      04-12-2026, 01:14 AM   #199
shaunee
Drives: G80 M3 CX; TTRS; RS3 8V
Originally Posted by Donx3m View Post
I’m assuming you are talking about the custom tune correct if so, how do I counter him saying that my car can’t handle more power it doesn’t make sense to me why it wouldn’t car is up to date on every service possible
The only person that knows the "why" right now is the tuner, so ask him, why.
What were your trap speeds on the 1/4 for each map?
The custom map doesn't look great to me.
Stage 3 Hybrids M3 CX
99ron (DI only): 60-130 5.8s
E25 (DI only): 60-130 5.6s
      04-12-2026, 01:18 AM   #200
shaunee
Originally Posted by Eazy-E90 View Post
MHD stage 1 E40 flex map. Only mods are mid pipe and plugs gapped 0.022.
Any thoughts on the log?
Going to try stage 2 on the stock DP’s.
https://datazap.me/u/eazyx3m/logs/cm...22-23-24-25-26
Personally, I suggest this Stage 1 and Stage 2 map thing on this platform is garbage, in respect of using either stage map with stock primary cats.
Flash Stage 2 and log it, but there's zero reason (hardware wise) why it shouldn't be fine, imo.
      04-12-2026, 04:34 AM   #201
HerbDean
HerbDean's Avatar
112
Drives: 20 STI, 26 M3 Comp
Stg 1 looks clean. Load Stg 2 and see how it goes.
      04-13-2026, 04:52 AM   #202
shaunee
I ask him and he blames the car not being able to to handle more power I trapped a 123 on custom and 126 on it’s my 60ft was 1.5 on ots and 1.7 on custom
You trapped lower on custom than OTS? If that's the case, you're more than likely making less power on custom, which is just not right imo.
Just "blaming" a car is not the reason why he can't up the power.
Change tuners, if you're getting explanations like this!
Donx3m12.50
      04-13-2026, 08:24 AM   #203
Megahurtz
Drives: 2026 BMW M4 Comp X-Drive
This is 5 gear 2k to redline foot was 100% full throttle the whole pull
log
Looking at the log, you're likely hitting the load limit but you're not logging the limiter PID, only the actual RAM Load PID. But having tuned these cars, I'm sure its a load limit.
The cause is that many tuners will set the turbo to spool much quicker which is great for 3000rpm+ hits but when you do bog pulls it will overshoot boost/load limit and then close the throttle. It's normal. However, if it is causing a drive-ability issue, the solution is to fix the WGDC in that specific area. Turn down the base duty cycle at that low of an RPM. There are a few tables that would need to be edited.
Owner, Snackbar Tuning
Donx3m12.50
      04-13-2026, 03:11 PM   #204
Eazy-E90
Drives: X3M Comp
Alright new logs from above. This time MHD stage 2 on the flex map running E40. Same mods just mid pipe and plugs gapped at 22. Still stock DP’s
This first log (run 2) is definitely the worse of the two.
Any opinions?
https://datazap.me/u/eazyx3m/logs/cm...0jla066olul1zm
https://datazap.me/u/eazyx3m/logs/cm...0cjv06zb75lz4a
      04-14-2026, 01:52 AM   #205
shaunee
Any opinions?
You sure this isn't bad gas..... you shouldn't see hardly any corrections on E40.
      04-14-2026, 10:28 AM   #206
Eazy-E90
Drives: X3M Comp
The log I posted on 4/11/26 in this thread was on the same gas, the only difference was Stage 1 vs Stage 2. It could be bad gas though, this was Shell and I usually don’t fill up there, it was just the closest E85 at the time.
I was comparing logs with a buddy and he was seeing similar issues on MHD flex map on e40. Some of my logs looked clean like the second one I posted with almost no timing correction, while the first log had up to 4 degrees of correction. He was having the same issue some logs clean while others there were multiple corrections.
His was actually worse since he was also getting pretty bad throttle closure.
I’m going to keep logging and fill up at my usual E85 station next time to see if it makes a difference.
      04-14-2026, 01:15 PM   #207
shaunee
You need to do a couple of logs to see how it settles. It may undergo some adaptions especially on the first pull, should settle though for subsequent pulls.
I'm not sure I have seen OTS E logs before, but I know OTS 93 maps can tend to have a bit of correction. I wasn't expecting to see that with E.
      04-14-2026, 04:11 PM   #208
pseudomonas
Drives: X4MC
Anything concerning in this log?
https://datazap.me/u/avu211/logs/cmn...14ju06p5uy4xy8
Custom flex map on E44. High flow cats, single mid, front mounts, and xhp stg3.
Jnat1837.00
      04-14-2026, 07:24 PM   #209
JasonSB
Drives: 2022 BMW M4 XC
That looks good. Im sure it pulls hard.
      04-16-2026, 12:52 AM   #210
Sammykiller
Sammykiller's Avatar
108
Drives: G87 M2 6MT
Hello!
First time logging the platform, BM3 OTS E30. just got done going through my ptb clutch’s bedding/settle period and it was time to hit it. I don’t have a flex fuel sensor yet but my ultimate goal is to get the sensor installed and custom tune for flexfuel as I have multiple local E85 options.
Mostly want to know if any seems out of the norm, I won’t daily an E30 OTS tune and will mostly be on 93.
Thanks all.
https://bootmod3.net/log?id=69e06489232454143d9b33ff
      04-19-2026, 07:14 PM   #211
Sammykiller
108
Drives: G87 M2 6MT
Bump! Wondering if anyone that has experience reading logs can read the one I posted above, thanks!
      04-20-2026, 03:38 AM   #212
shaunee
Originally Posted by Sammykiller View Post
Hello!
Thanks all.
Quick look, it appears to be consistently correcting on cylinder 1. Really need a E sensor, as you have no real idea what your content is.
      04-20-2026, 02:39 PM   #213
Sammykiller
108
Drives: G87 M2 6MT
Thank you for taking a look, I will be getting the sensor and installing it in the coming weeks, after that it’s time for a custom tune, I will do a few pulls on the 93 OTS tune and post them here to see if there’s anything off about the “daily” tune.
      04-22-2026, 05:58 AM   #214
Donx3m
Donx3m's Avatar
13
Drives: bmw X3M
UPDATE
I’m pretty sure me and my tuner found the problem being fuel quality. I would always get 93 and e85 from the same gas station i decided to go to another one all the problems went away. We’ve spent countless days trying to find the problem for it to just end up being the fuel quality I do wanna shout out my tuner spicy car works from Germany, for not leaving me stranded and not giving up on the car great dude great people, we did also switch the car from a e50 tune to a e45 tune and ended up with more out of the car with that as well.
      04-22-2026, 08:19 AM   #215
HerbDean
HerbDean's Avatar
112
UPDATE
Great news. Glad you confirmed the issue and are able to move on. Good example of how important 'good' gas is on forced induction.
Donx3m12.50
      04-23-2026, 05:17 AM   #216
Megahurtz
UPDATE
Not all E is the same quality. Some stations mix such low grade gasoline with E so that the octane rating is lower than you would expect on E.
If you want the best performance, get your pump gas from a top tier fuel provider and then your pump E from a well known E station that sells high quality E such as Thorntons, Shell or Sunoco. These stations get their E from quality providers.
I see it all of the time where clients will blend with crap E and crap 93 octane thinking its the same but the cars wont handle as much timing as when running good fuels. This is also why OTS and even some pro tunes run less timing than you actually could push on E50 in these cars.
I run specific fuels to hit E50 and my car handles more timing just fine. Most tuners seem to cap out at 18-19 degrees on the S58 and OTS tunes don't typically go past 17.5 degrees.
      04-25-2026, 01:07 AM   #217
Sammykiller
108
Drives: G87 M2 6MT
Got some more logs, not very long ones but doing a mix of 2nd and 3rd gear pulls on OTS 93 octane tune, car has maybe 2 gals of E85 on these pulls.
Mostly just making sure OTS isn’t doing anything out of the norm that could cause issues until I get a flex sensor and custom tune for flex fuel.
https://bootmod3.net/log?id=69eac339c9db57557e78485c
https://bootmod3.net/log?id=69eac49eb871d247c3c57ce6
      04-25-2026, 01:37 AM   #218
shaunee
Always best to do full RPM sweep pulls.
Nothing looks untoward in the log for OTS.
Future logs, log ignition on each cylinder as well (not just corrections).
      04-25-2026, 04:08 PM   #219
Sammykiller
108
Drives: G87 M2 6MT
Appreciate the info, will add ignition to all logs moving forward and use manual loggin instead of the auto log so it shows more of the RPM range in each pull.
