as It says it’s paired but won’t actually open/close them. Will try again today after work as I see other members have paired theirs successfully.
12-20-2023, 07:35 PM | #271 | |
Not my first rodeo
810
Rep 481
12-20-2023, 10:01 PM | #272 |
Rep 24
Got mine from Mike also at XHP and decided to do a bit of a volume test before and after. I downloaded to my iPhone a free decibel meter (dB Meter) and on a cold start up it hit 93 dB’s. Got the SST in place and secured and started the car again. Flipped through the remote and made sure things worked (which they did brilliantly) and so after being in A I shut it off to cool completely. After a good 45 minutes, with the same phone in the same location (3 feet behind the car centered off the drivers pipes) I started the car up again. This time it maxed out at 104 dB in what I would consider matching orders of events. I can’t say anything about revs or what 5000 rpm’s sounds like but from a cold start, in a garage with no other changes but the SST, it was good for 11 dB. FYI, at this point the only “performance” mods done are BMC drop in filters.
NicolasB809.50 |
12-21-2023, 10:20 AM | #273 |
Rep 191,448
Congrats
12-28-2023, 01:25 PM | #274 |
Rep 338
Drives: 2023 BMW M3 Competition xDrive
Could you DM me with pricing on this please?
12-29-2023, 09:15 AM | #275 |
US ARMY
126
Rep 144
Drives: 2024 G80 M3 CP X-drive
mike@x-ph.com
Can you DM me a price on these shipped to 76542. Thanks brother. |
12-29-2023, 10:22 AM | #276 |
Rep 1,334
Drives: 2024 BMW M4 Base
Hey mike@x-ph.com ! Can I get a DM price to 29651 please?
12-29-2023, 01:11 PM | #277 | |
Rep 191,448
David In HD126.00 |
01-28-2024, 11:49 AM | #278 |
Rep 152
I am hoping someone can answer this. I was planning on getting SST and setting the start up mode to “always closed”. If I turn my car off with valves open, and the next use is a remote start, will it close the valves when remote started?
01-28-2024, 01:23 PM | #279 | |
Rep 422
It’s just going to stay in whatever position you left it in before turning the car off unless you change it with the fob.
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive |
01-28-2024, 01:25 PM | #280 |
Rep 152
I don’t want to have to remember to hit the close button every time before shutting the car off. I just want it to default to starting closed (the entire point of having valves).
01-28-2024, 01:55 PM | #281 | |
Rep 422
There is no customizing what the valves do outside of open, closed, let the car handle the valves like from factory.
01-28-2024, 02:23 PM | #282 |
Rep 152
It says you can set the memory setting to start how you’d like. I’d like it to start closed. I’m just wondering if it’s turned off in open mode, if it’ll go back to the start setting (closed) during remote start or if it’ll stay in the last setting until you hit the power button.
01-28-2024, 06:49 PM | #283 | |
Rep 422
01-28-2024, 07:01 PM | #284 |
Rep 152
01-28-2024, 07:08 PM | #285 |
Rep 422
Ahh gotcha. I would assume it would work like it was keyed on but I dont know for sure. I have the SST controller but I dont have the car yet, currently on its way across the Atlantic haha
01-29-2024, 09:03 AM | #286 | |
Rep 2,758
I have it programmed this way with no issues. |
