05-31-2023, 11:17 AM | #221 |
Rep 447
Drives: '24 X3M Comp
You only hear it on cold start for a few seconds and that's it.
Again, BMW would have to re-engineer the rear muffler for the rattle to go away because the AA EL isn't the only culprit. All the non-single midpipes have the same issue...PSI, R44, Akrapovic, Mosselman... It would seem the solution, hearing from Mike, is to simply pick up a new rear muffler (or axle back). I'm still waiting for my Valvetronic v2 Titanium axle back to see if it fixes the issue. Rattle is likely caused by increased vibrations in a certain frequency range causing something in the muffler to shake out of spec. A single midpipe simply produces a different vibration that doesn't blow up the rear muffler.
2024 F97 ///X3M COMP [AW/SO] Active Autowerke EL Mid Pipe + Axle-back | H&R Sport Springs |
05-31-2023, 12:20 PM | #222 |
Rep 310
Drives: ‘23 M3 Comp xDrive
Good to know that this isn’t just with the AA EL midpipe. I don’t know if this is useful info for anyone looking to purchase, but I 100% think the sound improvement during driving is worth the cold start rattle. It’s just on another level for me when it comes to pushing the car up RPMs. It’s addicting to make this thing scream!
anakratis647.50 static_void968.50 |
05-31-2023, 12:54 PM | #223 | |
Rep 51
05-31-2023, 04:40 PM | #224 |
#Driver
374
Rep 424
Decision retracted. Order is on. We'll see.
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan insta: gtsdaddy |
EatThatLunchBaby391.00 |
05-31-2023, 07:30 PM | #225 |
Rep 310
I think you’re making the right choice, the rattle is an inconvenience but definitely worth the trade off IMO. Like Mike said as well, if you really can’t stand it then I guess we will all be getting louder with axel backs 😁
05-31-2023, 07:44 PM | #226 |
Rep 39
Drives: X5 40i , G80 M3C
The improved sound of the AA EL easily outweighs having to hear the rattle during the 30 seconds of cold start.
But I really am curious on what exactly is causing it. |
GTS Daddy374.00 |
06-01-2023, 10:24 AM | #227 |
Rep 191,486
Do we know if disabling the cold start eliminates the issue?
anakratis647.50 |
06-01-2023, 12:54 PM | #228 |
Rep 447
It should. The rattle only happens on cold start. You don't hear it when driving around at 1-3k RPM.
06-01-2023, 01:02 PM | #229 |
Rep 253
06-01-2023, 04:47 PM | #230 |
Rep 31
Drives: 2021 330i xDrive / 2022 M3 Com
Installed mine two weeks ago an I have the same rattle. I did have trouble fitting mine on the passenger side down pipe. I had to shave down a lip on the inside of the mid pipe it was hitting and grind down the edge of the cat pipe that sticks out past the flange to get it to seat properly.
Maybe the tolerances aren’t close enlugh or to close and the tubing is hitting the inside of the midpipe until heat expansion kicks in? I was thinking of using an oscillating saw an cutting the tube down a quarter inch might fix it.
2021 BMW 330i xDrive
2022 BMW M3 Competition xDrive (Individual Riviera)(Ordered) |
06-01-2023, 06:29 PM | #231 |
Rep 522
are you guys sure the rattle is in the rear muffler - F80 used to suffer a lot from wastegate rattle on cold start
2023 G80 M3
www.instagram.com/modern.classica |
06-01-2023, 09:05 PM | #232 | |
Rep 39
It most likely is resonance induced from the x-pipe design. From what I understand, our rattle is almost the same as what people were experiencing from the PSI mid pipe…which is an x-pipe. |
06-01-2023, 09:34 PM | #233 |
Rep 310
06-03-2023, 10:17 PM | #234 |
Rep 447
06-03-2023, 10:23 PM | #235 |
Rep 447
2k on a midpipe and y’all are saying a rattle is okay lol. I would make AA answer for it, half the folks on here are the people who put the pitchforks on Valvetronic bc they make their exhausts in China. I rather have a reliable exhaust made in China than one that rattles like a 94 civic on startup. I would push for an answer…
06-03-2023, 10:28 PM | #236 | |
Rep 447
06-03-2023, 11:41 PM | #238 |
Rep 447
The Dinan topic does mention the rattle a couple times, though they have attributed it to the exhaust valve. I don't believe many people have ordered the AWE midpipe only, at least not from what I've seen. Changing the rear box alleviates the issue AFAIK.
06-04-2023, 06:03 AM | #239 |
Rep 310
It’s so odd to me that it would be just the resonance from the X-pipe design. I’m not saying it’s wrong but it distinctly sounds like it starts normal (~1 second), then mechanical rattle from the rear (~5 seconds), then loud resonance sound (~ 20 seconds) until the RPMs drop to normal idle levels
06-04-2023, 08:12 AM | #240 |
Rep 501
My ER has a bit of a rattle on cold start. Goes away when RPM kicks down. This is the stainless/standard length - h-pipe set up.I'
(I've got a stock axle back and stock valves) |
06-04-2023, 08:46 AM | #241 | |
Rep 39
I knew this could have been a problem when I initially ordered the EL pipe. There is always a risk when someone is among the first to get a new product. I had almost the same issue on my mustang when I installed Long tube headers with an X-pipe. Although that car did not have valves in the exhaust, the resonance matched the natural harmonics of the exhaust hangers and crated a slight rattle. Luckily that car was so loud at startup that you really could not hear it. X-pipes create resonance, almost like a pressure differential from when the exhaust collects again on the exit. It just so happens that the resonance is close to a natural harmonic of something located in the stock exhaust can. What the actual rattle is…I have no idea. I’m not an engineer but adding length to the x pipe could be a potential fix (alter the resonance freq). I don’t blame AA, PSI, or any other X-pipe manufacture as they most likely engineer and test their products as a package, i.e with their axle back connected. |
06-04-2023, 01:31 PM | #242 |
Rep 191,486
This issue has more to do with removing the cats than the brand of the downpipe.
Option 1 - get a resonated or catted midpipe, no cold start rattle but also a milder volume increase Option 2 - Get a non-catted and non-resonated midpipe, cold start rattle for a few seconds, then enjoy the sound for the rest of the time. Option 3 - upgrade your axle back and get the best of both worlds
